Question about Maytag Neptune MAH5500B Front Load Washer
Washer will not shut off.
Machine will compleat a full cycle but will not shut down and release the door lock. I have to push the start/stop button to shut it off and wait about 2 min. before the door lock will release. The drum will rotate for one or two rotations then pause for a few seconds. This will continue until I push the stop button.
  • ChengTAGM24 May 27, 2008
    This machine is a Maytag Neptune Mod MAH4000AWW washer.
  • 975 Answers
You need to replace the TIMER MODULE , THATS the main button that you push and pull , hope this helps , AJ
Posted on May 27, 2008
    Sergeant:
  • 154 Answers
May be problem with control .. for how long this problem exists
  • santha ram
    santha ram May 27, 2008
    Initially check the filter on your washing machine
    and clean if necessary, your manual should detail this procedure.
    If your machine will not start or complete the programme, check:
    • The plug, the socket and the switch, if necessary, with another appliance.
    • The fuse in the plug.
    • That the door is closed.
    • That a programme is accurately selected.
    If water will not enter, check:
    • The hot and cold hoses are correctly connected to the relevant
      caps and that these are turned on.
    • That a suitable programme has been selected.
    If water will not drain, check:
    • That the outlet hose is not kinked
      or raised more than 40° from the floor.
    • If you wish to remove articles
      when the water will not pump out, place the end of the drain
      hose into a bucket on the floor and allow water to drain
      out by gravity, noting that more than one bucketful may
      be present. Hook the hose into the sink again and try the
      spinner before removing the articles - if this fails most
      of the water can be baled out with a cup.
    • If the above method fails to remove
      the water then the pump is probably blocked - do not open
      the door, but contact your nearest Service Engineer.
    • check all this sir
  • santha ram
    also make sure the TIMER is proper.. if faulty replace it... thank u sir.. dont forget to rate me.
  • 558 Answers
Sounds like the final phase is not being registered on the timer or the computer chip may need to have a service tech diagnose but it isn't a complex problem just an annoying one, the final phase is a cool down cycle and also you may need to see if you have the settings for cotton clothes, the dryer will tumble them so as not to let them wrinkle. hope this helps
I dont have a stop buttom
You're start/pause button should pause the cycle, cancell should completely cancell. After pressing the Start/Pause within a cycle, the door lock may require time to unlock as indicated by the lock light on the panel.
Apr 11, 2014 | Frigidaire Affinity ATF7000E Front Load...
Door won't unlock and cycle won't start
The interlock has failed most likely. Its a small electronic part that the door catch connects into when you close the machine door. Its tricky to release but can be done. Unplug the machine, remove the lid, put your hand down the front of the machine to where the door catch goes in and fiddle until it releases. It takes a bit of luck when you dont know what your looking for.
May 24, 2010 | Bosch Nexxt 500 Plus WFMC5301UC
Washer won't start cycle after door is closed
Try taking the top of the machine off and checking all of the electrical connections, including the one to the door lock. I have to do this about once a month with my machine and it seems to work.
Jan 20, 2009 | Whirlpool Duet GHW9150P Front Load Washer
500 series washer
Hey try this, open the doo rand oil the door lock mechanism. next turn the machine on and push start/pause button. repeat ,repeat, repeat. if it does not release open round acees door at the bottom of the washer,there should be a manual unloccking pull inside pulldown to unlock(very thin strip of plastic. repeat process. also make sure rubber gasket around tub is secure and flush around washer openig.
Aug 31, 2008 | Bosch 3.81 cu ft WFMC530 1UC Nexxt 500...
Front Loading Duet Washer will not start
You have to set your programme FIRST, then put the "on" switch. Try.
Mar 26, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Door locked open
Tool: We cut a piece a wire about 10 inches long from a wire clothes hanger. On one end we bent 1/2 inch of the wire in a 90 degree angle with needle nose pliers. On the other end of wire we put another bend at least three inches.(this end will be your handle end) Process of using homemade tool to release latch: Make sure washing machine is on a wash cycle. Use flash light to locate latch in the locking catch. Insert the small bend of the tool into the locking catch. Then hook onto the latch and pull out --apply a small amount of pressure -- about three lbs of pressure) Then at the same time you are pulling, press in on the door release button (the little white button above the latch hole where you now have the wire inserted). As your are pulling with little pressure on the latch, hold the little white button in and press the start /stop button. You should hear the door lock. Let machine start working. (about ten seconds) Now push start/stop button again and you should hear door lock release. Your lock catch should give away. This worked for us.
Feb 11, 2007 | Bosch Nexxt Premium WFMC6400UC Front Load...
Whirlpool Duet Front Loading Washer Won't Turn On
mains filter blown door lock fail main pcd fail appliance doctor
Jan 28, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Problem with washing machine
New door sensor im afraid,unless the machine senses that the door is properly shut none of your wash or spin cycles will start.Sensor located inside washer casing , where lock pin on door handle enters machine.It may just be loose,try tightening the two screws either side of lock keep.If it needs replacing you will need to UNPLUG washer ,remove lid and slide your arm down inside front of washer to access.Good luck.
Oct 23, 2006 | Zanussi FLE1416W Front Load Washer
Maytag Neptune MAH5500B Front Load Washer Logo
44 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
