Question about Peg Perego John Deere Gator HPX Ride on Toy
Not sure if battery's bad or shifter is out. what indicates full charge on the battery?
    Sniper:
  • 70 Answers
No, just the shifter. Just to check you can exchange the red and blue wires under the pedal(just for a second or so, do not do this permanently) to see if you get power to the wheels, if so then yes it is Definitely only the shifter, but I am still pretty sure it is just the shifter. you can also call Peg Perego Tech support which is excellent and they can help you too 1800-728-2108 and parts can be priced and found at www.mypegperegoparts.com the battery charger should have a led light that will glow green at full charge, and yellow if not charged all of the way.
Posted on Mar 02, 2011
My paperwhite won't turn on even after a charge
You may have a bad cord or need a new battery. when you charge does the light come on? If not you have a bad charge cord. Any similar USB cable will work. Try charging again.
Does the light change from yellow to green; which indicates a full charge but still won't work? I'd suspect a bad battery. You can order one from Amazon or may find one at a battery store or Best Buy. Take the kindle along with you to make sure you get the right one.
I've had my paperwhite about 5 years, charge at least once a month and have had no problems.
May 28, 2016 | Amazon Kindle Paperwhite
Power portastudio
Gel cell batteries usually are good for 3 to 5 years and from your description, it sounds like the battery is not recharging properly. They will indicate a full charge but in reality, do not have the stored power to operate the device. Check for replacement batteries at your local burgular alarm shop or buy online BUT make sure to match the voltage and AH (amp hours) ratings.
May 09, 2014 | Anchor Audio PB-2500 Battery powered sound...
Aquasoothe travelite scooter, the batteries are fully charged, the battery gauge is showing full, but the battery light is flashing. It flashes 7 times then pauses, we can't get the machine to move or...
Response to similar query in 2011.
http://www.fixya.com/support/t5751777-aquasoothe_travel_lite_instruction
not my words. The link to the pdf for this is http://www.discovermymobility.com/store/scooters/summit-scooters/elite-portable-scooter/manual.pdf
you want page 22.
Problem Check Point
The driving of the wheelchair is too slow or insufficient, the status
indicator lamp flashes slowly Batteries are exhausted and need to be recharged
1 flash The battery needs charging or there is a bad connection to the battery. Check the connections to the battery or charge batteries.
2 flashes There is a bad connection to the motor.
Check all connections between the motor and the controller.
3 flashes The motor has a short circuit to a battery connection.
4 flashes Freewheel is engaged.
5 flashes Not used.
6 flashes The controller is being inhibited from driving; this may be because the battery charger is connected.
7 flashes A throttle fault is indicated. Make sure that the throttle is in the rest position before switching on the scooter
8 flashes A controller fault is indicated. Make sure the controller connections are secure.
9 flashes The parking brakes have a bad connection. Check the parking brake and motor connections. Make sure the controller connections are secure.
The-Active-Light
does not function,
the Battery/
Status indicator
flashes rapidly.
Count the number
of flashes:
10 flashes
An excessive voltage has been applied
to the controller. This is usually caused
by a poor battery connection. Check the
battery packs and controller
connections.
Sorry wasn't sure how much space they give you for answers. :)
Oct 11, 2013 | Health & Beauty
Ultra 3 wiring diagram
the meter is an amp indicator, therefore wired in line with charger, if batteries are charging and meter is not indicating then the meter is bad. if batteries are full then it will move very slightly when batteries are low it moves more
Nov 05, 2012 | Jet Health & Beauty
The (new) batteries indicate from the charger that they are fully charged yet only go for 1 mile before indicator goes 'red".
diane how far did ya used to go with a full charge? Just because the provider said the batteries are new doesn't mean they are new coulda sat on the self for 6 months. New batteries can go bad or in your case probably just one is bad. batteries should be under warranty contact the place you bought them and have them check them for you make sure they are fully charged when they pick them up. Hope this helps
Jan 31, 2011 | Health & Beauty
I bought a gator last christmas 4 my son and only charged battery 6 times fully but now it will not work
most likely it is the shifter switch. Just to check you can exchange the red and blue wires under the pedal(just for a second or so, do not do this permanently) to see if you get power to the wheels, if so then yes it is Definitely only the shifter, but I am still pretty sure it is just the shifter. you can also call Peg Perego Tech support which is excellent and they can help you too 1800-728-2108 and parts can be priced and found at www.mypegperegoparts.com the battery charger should have a led light that will glow green at full charge, and yellow if not charged all of the way.
Sep 25, 2010 | Peg Perego John Deere Gator HPX Ride on...
How long to charge a new ipod touch
Just charge it until the battery indicator indicates that the battery is full. If you want to make sure you properly condition your new battery, charge it for 12-16 hours, even if full. But usually, charging until full is sufficient, and should not take more than 6 hours if new.
Jun 29, 2010 | Apple iPod touch
My suns Quickie P320 (dual battery) requires very
Rapid discharge usually is a sign of weak batteries, and they should be replaced if the charge indicates that they are full after charging for several hours, and then dissipate rapidly.
If your not getting a full charge indication after several hours, then you need to check the charger to make sure it is putting out about 28 Volts DC. If it is, then it is for sure the batt's.
The sweeping lights should not occur when the chair is off the charger. They sweep while on charge to tell you that it is charging and you can't move the chair. If they sweep while off the charger, turn off and restart and it should go. If not, call a tech. rep. for Quickie.
Sep 29, 2009 | Quickie Wheelchairs Health & Beauty
Dell inspiron 2200 green LED battery Indicator flashing
sounds like your charging circuit isn't working or the adapter isn't putting out enough power or amprage to fully charge the battery, or you battery went bad. if the charging circuit is bad then so is *********** board, time to burry the system and buy a new one
Jun 21, 2009 | Dell Inspiron 6000 Notebook
Peg Perego John Deere Gator HPX Ride on Toy Logo
389 people viewed this question
Top Peg Perego Toys Experts
romney2012
Adam Fjeld
Adam Fjeld
Lawrence Oravetz
Are you a Peg Perego Toy Expert? Answer questions, earn points and help others
