Question about Hitachi 1TB 7200RPM 32MB BUFFER SERIAL ATA II/300, 3.5INCH, 8.8MS SEEK, DESKSTAR 7K80, H 1 TB Hard Drive
My hitachi hard drive gont tern on can u fix the
  • Hitachi Master
  • 27,725 Answers
One bad/faulty lead can cause a computer with lots of problems
replace all the leads that attach to your hard drive including electrical extensions + IDE,SATA and the ones that attach from your motherboard to hard drive
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they are probably old and faulty ?
hope this helps
Posted on Oct 03, 2010
Hitachi 1 TB external hard drive won't power up
yes you can fixed it replase cover and and cut hdd and buy new rak out side and conected the new rak with hdd that is very esy
Apr 23, 2013 | Hitachi Touro Desk 1 TB USB 20 External...
My simpletech hard drive hitachi 750gb doesn't work and make noises
Clicking Hard drive When a hard disk makes a clicking sound and the computer does not detect it then the hard disk is faulty. This is commonly known as "The click of death".
There is no way of fixing this hard drive, if you need to recover your data, then there are companies that can recover data off faulty hard drives BUT it will cost you an arm and a leg for their services.
Apr 05, 2013 | Computers & Internet
External hard drive not accessible
A Hitachi USB external hard drive is a device that acts as portable, removable storage for your personal computer. If you need additional space to house files on your computer but don't want to go to the trouble of installing an internal drive inside the case, a USB external hard drive is your best option. These drives are "plug and play" devices, which means that very little can actually go wrong. If you're having problems, fixing them shouldn't take more than a minute or two.
Check your connections. A USB cable needs to be connecting your Hitachi external hard drive to your computer. Your external hard drive's power cable also needs to be plugged into a functional wall outlet, surge protector, extension cord or power strip. Make sure your Hitachi USB external hard drive is turned to "On." An "On/Off" button is present on the front of the unit. If the indicator light around said button is not illuminated, the drive is "Off" and your computer won't be able to recognize it. Press it to turn it on and then try to access your drive again. Format your hard drive. If your Hitachi USB external hard drive doesn't currently have a file system on it, you won't be able to use it to store data. Open up the "Computer" icon in the "Start" menu. Right-click on your USB external hard drive's icon and click "Format." Click "Start." This will install a file system on your Hitachi USB external hard drive. After this process is finished, you will now be able to use your drive. Restart your computer. Certain models of computers (especially older models) won't recognize new hardware unless your computer boots with the hardware already connected. Leave your USB drive plugged in and restart your computer. Once you do this, your Hitachi USB external hard drive should appear as normal in the "Computer" folder with all of your other drives. Hope this helps.
Jan 08, 2013 | Hitachi Travelstar 7K60 (DK23FA60) Hard...
My hard drive is not being recognize
Jan 06, 2013 | Computers & Internet
ATA Hitachi HTS547564A9E384 Drive has 117325064 bad sectors. Ubuntu says to backup all data and replace the disk. Im using an HP Laptop and this started happening only 2 weeks after i bought it. Its an...
I'd take it back right away, sounds like the hard drive is going. There are things you can do to try and fix it, but I'd take it right back and get the seller to fix it. It also could be that the drive has come loose but odds are the hard drive is going. So copy all data that's important to DVD and take it back and have them replace the hard drive.
Aug 16, 2011 | Hitachi Travelstar 5k750 Hts547564a9e384...
My Hard Drive broken how can i fix this hard drive
If the hard drive is faulty, then us mortals cannot fix these hard drives.
The best solution is to buy a new one.
Apr 09, 2011 | Hitachi (0S00157) 500 GB SATA II Hard...
Toshiba new computer would not be able start or tern of.It has note about harddrive problem
whats the exact message? if it says theres a hard drive problem i think you need to contact their hardfware tech support to have the hard drive replaced. check on the bios if hard drive is detected. if not hard drive needs to be replaced.
Sep 12, 2009 | Computers & Internet
Installation
What ATA setting does your computer support? Hitachi makes a program you can drop the ATA settings down on your drive and that might fix your read error problems. It's called Feature Tools and it is on there website. http://www.hitachigst.com
Jan 13, 2008 | Hitachi Deskstar T7K500 320 GB ATA-133...
Hitachi 1TB 7200RPM 32MB BUFFER SERIAL ATA II/300, 3.5INCH, 8.8MS SEEK, DESKSTAR 7K80, H 1 TB Hard Drive Logo
56 people viewed this question
Top Hitachi Computers & Internet Experts
steve morris
steve morris
Are you a Hitachi Computer and Internet Expert? Answer questions, earn points and help others
