Question about Sony Cyber-shot DSC-T20 Digital Camera
Problems with sony cyber-shot dsc-t20
I have got the problems initially like flash cannot be changed and also zoom disabled but after configuration of setting it will work but the image quality is too bad and also when i half press my capture button the image displayed (preview) in LCD is poor than the previous view and after capturing the image some what in good quality for small distance object but very bad image quality for distance (only some what) object.Plz help me by giving solution.
I have the same problem as you..
I don't know what is wrong with my camera and Ic ant seem to find the restore button to factory settings. There is nothing in the menu that states this.
For some reason my photos are in really poor pixelated quality even if it is set to the maximum of 8MP. When i take a photo with the flash, the photos return pixelated as though its been taken from a poor 'cell phone camera'
grrr its a really crappy camera.. >_<
It used to be good until this started happening out of no where.
Posted on Sep 04, 2008
  • 10,594 Answers
Kindly initialize your camera from menu and camera will starts with factory default settings.
Posted on May 28, 2008
How do I switch off flash
On this model I think you need to go into the camera menu, navigate to the internal flash setting and disable the auto function. Sometimes these CSC are set to have the flash fire automatically if there is insufficient ambient light.
Oct 03, 2014 | Sony alpha ILCE-5000L 20.1 Megapixel...
Flash: CompactFlash not present I am getting above error when i power on a cisco 1841 router
Did you do anything to the compact flash, like try to format it and copy an image to it? Cisco routers are very picky about the formatting on the flash. It has to be formatted FAT16 and the image has to be the first file on the card.
Jul 24, 2017 | Cisco Computers & Internet
OVERSIZED DISPLAY
You can use iTunes to enable or disable any accessibility feature, including Zoom:
  1. Connect your device to a computer and open iTunes.
  2. Locate and click on the device under Devices:
  3. In the Summary pane, click Configure Universal Access:
  4. Select Neither to disable Zoom:
  5. Click OK and then click Sync to save the changes to your device.
If you do not have access to a computer or iTunes, use the following steps to disable Zoom on the device.
  1. On the Home screen, double-tap with three fingers to exit zoom.
  2. Locate and tap on Settings > General > Accessibility:
  3. Tap Zoom and turn off using the slider:
Jan 29, 2011 | Apple iPhone 3G
My iphone icons are enlarged
If the icons on your Home screen appear too large, the zoom feature may be enabled on your device. use iTunes to enable or disable any accessibility feature, including Zoom:
dmooney_eire.png 4, Select Neither to disable Zoom: dmooney_eire_0.png
  1. Click OK and then click Sync to save the changes to your device.
Jan 14, 2011 | Apple iPhone Smartphone
E:91:01 in DSC-W80
I can't recall all the Sony error codes off the top of my head, but I believe E:91 is that your flash is not working.
Can you take pictures at all or do you get just the error code? If you can take a picture with the flash off then your flash needs to be replaced.
If you can't use the camera you need to first press the reset button, then reset all camera settings to default.
1-3. PROCESS AFTER FIXING FLASH ERROR
When "FLASH error" (Self-diagnosis Code E : 91 : 01) occurs, to prevent any abnormal situation caused by high voltage, setting of the flash is changed automatically to disabling charge and flash setting. After fixing, this setting needs to be deactivated. Flash error code can be initialized by the operations on the HOME screen.
Method for Initializing the Flash Error Code
Initialize
Initializes the setting to the default setting. Even if you execute this function, the images stored in the internal memory are retained.
1 Select [Initialize] with v/V/b/B, then press z. The message "Initialize all settings" appears. 2 Select [OK] with v, then press z. The settings are reset to the default setting.
To cancel the resetting
Select [Cancel] in step 2, then press z.
· Make sure that the power is not disconnected during resetting.
Hope this helps.
Thomas D.
Owner, Darntoothysam com
Affordable Digital Camera Repair
Sep 07, 2009 | Sony Cyber-shot DSC-W50 Digital Camera
Sony cyber-shot dsc-w50 problem
When “FLASH error” (Self-diagnosis Code E : 91 : ** ) occurs, to prevent any abnormal situation caused by high voltage, setting of the
After fixing, this setting needs to be deactivated. Flash error code can be initialized by the operations on the Setup screen.
1 Select [OK] with v on the control button, then press z.
The message “Initialize all settings Ready?” appears.
• Make sure that the power is not disconnected during resetting.
Jul 26, 2009 | Sony Cyber-shot DSC-W50 Digital Camera
How can I disable the zoom on the mouse?
check in control panel for your mouse and click in there should be a way you can change your mouse settings
Jan 17, 2009 | Logitech Cordless Mouse
Sony DSC-P3 Zoom stopped working
i had that same problem. check your image size, the camera cant zoom if the image size is set to 3.1M or 2.8M(3:2)
how to change image size:
turn on camera and leave it in camera mode (picture taking mode)
press the delete/image button
change image size until camera zooms again
VGA gives the biggest zoom range
i hope this helps
it worked on my camera
Jul 27, 2008 | Sony Cyber-Shot DSC-P32 Digital Camera
DSL light flashing constantly
I had the same problem to begin with. Here is what the Zoom helpdesk suggested:
"To force the dsl light to stop blinking, please follow these steps.
1) Open up your web browser and type 10.0.0.2 in the address bar. Type in the the username and password to log in to the modem.
username: admin
password: zoomadsl
2) When you get to the address bar, Click on advance setup.
3) Click on ADSL Configuration.
4) Change the standard to G.Dmt and change the activate line to Start.
5) Save changes and then write settings to flash.
Within a 1 or 2 minutes, the dsl light should go solid."
This worked for me. Good luck.
Mar 24, 2008 | Zoom X6 (5590) DSL Modem (55900003)
Is the DiMAGE A1 equipped with detail zoom function?
Yes, the camera features x2 digital zoom. (Digital zoom does not work in RAW setting) When operate the digital zoom, the imaged size will be changed as follows: Setting image size 2560X1920,2080X1560 and 1600X1200: to 1280X960 Setting image size 640X480: No change
Sep 15, 2005 | Konica Minolta DiMAGE A1 Digital Camera
Sony Cyber-shot  DSC-T20 Digital Camera Logo
130 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
Are you a Sony Camera Expert? Answer questions, earn points and help others
