Tub will not turn when in wash cycle but will turn in spin cycle. transmission?
  • 905 Answers
It might be the transmission, might not.
Some washers that used a belt drive between the motor and transmission would have the same symptoms if a solenoid didn't actuate properly.
Most washers now are being made without a belt drive, the motor is directly coupled. Motor spins one way for wash cycle, and spins the other way for spin. Basket still only turns 1 way though. In this kind of setup, your drive coupler could be stripped in 1 direction, and still fine in the other.
Take a look at the transmission, determine if it is belt drive or not. If there is, look for a wiring diagram pasted somewhere, usually on the access cover. Check the solenoids first, before disassembling for transmission service.
Posted on Oct 03, 2010
  • Sheldon Dedek Oct 03, 2010
    Also, your wash / load size may be having issues. When in a wash cycle, motor control is through the size selector. Once the pressure switch / level switch is satisfied, the then the motor is allowed to run in the wash cycle. Sometimes moving the selector switch back and forth will clean the contacts enough for it to start working again. Easy to service though, the pressure switch / wash size assembly is located in the control cabinet where the timer dial is at.
White-Westinghouse wash cycle not engaging
Likely transmission failure. The motor controls agitation as well as draining
Feb 26, 2013 | Washing Machines
Maytag Performa washer drum turns with agitator. Also the brake doesn't stop the drum at end of cycle or when cover lifted.
The first thing to check is the clutch. It's supposed to lock the inner tub and drive the transmission (agitator) when the motor turns in one direction, and spin the tub when the motor turns in the other direction. It's also possible the agitator drive shaft coming out of the transmission and the concentric tub drive shaft are frozen together (worst case) - this is usually caused by a bad bearing seal allowing water to leak into the shaft.
Lifting the lid during the spin cycle should disconnect power to the motor - maybe what you see is the tub continuing to spin because the transmission is acting as a flywheel. Either that, or the lid switch actuator is not working properly.
Nov 27, 2010 | Washing Machines
Washingmachine tub spins during the wash cycle
If it's a top loader it sounds like the spin pall on the transmission is stuck, which would mean new transmision
Aug 06, 2009 | Whirlpool Washing Machines
Tub sometimes will not spin to wring out clothes.
Sounds like the machine is not pausing between cycles to allow the transmission to lock into spin.
Eric
Jul 02, 2009 | Kenmore Washing Machines
Loud noise in spin cycle
it is your bearings and your transmission the noise is coming from your bearings but because you have to push the basket to get it started your transmission is bad also
Dec 30, 2008 | Maytag Performa PAV2200
Washer wont spin
if the coupler and clutch are ok and you can hear the motor functioning, then it appears that your transmission is bad.most of the time you will see that in the days/weeks leading up to this that your cloths were more wet than usual when you took them out of the machine. Check your owners manual for warranty information. Some machines had a 5 year warranty on the transmission or gear case as whirlpool likes to call it.
Dec 29, 2008 | Roper RAS8445KQ Top Load Washer
Tub spins while in wash cycle
suspect what ge call a mode shifter pull front panel off by sliding putty knife along edge at each side and pressing clips front comes right off look on motor for a flashing green light (washer must be in operation) there are 2 wires in a single plug on motor these run back to transmission area with a volt/ohm meyer unplug and ck between the wires for continuity should be roughly 90 ohms if bad will not show any continuity
Oct 08, 2008 | GE WWSR3090TWW
Washing Machines Logo
Top Washing Machines Experts
