Question about Craftsman 4 Cycle Blower/Vac
I have the same problem as gjmaag2, I removed the muffler and while there were some deposits on the exhaust port walls, nothing close to clogged. However, with the muffler, you can't see inside. All i can see is the inlet is clear, and the exhaust hole is clear. My compression is 105 PSI, good spark, fresh gas, wet plug, and clean air filter.
  • 1 more comment
  • john0132 Oct 03, 2010
    The advice I got from the first expert was to adjust my carb to increase air. I am not confident with this response since the carb has NEVER been adjusted or touched. I've seen carb screws back out from vibration, but never back in. In addition, the starting sequence calls for full throttle. How do you get MORE air into an engine?
    The blower experienced a blown head gasket while under warranty. That was repaired. Other than air filter and occassional spark plug cleaning, nothing has been done to the unit.
    Lately, it became harder to start. Now, it will start and run for a few seconds then die. This is after priming. After a few cycles of this, it won't start at all. I checked compression, 105 PSI. I checked spark with a gap tester. The spark easily jumped a 6 mm gap so that seems okay to me. The plug comes out wet so fuel would seem to be ruled out. As noted before, I pulled the muffler and saw nothing plugged, a few minor deposits was all. Also, I am on my second batch of fresh fuel, mixed 40:1 per the OEM's instructions.
    This thing should run????? Is 105 PSI too low? Could I have another blown head gasket? It's been a long time, but it seems like I had the same symptoms when the head gasket blew.
    His problem and mine were as follows; Units have compression, his 95 PSI, mine 105 PSI, strong spark (mine had a strong spark across a 6 mm gap), fresh gas (mine X 2 batches), wet plugs, and clean air filters.
    But it won't run. Mine will run for a second or two after priming. After five or six times of this, it won't even do that. Mine had a head gasket failure when it was about a year old, and was replaced under warranty. The first expert suggested that the carb. needs adjusting. My problem with that is that my carb has never been touched, so unless vibration backed something out, I can't see it. Further, the starting instructions call for wide open throttle, so again, I am having trouble with the lack of air theory.
    I am also wondering if the compression is within range? It also seems to me that the symptom I see now are the same as when the unit needed a new head gasket. However, the 105 PSI reading seems to prove otherwise?
    I didn't think you were right, but I'm big enough to admit that you were definitely on the right path. It turns out that there was supposed to be a plastic stop cap to limit the mixture adjustment. I could see where it HAD been. Guess the thing broke and fell off, leaving the mixture screw to do whatever it wanted.
    I readjusted the Idle (air?) screw to factory settings (4.5) turns, then took a shot in the dark and readjusted the mixture screw to three turns. Fired right up! Took closing the Idle one turn, and closing the mixture screw 1/2 turn to get it idling without stalling... Runs like a champ.
    Thanks
  • 1,040 Answers
Here is a link to a couple of my Tips:
www.fixya.com/support/r6081405-cleaning_small_engie_carburetor
The KEY to getting your machine running is the Den Tek Brush.
Jim
Posted on Oct 04, 2010
    President:
  • 2,047 Answers
Sorry i couldnt find the problem with gjmaag2. But based on your explanation i figure your unit does not accelerate as it should?
If this is the case: Mufflers usually are seen through and you think there is no blockage. But the inner walls which contain the actual filterings components might have been blocked. If it is affordable get a replacement for the muffler otherwise get an expert to open it up and do a service of the muffler.
Hope this solution has been helpful?
Posted on Oct 03, 2010
  • Rockme
    Rockme Oct 04, 2010
    Sorry i couldnt reply your comments earlier it was due to the time difference. Also i would love to say thank you for the continuos feed back.
    Please endeavour to rate the response provided.
    And please visit fixya again soon.
    Guru:
  • 1,051 Answers
If the plug is wet your fuel air mix is too rich. Increase the air in the mix and you should be fine. To increase the air adjust the screw on the side of the carb.
  • 1 more comment
  • Bob Korsu
    Bob Korsu Oct 04, 2010
    john0132,
    Two things to cosider, 1. yes engine vibration can cause the carb adjustment to be off,but while it's not highly probable that this is the cause, it is worth checking, and second, you mentioned that the head gasket needed replacement. This is not typical unless there is an underlying problem. I 45 years I needed to replace 1 head gasket and that was because a pooly milled head caused the gasket to fail. I removed the head, took it to an auto machinist and had the head milled to perfection. My total cost was about $100 and a couple of hours of my time.
  • Bob Korsu
    Another thought. If the plug is wet with water the problem is definately the Head.
  • Bob Korsu
    Bob Korsu Oct 16, 2010
    Have you resolved the issue?
SRM 2400 trimmer. Why doesn't it start?
Ralph, if you are getting fuel, spark and have compression , I suspect the muffler screen is plugged. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Small Engine Repair Cleaning Carbon Buildup on the Exhaust Port Muffler on...
Echo trimmers and loss of power EXHAUST PORT CLOGGED
Symptoms Repair Of Clogged Spark Arrester On Grass Trimmer
My Aunt Echo PB 2100 Blower with Clogged Spark Arrestor Screen
Apr 17, 2016 | Echo Garden
576xpchainsaw it is backfiring when trying to start
Backfiring is ignition or fuel. You said you checked for sheared flywheel key. Was is sheared? If any doubt, change it. The other issue could be excessive fuel or clogged exhaust ports. Remove the muffler see it the ports are clear. Is the muffler clean?
When changing the ignition module did you properly set the air gap? It should be .012"
Apr 27, 2014 | Husqvarna Garden
Can't pull the starter cord, it's very hard to do. Removed spark plug and then the pull cord worked fine. Put the spark plug bvack in and once again the starter pull cord was hard to pull. Seems...
Hi and welcome to FixYa, I am Kelly
Remove the muffler and clean out the exhaust port and screen. You will have to disassemble the muffler and clean off or replace the screen item 8 of this link:
http://www.partstree.com/parts/?lc=echo&mn=CS-330T++S%2FN%3A+C08611001001+-+C08611999999&dn=7946
Before taking the muffler apart... unhook the spark plug and just pull it though with the muffler removed. If it pulls normally you know you have found the problem.
If it still pulls hard...check the exhaust port of the cylinder head for 2 tiny holes (not screw holes) Some have them some don't depending upon the year of the saw. If you do find 2 small holes that appear clogged with carbon... do your best to clean them out.
Thanks for choosing FixYa,
Kelly
May 15, 2011 | Echo CS400 18" Chain Saw
ON MY ECHO PB 230LN HAS NO POWER.SCREEN HAS BEEN TAKEN OUT OF EXAUST ,NEW CARB KIT,OLUG AND FILTTERS. STARTS FINE,IDLES BUT WONT PICK UP SPEED
I think you are on the right track with removing the screen from the exhaust, but I feel your exhaust blockage is further back...possibly in the muffler or ,most likely, in the exhaust port itself. To check, remove the muffler and visually inspect the muffler port. If it is clogged, rotate the piston to the top of the cylinder and using a dull small screwdriver, chip away at the carbon until you have it clear. don't chip too hard, you don't want to damage the piston. Use some compressed air to blow away the debris. Lower the piston and blow away any stray debris that might have ended up in the cylinder. You can test run with the muffler removed, but only for a few seconds, and it will be very loud.
If the muffler port is clear and the test run without the muffler doesn't cause a significant difference in the engine speed, then the next course is in the carburetor. Most of Echo's current products use carbs that are not adjustable, therefore the carb must be rebuilt or replaced.
Sep 12, 2010 | ECHO, Inc. PB-251C Handheld Blower
Stihl gas trimmer bogs out, everything else is fine
check air filter if clean check spark arresterin muffler usually a screen under plate where exhaust comes out also tube shaped can be pulled out with pliers,if clogged canclean with wire wheel also can remove muffler tosee if exhaust port ic clogged with carbon if all is ok problem maybe with carb hope this helps
Aug 13, 2010 | Homelite Mighty Lite Lawn Trimmer
I have a Ryobi brushcutter that is 4 years old.When I was using it the other day it just would not run at full throttle. I checked spark plug,air filter and fuel filter. No adjustments on carb. I have no...
Smokey 2 cycle oil will cause the exhaust ports to carbon up and plug the spark arrestor.
Remove the muffler, use a pick to clean out the exhaust port on the engine, and the muffler inside opening, then clean the spark arrestor screen, to assure yourself you are correcting the problem start the machine up with the muffler off, it should run like a charm, if it goes back to running badly when you reattach the muffler it may be clogged on the inside.
Jun 14, 2010 | Ryobi 30 Cubic Centimeter Gas Brush Cutter
Can't get my Echo PB251 Blower to rev up at all, unit is 8 mo.s old was running fine now all of a sudden won't rev up, I have changed plug gas filter,cleaned all filters including spark arrestor changed...
guarantee exhaust is clogged maybe not muffler but exhaust port pull muffler off check screen and muffler then look into exhaust port usually rectangular port is closed down with carbon pull starter slowly to lower piston then scrape out carbon with screwdriver clean as good as possible then blow cylinder out make sure to get all pieces of carbon out reassemble should run fine
Jun 14, 2009 | ECHO, Inc. PB-251C Handheld Blower
Starts but won't speed up enough to run
If this is a 2 cycle engine the problem could be that the exhaust is clogged. Most 2 cycle engines have a spark arrestor on the muffler which clogs. could also be the exhaust port from the engine. remove the muffler and check it out.
May 15, 2009 | Garden
Engine will only run on 1/2 Choke
Hello edv40026:
Have you Checked the Exhaust Port and Muffler for Restriction?
From your Description it Sounds like the Exhaust Port or Muffler is Restricted with Carbon Deposits, the Carburetor Metering Pump Actuator Gap is Incorrect or the Compression is Low (Worn Rings/Cylinder).
>>The Following is a Basic Instruction File for Doing a Diagnostic on the Engine for this Problem. Any Input is Appreciated.
>>**Remove the Muffler and Make Sure the Exhaust Port is Clear.
>>If it is, then Try to Start the engine with the Muffler Off.
>>If it Starts and Runs Properly, then Clean the Spark Arrestor Screen in the Muffler or Replace the Muffler if Required.
Is the Fuel Line from the Fuel Filter Staying Full of Fuel?
The Carburetor Metering Jet Actuator is Set so the Pump Diaphram Dowl is Just Touching the Actuator Arm. These Components are Located Under the Cover with 4 Small Screws Holdong it to the Carburetor Body.
Please, Do Not Hesitate, If you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
May 13, 2009 | Craftsman Garden
Homelite ut o8107 blower 25cc will only idle
Hello:
Have you Removed the Muffler and Checked the Exhaust Port and Muffler for Carbin Restriction?
Remove the Muffler and Start the Unit. If the Operates Correctly, then the Spark Arrestor Screen is Clogged and the Muffler/Screen Requires Replacing.
Make Sure the Exhaust Port is Not Restricted Also.
Hope this Helps.
Good Luck
Respectfully
John
May 09, 2009 | Homelite 'Yard Broom' Leaf Blower
Craftsman 4 Cycle Blower/Vac Logo
60 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
