Question about Husqvarna 28cc Hand Held Blower HVH 125B
I'm looking to replace the starter spring for my Husqvarna 125B - 28cc hand held. I can't see how to have the spring tight and get the cover back on. I had to replace the starter cord and the starter spring became unwound. Thanks in advance
  • 905 Answers
Here is the gist of my particular method of how to rewind a recoil starter:
1) Remove the recoil assembly housing, don't remove the pulley or disassemble, but remove the old pull rope and the anchor
2) Prepare a replacement rope (based on length of old, melt end with match that goes in housing, etc). Don't put the handle on at this time.
3) The pulley should be "at rest" and not have any tension on it. Slowly rotate the pulley by hand until it become tight.
4) Unwind the pulley until the rope anchor lines up with the rope hole in the recoil housing
5) If able, use a zip tie at this point to secure the pulley from turning. Loop the zip tie through the housing, and anchor it to the pulley somehow. If not able, that is alright, you will just have to maintain tension with your hand
6) Carefully feed the rope through the rope hole, and through the anchor assembly. It makes it easier if the end of the replacement rope is heated with a match to make it smoother and stiffer. Heat the knot with a match as well, to help it hold tighter and longer.
7) Once you have the replacement rope anchored, slowly let the pulley unwind while feeding the rope into it.
8) When there is no more room on the pulley for additional rope, pull the rope back out about 6 inches from the rope hole, and cut so that you now have about 6" of rope hanging out of the recoil housing. Keep maintaining tension on the pulley the entire time.
9) Feed the free end of the rope through the pull handle, and tie the knot around the anchor for the handle
10) You should now be able to let the pulley **** back in the rest of the rope, but make sure that there isn't any rope sticking out of the groove for the pulley. If there is, pull the rope out a bit at a time, and trim it from the handle end. You want the pull handle to be pulled snugly against the rope hole by the tension of the pulley.
11) Reassemble the recoil housing back onto the blower engine, and you are done.
By doing it this way, you are guaranteed to have the longest rope available to pull with. This helps to prevent from pulling on the rope, reaching the end, and stressing the rope anchor and causing the rope to pull out / break prematurely. Manufacturer directions may specify an X amount of pre-loading on the spring, but I have never had a problem with my method. Just be sure to use the same size rope for replacement, don't go bigger or smaller.
Posted on Oct 03, 2010
What screw is L & H on husqvarna leaf blower 125b ?
unit is running lean. The lo is closest to the crankcase. Give the lo a half turn out.
Aug 31, 2014 | Husqvarna 28cc Hand Held Blower HVH 125B
Gas is leaking from husqvarna 125B blower when priming
Either the return line to the tank from the primer has a hole in it, is broke, disconnected; or the diaphragms in the carb are stiff and the unit is flooding
Jul 26, 2014 | Husqvarna 28cc Hand Held Blower HVH 125B
Husqvarna 125b leaf blower
Have you checked the Flame Arrester in the Muffler. They clog easy and engine can't push out exhaust.
Nov 23, 2013 | Husqvarna 28cc Hand Held Blower HVH 125B
How do I replace the recoil spring on my Husqvarna blower
I know the video shows a chainsaw but its the same principle.
Apr 22, 2013 | Husqvarna 28cc Hand Held Blower HVH 125B
How do I get the spring back in my Huaqvarna 125b blower?
you have to wind the spring back in, one coil at a time , its not too easy i would say the best thing is to order a new spring, this will come in a keeper so makes fitting easy.
May 26, 2012 | Husqvarna 28cc Hand Held Blower HVH 125B
I am attempting to remove the vac door cover on a Husqvarna 125B leaf blower. I can see it is hinged and appears to have a catch on the other side of the cover. Problem is that I have tried wedging out...
Hey dumont411........ did you ever get the screen cover off your Husqvarna 125B. I'm having the same problem.
Please email me directly at mrc.engr@verizon.net and not this stupid site.
Thanks !!
Mike Cecchini
Bethesda, Maryland
Oct 23, 2010 | Husqvarna 28cc Hand Held Blower HVH 125B
Husqvarna 28cc Hand Held Blower HVH 125B Logo
593 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
