Question about Krups BeerTender B95 Beverage Dispenser
My beertender stopped cooling my keg. what can I do to fix it?
  • 3 Answers
Wondering if you found a solution to this yet. Mine stopped cooling, too.
Posted on Nov 03, 2010
  • ChicagoRod Jan 27, 2011
    I found a new peltier plate on Ebay for about $6. Supposedly they do go bad and are easy to change. They are located under the fan, under the heat sink (silver thing with fins for cooling). TEC-12705 is the part number.
I do not have any cooling or display. no power, plug is good.
Posted on Apr 03, 2011
  • Pete Mote
    Pete Mote Feb 09, 2012
    Shake your fist at the sky then replace the SMPS output caps. mastecutor@gmail.com
Beertender b90 level indicator flashing. Cooling indicator is working fine and and the temp is 42 degrees.
42 deg is too warm for beer keg it should be 32 deg possible a warning temp too high
Nov 20, 2013 | Refrigerators
Where can I purchase tubes for my beertender B90 in the UK. How do I find out the product code so I can order as there are several differert types on Amazon.
As you have discovered, it is impossible to buy tubes in the UK. They can be ordered from the USA but they cost a fortune and the shipping fees are terrible. The best solution I have found is as follows: Log onto www.eBay.co.uk and enter Beertender tubes into their search engine. Scroll down the first page of the results and at the bottom right hand side select the link (see all matching items from international sellers). Scroll down the results and about the 4th one down is a French retailer selling 30 tubes for 10 pounds. OK, so they charge 20 pounds postage but if you buy 2 X 30 tubes, they postage is about 24 pounds - 60 tubes for a cost of 44 pounds. It is possible to reuse the tubes a few times - make sure the pressure is thoroughly expended and gently prise the tube from the keg. But, hey, I don't really see the point if all it costs is 8p for a new tube per keg. Bottoms up From Dogmanbrian
Jun 19, 2013 | Krups Beertender from heineken and b90...
Krups Beertender VB5028CT (C75) totally dead now.
I had one that appeared totally dead and replaced four capacitors (~$5 to buy) and it's back up and running. If you pull the back of the unit and remove the unit attached to the power cord you'll see a pcb board. Look for any capacitors that look kind of rounded on the top (they should be flat). On mine it was a cluster of one 470 uF and three 1000 uf capacitors. Desolder those and solder in new ones. Mine were rated at 16 volts but I replaced them with 25 volt units for a bit more safety margin.
Jan 11, 2013 | Krups C75 Beertender Home Beer-tap System...
Krups beertender not cooling
Replace the capacitors in the power supply circuit 880 and 470 mikrofarada.
Dec 24, 2012 | Krups BeerTender B95 Beverage Dispenser
Turned beertender off to change kegs. No it will not turn back on....
The plastic switch on the side is very whimpy. it's either disconnected from the toggle switch on the PCB board. Fiarly simple to verify that. If that is nt it. Your peltier thermalelectric
plate may have gone bad and the beertender may be in a current limit shutdown state. you can verify this by disconnecting the peltier plate from the board. You should do this with the tender not plugged in. mastecutor@gmail.com
cost of plate is only $5 dollars.
Aug 30, 2010 | Krups BeerTender B95 Beverage Dispenser
I have a danby kegerator and i just tap the keg and all its doing is spitting air with some foam and i tasted the beer it was completly flat i need help asap!!!
try changing kegs sounds like the tube in the keg is broken the keg has a tube that runs to the bottom of the keg inside and u push air into the keg to push beer thru that tube and into a cool glass and down to ur gulletbut it sounds like u have a defective keg or an empty keg
Feb 24, 2010 | Danby DKC646BLS Full Size / Pony Beer Keg...
Display for Krups Beertender stopped working
unplug the unit for 30 seconds, then plug back in. I had this problem, and it is a solution to most modern electronic devices. it reboots the system.
Jan 17, 2009 | Coffee Makers & Espresso Machines
Krups BeerTender B95 Beverage Dispenser Logo
3,334 people viewed this question
Top Krups Refrigerators Experts
Tom Chichester
Terry Hair
JonSnell Electronic
JonSnell Electronic
Are you a Krups Refrigerator Expert? Answer questions, earn points and help others
