Question about Whirlpool 30" Self-Cleaning Freestanding Electric Range - White-on-White
I need to replace the light bulb in my whirlpool self-cleaning oven but I can not remove the glass cover. How do I remove it?
    Genius:
  • 1,416 Answers
Here is a solution to go about the glass bellow
Removing your microwave door allows you to quickly clean out any accumulated food or grease. This also makes it easy to get to all the crumbs and debris around the door hinges. While you have the door off its hinges, examine the plastic panel and glass window for signs of damage. Make sure you install a replacement door that is designed for your brand of microwave to ensure that it will fit correctly.
  • Remove the power cord from the electrical outlet and move your microwave onto a workbench or sturdy table. For cabinet-mounted microwaves, pry off the decorative grills or front panels and remove the mounting screws. You should then be able to slide the microwave out of its mounting bracket.
  • 2 Open the microwave door and remove the glass tray. Use a flathead screwdriver or putty knife to pry off the plastic cover on the inside of the door. Work around the edge of the glass until the cover slips free.
  • 3 Remove the door by pulling the mounting pins out of the hinges at the top and bottom. You may need an assistant to steady the door so you can have both hands free to work with the pins.
  • hope this solution help?
    Thanks for visiting fixya.
    Posted on Oct 03, 2010
    How do I change the bulb inside the cooker of the B5741 cooker
    Oven Lighting
    Warning: There is a danger of electric shock! Prior to changing
    the oven light bulb:
    • Switch off the oven!
    • Disconnect from the electricity supply.
    Place a cloth on the oven floor to protect the oven light and glass cover.
    Replacing the oven light bulb/cleaning the glass cover
    1. Remove the glass cover by turning it anticlockwise and then clean it.
    2. If necessary:
    Replace bulb with a 40 watt, 230 V, 300 °C heat-resistant
    oven light bulb.
    3. Refit the glass cover.
    Dado
    Apr 15, 2015 | AEG Ovens
    How do you change the oven lightbulb?
    Most require 2 screws to be removed to lift the glass cover from over the bulb. Then simply unscrew the bulb and insert new bulb. A 1/4" nut driver is the best tool for the job.
    Sep 08, 2014 | Whirlpool 30" Self-Cleaning Freestanding...
    HOW TO REPLACE THE LIGHT BULB IN MY OVEN
    Oven Lighting
    Warning: Risk of electric shock! Prior to changing the oven light bulb:
    - Switch off the oven!
    - Disconnect from the electricity supply.
    Changing the oven light bulb/cleaning the glass cover
    1.Remove the glass cover by turning it anti-clockwise and then clean it.
    2.If necessary: replace with 25 watt, 230 V, 300 °C heat-resistant oven lighting.
    3.Refit the glass cover.
    24472822-skr3uzd4ii43xzwyhmpsswym-3-0.jpg Dado
    May 21, 2014 | Electrolux EOB5665G Ultrafan Electric...
    Oven light glass cover will not come off. Need to replace bulb.
    Easy, go to the garage and get the tool kit. Inside is a device called a hammer. Take the device in your right hand if you are right handed, lift in a backward fashion and thrust forward against the glass cover. Now it will come off.
    Oct 26, 2013 | Whirlpool 30" Self-Cleaning Freestanding...
    Replace light in KEMC378KSS microwave
    The oven lights are 12-volt, 5-watt maximum halogen bulbs. They
    will come on when the oven door is opened. On double oven
    models, both upper and lower lights will come on when either
    door is opened. The oven lights will not work during the Self-
    Cleaning cycle. When the oven door is closed, press OVEN
    LIGHT to turn them on or off.
    To Replace:
    Before replacing, make sure the oven is off and cool.
    1. Disconnect power.
    2. Remove glass light cover by grasping the front edge and
    pulling away from oven
    3. Remove bulb from socket.
    4. Replace bulb, replace bulb cover by snapping back into wall.
    5. Reconnect power.
    Feb 04, 2013 | KitchenAid KEMC378KSS Electric Double Oven
    How to change oven light
    Which model Whirlpool range do you have? For most Whirlpool ranges that I have used , the oven light is covered by a screw-on glass cover. When the oven is cool, unplug the range, open the door and turn the cover counter-clockwise (to the left). Then remove the 40W bulb (again counter-clockwise rotation). Replace the bulb with another 40W appliance bulb. Then replace the cover by turning it clockwise until it is tight. Do not over-tighten either the bulb or the cover. Then plug in the power cord for the range. (Unplugging the unit makes sure that you will not get shocked if anything goes wrong. Sometimes the bulb may break in the socket - in that case, use pliers to unscrew the base of the bulb before replacing it with a new bulb.)
    Whirlpool has the manuals for most of their appliances on their support site: https://www.whirlpool.com/webapp/wcs/stores/servlet/OCManualsLiteratureSearchView?catalogId=10561&langId=-1&storeId=10211&krypto=5QgxQhneFliXuEuX564wSQ%3D%3D&ddkey=http:OCManualsLiteratureSearchView .
    I hope this helps.
    Jan 11, 2012 | Whirlpool 30" Self-Cleaning Freestanding...
    How do I remove the glass cover to replace the light bulb
    Hello, Thank You for using FixYa. I will be helping you today.If its stuck spray some pam around the base of the glass wipe up any over spray and turn the oven on 200 degrees for about 20min. let it cool and try to turn the glass cover.
    Thank You and please rate my answer if it was helpful..
    Jun 16, 2011 | Whirlpool 30" Self-Cleaning Freestanding...
    Can not remove light bulb from whirlpool oven
    I had similar difficulty. This worked for me after 45 mins grief.
    I got a heavy duty 1cm wide elastic band (length double was about 14-15cm). This is a common size heavy duty elastic band in the UK.
    This elastic band is much too long to go around the glass bulb cover so I tied a knot in it so that i had a complete circle of rubber band tightly held around the bulb cover. Then I used a Mole wrench -a kind of large adjustable spanner - to undo the glass bulb cover. It came off easily because the rubber band gave sufficient grip to undo it. It is about 2.5 full turns anticlockwise to completely free it.
    I hope this will help the next viewer of this website.
    Geoff
    Aug 11, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
    Oven
    Pry back the bulb glass cover wire spring and remove glass cover. Use heavy rubber gloves or a plastic bottle opener(piece of serrated soft plastic/rubber) and unscrew counterclockwise.
    Mar 05, 2007 | Whirlpool GBS277PR Electric Single Oven
    Whirlpool 30" Self-Cleaning Freestanding Electric Range - White-on-White Logo
    279 people viewed this question
    Top Whirlpool Ovens Experts
    Dan Webster
    Dan Webster
     Fix Your Board
    Fix Your Board
    ashburton
    Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
