Question about Porter Cable Robotoolz Electronic Self - Leveling 5 - Beam Laser Level
TURN ON LASER IT FLASHES A FEW TIMES FOR LEVELING AND SHUTS OFF. I'VE CHANGED BATTERIES. SAME RESULTS. I'VE EVEN HAD PROBLEMS WITH PUTTING ALL BRAND NEW BATTERIES IN LASER AND IT WOULD KEEP FLASHING AND NOT GET LEVEL. SO I WOULD HAVE TO PUT 2 NEW BATTERIES AND 2 LOW BATERIES TO MAKE IT WORK.
2 Suggested Answers
SOURCE: new out of the box drill set fresh out of box and
im havingg the same problem have tried three chargers and four batteries with same result.
Posted on Sep 02, 2011
The camera keeps turning on and off by itself
When your camera shuts off by itself, it has detected an error inside. Could be hardware failure, but also a software problem. So no use of switching it on again. Please when it shuts down again, wait till no memory access light is burning or flashing. Then remove the battery. The best thing before reinserting the battery is to charge it first. But if you are sure the battery is fully charged, wait a few moment before you reinsert the battery. Then when you have put in the battery switch on the camera.
When you remove the battery for a few moments, the camera will have a "cold" start. So the program that makes your camera work, start from scratch. As long as the battery is in the camera, the program in the memory does not change. That is why you should the battery.
If your camera has a hardware failure it won't be solved when you remove and reinsert the battery. If the switching on and of occurs while zooming, it could be the lens mechanism has a problem with the gear or motor. If this happens, you should visit a service centre, or buy a new camera.
Then it could be the battery is charged, but not powerful enough to do all tasks. If the camera detects the voltage is under a certain level, the camera also shuts down. If every time the flash has to charge, or the zoom or AF motor needs to work, the camera shuts down, it could be the battery is on its end of life. But for that you should look on the display. Most cameras do have a battery level indicator.
Feb 04, 2014 | FUJIFILM FinePix JX250 Digital Camera
NEC vt800 projector troubleshooting
That is a problem with the lamp. Replace it with a known good one.
Feb 27, 2013 | NEC VT800 LCD Projector
Flashing 0% battery and won't turn on
I had the exact problem with the blinking top menu. I found that my memory card had gone bad. one i put in a fresh card the camera operated normally.
Aug 27, 2012 | Canon EOS 60D Digital Camera
Where can I get battery power pack(shell with recharchable batteries inside) for metz 45 cl series,good second hand,off market brand,or even geniune brand,thank you
I have a lot of old 45-40 Series Metz 45 NiCd battery packs, that I will eventually rebuild with new NiCd batteries. I got them from Photographic Trader magazine and from ebay. I've heard that NiCd cells are going out of production, in favour of NiMH cells. I've found it's easier to put NiCd or NiMH cells in the alkaline battery holder, the flash recycle time is only slightly longer. I charge them separately out of the holder, or in the holder with a connector I made. NiMH cells need a suitable charger, with peak detection, as NiMH cells don't like being overcharged.
Nov 05, 2010 | Metz mecablitz 45 CL-4 TTL Flash
Dell Inspiron 531 (desktop) won?t turn on/boot
You've either got a bad motherboard or a bad processor (I'd lean to the motherboard being bad). I would honestly take this into a computer repair shop and have them check both.
Oct 22, 2009 | Dell Computers & Internet
Camera says "change batteries" even with new batteries
Hi, Has anyone resolved this issue yet, I have a powershot s2 IS with the same issue - i replace the batteries with brand new duracell's and it says replace batteries i reseat the batteries and it works for a few pics if im lucky then says replace batteries again - any help would be appreciated - Canon offers no solution.
Oct 13, 2009 | Canon PowerShot A720 IS Digital Camera
Switching the camera on .
omg, i have the same problem! why does it do this?!
Jan 16, 2008 | Vivitar ViviCam 4345 Digital Camera
Canon A95 "Change Batteries" problem!
I have this problem as well. I thought it was a problem with my NiMH batteries. So, I bought a volt meter to make sure the batteries worked. I have 8 AA NiMH batteries. I charged them all up and tested them with the volt meter. They were all good to go. However, no matter what I put in the camera one of two things happens:
1. I get the "change batteries" message.
2. I don't get the message, but the next time I check the camera (a few days later), one of them is totally drained.
Something is very wrong and I plan on contacting Canon.
Nov 30, 2007 | Canon PowerShot A520 Digital Camera
You need to use 2100 mAH or 2300 mAh rechargeable batteries - alkaline batteries will not maintain the high level of power required.
Aug 06, 2017 | Canon PowerShot A95 Digital Camera
No pwer
Well with a clutch of cameras showing the same fault - together with other queries of a similar nature I suggest you contact Canon on an Educational level- for a bulk replacement deal. There are obviously showing a common manufacturing fault
Sep 21, 2007 | Canon PowerShot S1 IS Digital Camera
Porter Cable Robotoolz Electronic Self - Leveling 5 - Beam Laser Level Logo
Top Porter Cable Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Porter Cable Measuring Tool and Sensor Expert? Answer questions, earn points and help others
