Question about LG LWHD1200FR Wall/Window Air Conditioner
We also have a unit that will not drain out the back, but pools in the front compartment instead. It builds up until the fan sprays it into the room, and drips into the living room floor. It doesn't seem to be getting to the back where it is supposed to drain at all, and yes, it its slanting. Any suggestions would be greatly appreciated.
The reason is probaly an easy fix the water flow sometimes builds up scum from bacteria and dust buy a 12 oz bottle of rubbing alcohol take out the reusable filter so that you see the coil behind below the coil is a small pooling tray that water empties into from the coils when its operating.pour the entire contents of bottle into that collection tray that will dissolve the scum and kill the bacterial build up that can block the drain tube also try removing a blockage in drain tube with a pipe cleaner or a scredriver but be careful you dont damage the coils with it so try to use something bendable that won,t cause damage..
Posted on Jan 21, 2011
WATER COMING THROUG FRONT OF FUJITSU fan coil unit
vent pipes are not sealed properly and condensation is building up and leaking out .
Jun 10, 2017 | Fujitsu 12RLS Halycon Wall Mounted Air...
I have a Kenmore refrigerator. Model 596.65234404, serial number ky3257801. Occasionally there is water forming puddles on the floor in front of the refrigerator. What maintenance procedure can I do to fix...
That water is from the melting frost of the automatic defrost cycle. Their is drain in the freezer behind the back wall under the evaperator coil that is blocked, so instead of defrost water draining it's pooling in the freezer or in some case espically on models with the freezer on the top,the water is leaking from the freezer vents into the fresh food compartment.
The way to clear the drain is remove back plate and remove all ice build up and GENTLY make a small hole in drain through then totally flush w/warm water.
The exact location of drain is under the coil behind back freezer plate in the center
Good luck
I hope this helps
Aug 24, 2011 | Refrigerators
Water is leaking from under the freezer compartment onto the top shelve of my whirlpool refrigerator
Good luck,
Gene
Aug 10, 2011 | Whirlpool Refrigerators
Water is dripping into fridge compartment from section separating fridge and freezer compartments, otherwise, both seem to be working fine. unit was new in 2001, model ET21PK.
Good luck
I hope this helps
Gene
Aug 09, 2011 | Whirlpool 21.0 cu. ft. Top Freezer...
Water dripping from Funny looking . unit in ceiling of refer
The way to clear the drain is remove back plate and remove all ice build up and GENTLY make a small hole in drain, then totally flush w/warm water.
Good luck
I hope this helps you to stop that leak,
Gene
Aug 09, 2011 | Frigidaire FRT15B3A Top Freezer...
Water is leaking into teferagerator, seemingly from the freezer compartment. It is a Kenmore Coldspot model 106.72132101 type 21 TFA.
Good luck
I hope this helps
Gene
Aug 01, 2011 | Kenmore 61282 / 61284 / 61289 Top Freezer...
There is a pool of water forming under the crisper - I have cleaned it all out and it continues to collect water - I need to clean it up once a day.
Hi and welcome to FixYa. I am Kelly. The compartment drain is most likely clogged. I have checked the manuals that I have and I am not seeing a compartment drain tube. I do see what is called a cap. Units that have this cap like device on the bottom of the compartment (Under the refrigerator) often experience particulate build up in the cap. The cap itself is hollow and water will drain into the cap and then drip into the catch basin below the cap. Remove the cap by pulling down hard and slow, then clear / clean the cap passages. When this cap clogs it causes water to remain in the compartment and eventually run out the door of the refrigerator and pool usually near the corner of the unit. You will need a thin piece of wire to also clear the water passage from the inside compartment to the mating point of the cap.
The evaporator drain will sometimes have a plastic disc in it that has holes in it. You will need to lift out the disc to make sure the water passage is clear. A good hard tooth pick or a jewelers screw driver works great for removing the disc.
See item 5 of this link:
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5171276&diagram_id=1334945#d1334945
Make sure that the metal tray drain on the bottom of this item is also clean
If yu have to do a manual defrost to clear the unit of ice so you can clean the drain just unplug it.. place a fan on it for a little over 2 hours. (Water mess) The goal is to get everything to room temp so that any residual ice is melted. The clear all water passages.
Now If by chance I am mistaken from my manual research and your unit in fact has a drain tube clear the tube using a solid piece of copper wire or... with NO sharp end. Fold it back onto itself if need be or cut it clean so that only the wire insulation touches the tubing but clear the tube end to end.
By doing the above you should stop your water pooling problem.
Thanks for choosing FixYa.
Kelly .
Oct 21, 2010 | Maytag MTB1891AR Top Freezer Refrigerator
This summer I have ice build up on top of the unit. I have a drain hose so the bucket is not full. I have cleaned the air filter. I have also removed the front grill and used a fine brush to remove dust...
The coils you see on the back of your dehumidifier are the evaporator. When the unit runs, the coils get very cold. As the fan draws the room air over the coils, the humidity in the air condenses out of the air onto the cold coils. But, if the temperature of the air the fan draws over the coils is too cool, the humidity that condenses out of the air freezes on the coils.
To remedy this problem, you can try any of these:
Warm up the room the dehumidifier is in.
Put the dehumidifier on a sturdy table (the room air is coolest near the ground).
Turn the unit off until the room warms up.
Take care.
Aug 12, 2010 | LG LHD45EL Dehumidifier
My bottom refrigerator is not cold. The freezer is okay.
Check to make sure the fan in the freezer compartment is working and not blocked. This delivers the cold air to the refrigerator. The fan should run every time the freezer calls for cold.
Jul 22, 2009 | Refrigerators
Is there a drainage plug or hose on the air conditioner? It's leaking.
To increase the efficiency of the air conditioner's cooling to meet US energy requirements, most manufacturers eliminated the traditional drain plug. Instead, they switched to a design that used the extracted moisture from the room to help evaporatively cool the condenser.
To do this, the traditional fan blade was replaced with a 'sling blade' which was a fan blade with a rim or ring around it. The drain plug or drain hole in the bottom of the pan was eliminated and replaced with overflow notches in the back edge. Along with a solid piece drain pan, this provided a pool of water for the edge of the sling blade to dip into and pick up water to 'sling' or spray around the compartment to create evaporative cooling. The overflow notches established the maximum depth of the water pool and are also the lowest place when installed properly.
Although this is more efficient, this has caused 2 problems: increased noise as the water is slung around and water spray from the side air vents.
Persons have drilled holes through the pan or back edge as drains. This is not recommended as it negatively effects the colling ability of the unit and could lead to a voided warranty or premature failure.
Instead, insure that there is adequate pitch with the installation and make sure the overflow notches are kept clear.
If you 'need' a drain hose, my suggestion would be to drill into drain pan's back edge or the rear potions of the sides. The hole should be at the same level as the overflow notches. Once the drain hose is installed, block/cover the overflow notches to redirect the excess water to the drain hose instead.
Jul 07, 2008 | Samsung AW0603B Air Conditioner
LG LWHD1200FR Wall/Window Air Conditioner Logo
159 people viewed this question
Top LG Heating & Cooling Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
