Question about Kenmore HE2 Plus Front Load Washer
Kenmore HE2 washer will not spin or drain. Water left in washer..
    Genius:
  • 1,416 Answers
There are several reasons that a washing machine won't drain or spin. The cause could be something as easy as a clog or something difficult that will need a licensed repairman. Start with the simplest possible cause and work down to the more difficult causes.
INSTRUCTION BELOW
  • A washing machine won't spin if the water can't drain. Check hoses for any kinks or clogs that may prevent the water from draining. If a hose has kinks, try to straighten out the kinked hose. If it can't be straighten sufficiently, replace the hose. If hoses are not kinked, check for clogged hoses. This can be done by using the screwdrivers to remove the hoses and looking for clogs or running a water hose through the clogged hose to remove the clog. Use the rags and bucket to clean up the water that comes out of the hoses when they are disconnected. Once the clog is cleared, put the drain hose back into place. The washer should drain and spin now if a clogged or kinked hose was the problem.
  • 2 If the washer still won't drain or spin, check to see if the lid is not closing all the way or if the lid switch is not clicking into place. Close the lid and make sure that it closes all the way down. When the lid closes, the lid switch should click. If there is no clicking sound, then the switch may need to be replaced. Follow manufacturer's directions for replacing the switch. If the lid does not close all the way, visually check for signs that the lid is bent. If bent, try to bend it back into place.
  • 3 Loose or broken belts could also prevent a washing machine from draining or spinning. Pull the washer away from the wall and, using the screwdrivers and wrenches, remove the back panel. Using the flashlight, visually check for any broken or loose belts. Replace any broken or loose belts. Although replacing washing machine belts is difficult, anyone who has replaced belts on a car, lawn mower or even a bicycle chain should be able to accomplish the task.
  • 4 Another possibility for a washing machine to not spin or drain is the pump. With the back panel still off the washer, check the pump with the voltmeter to ensure that the pump is getting power. If the washer is getting power, turn on the washer and listen to find out if the pump is running but the water is still not draining. It may be necessary to remove the pump and clean it or to replace the pump with a new one. Once the pump is replaced, turn on the washer to determine if it will now drain and spin.
  • 5 If all of the above steps fail to produce a washing machine that drains or spins, then it is time to call a professional repairman. Use the screwdrivers and wrenches to replace the panel on the washer and push it back against the wall
  • thanks and good luck.
    Posted on Oct 03, 2010
    3 Suggested Answers
    kvhappliance
    • 218 Answers
    SOURCE: Washer is Kenmore He2 model # 110.46462501
    It sounds like you have something stuck in the pump.
    To repair
    Unplug machine.
    Remove bottom front panel(remove 2-3 screws in the bottom) Pull bottom of panel out and down to remove.
    Towards the center bottom you will see the pump. On the front is a round thing that resembles a filter. This is the pump filter screen...Get a shallow pan to put under screen. Turn lid counter clockwise to remove(turn slowly and allow water to drain. As you may need to dump pan several times before all water is drained out. Be carful or you could end up with water everywhere. Once the water is drained pull out screen and remove the debris and objects stuck in screen and filter housing you should also be able to see the impeller on the pump inspect for debris. Once everything is cleaned out reverse removal procedures put back together.
    Posted on Mar 22, 2010
    blueextc3221
    • 15935 Answers
    SOURCE: My Kenmore HE2 Front load washer will not drain, displays F-33
    The F33 error code indicates a pump drive system error. If the pump ohms out correctly & the harness is secure I recommend replacing the CCU (central control unit).
    Please see the following image provided for instructions.
    http://media.fotki.com/1_p,stwwfrggtqfbrbbxgtqsskgwtqkq,vi/wgtbwqwssxsbwkbdtfwxrbfbddwwf/1/1303472/5961857/image9159087223444281043img-or.jpg
    Remember to disconnect power to the washer before attempting access.
    This is an indication of a door latch failure and/or interconnecting wiring problem. The first step in troubleshooting the problem is to unplug the washer for AT LEAST 30 minutes in an attempt to reset the Central Control Unit (CCU). This is the main "brain" of your washing machine. Sometimes these error codes are erroneous and can be easily cleared by resetting the CCU. If the error code reappears following a CCU reset, then you have a genuine problem. In addition, if the door latch remains locked following this procedure, there is a manual release you can use to open the door. Follow these steps:
    1. Remove the lower panel under the door by loosening the three screws under the bottom edge on the front of the washer. HINT: If you prop up the front feet of the washer with a 2 x 4, it makes access to the screws much easier.
    2. With the screws removed, the lower panel should drop down then come off. If the panel sticks, a light tap on either side will knock it loose.
    3. Reach your hand up inside the washer behind the front casing on the right-hand side. This is where the door latch assembly is located.
    4. At the bottom of the door latch assembly is a small pull tab. This is the manual release for the door. Pull the tab straight down and the door will come open.
    If you still have the error code displayed, inspect the door latch mechanism for any broken, loose, or missing components. Next, open the top panel of the washer by removing the three screws in the rear of the washer that hold the panel in place. With the screws removed, the panel will slide back, then off. Locate the door latch on the right hand side behind the front panel. Inspect the wiring harness from the door latch to the to CCU. The CCU is located directly behind the wash tub in the top rear of the washer. Make sure all the connectors are snug and not loose or broken. In the majority of cases, a persistent error is a failed door latch. If all these preliminary checks are unsuccessful, replace the door latch. Follow these steps:
    1. Unplug washer.
    2. Remove the outer portion of the door bellow. This is the gray rubber boot around the door. Feel around the edge of the door bellow where it attaches to the front of the washer. You will find a wire retaining hoop in the seam between the rubber and the front case. Follow this wire hoop to the bottom of the door bellow and you will find a tension spring. Carefully, stretch this spring apart and remove the wire hoop.
    3. Pull the rubber bellow from the door facing on the front of the washer being careful not to rip or tear it. Once removed, fold the rubber backwards inside the drum so you can access behind the front panel. DO NOT remove the rubber bellow from the wash tub.
    4. The door latch assembly is located behind the front panel of the washer on the right hand side. Locate and remove the three screws on the washer front that hold the door latch assembly in place. The whole assembly should come free from the washer front and be held by a plastic mounting bracket and several wire connectors.
    5. Carefully remove the latch assembly from the plastic mounting bracket BEFORE attempting to unplug any wires. It makes it much easier to access if you do.
    6. Unplug the wire connectors using care not to break any of the wires. You may want to write them down, but I believe they will only plug into their respective slots.
    7. Remove the old door latch and install the new one in the reverse order of the steps I just presented to you. Plug the wires back in first, then place the whole assembly back into the plastic mounting bracket, and then reattach to the front of the washer.
    8. Now, when you get the reinstalling the rubber door boot, you may want to get the assistance of a second pair of hands as it can be difficult sometimes to manipulate the wire retainer back into place. Carefully reattach the rubber bellow to the door facing on the front of the washer first.
    9. Starting at the top of the door bellow at the 12 o'clock position begin inserting the wire hoop back into the groove. Work your way around with both hands to the 4 and 8 o'clock positions. (This is where you could use those second pair of hands). While holding a slight downward tension on the wire hoop to keep it in place, pull the tension spring apart enough to snap the remaining part of the hoop into place at the bottom. Once you've completed these steps make sure the door closes and latches properly. NEVER slam a door with an electronic latch. They can break easily.
    NOTE: Another method is to access behind the front panel from the top with the top panel removed. Either method works, but I have found that going through the front offers better access.
    Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
    Posted on Sep 12, 2010
    I have a Kenmore HE 2plus front load washer and during any wash cycle the drum won't spin and at end of cycle displays F01
    Front-loading washer Kenmore HE2 plus - spinning not ...
    www.shopyourway.com > Manage My Life > Questions
    My Kenmore HE2 plus washer has problems with spin funciton. almost all of the ... or twins size blanket, it just won't spin, even with extra spin cycle only. ... Check to see if the washer will spin without any clothes at all in the basket. ... My HE2 will wash a very small load. ... Any bigger loads The drum will try and turn but wont.
    Front Load Washer Won't Drain or Spin Video: Washing ...
    ? 1:54
    https://www.youtube.com/watch?v=wlMoT9rgvAg
    Jun 1, 2012 - Uploaded by searspartsdirect
    ... won't drain or spin. For more front load washing machineinformation and repai. ... If the cycle has completed and water is still left in the machine select "Drain and Spin" to remove anywater remaining in the washer. This can be caused .... I have aKenmore HE2 plus front load washer. I can't seem to get it ...
    Kenmore HE2 Plus 3.6 cu. ft. Front-Load Super Capacity ...
    www.kenmore.com > Laundry > Washers > Front-load Washers
    KenmoreFront-Load Super Capacity Washing Machine (4753) .... super wet, and to spin the empty drum after each load to hear if anything was caught in that gap. .... 1st of all: You cannot use any other detergent than HE rated detergent - PERIOD. ... will create too many suds and clog up the machine, and the clothes won't be clean.
    Jan 15, 2016 | Kenmore Washing Machines
    My he2 kenmore clothes washer does not go into spin cycle
    Problems with a washing machine not spinning or not draining are often inter related..
    If you are having a problem with your top load washer then check out this tip...
    Washing Machine does not Pump or Spin
    If you are having problems with your front load washing machine then checkout this tip...
    Front Load Washing machine not draining and or not spinning
    heatman101
    Sep 08, 2010 | Kenmore HE2 Plus Front Load Washer
    My Kenmore He2 at the end of wash my clothes are still heavy with water and a f01 code is flashing
    Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
    heatman101
    My kenmore front loader does not go into the spin cyclr and water is left in the drum
    Most likely either the drain pump or hose is clogged or perhaps the drain pump is not working. Machine will not spin with water still in the drum.. Check all connections.
    Mar 12, 2010 | Kenmore HE2 Plus Front Load Washer
    My kenmore he washer will not drain all the water also have code E20 flashing
    2 Beeps/E20--Error: Water dosen't drain. Cause: Drain is kinked or household clog. Correct.
    3 Beeps/E30--Error: Drum overfilled. Cause: Inlet valve,pressure switch or control board failure.Select drain/spin to remove water. Restart.
    Feb 16, 2010 | Kenmore HE2 Plus Front Load Washer
    Kenmore HE2 front load washer that does not drain and spin well. It does drain and spin sometimes though, so nothing is preventing from doing that. The service tech replaced the pump, but he could not fix...
    Some how there is debris like socks or something small getting down and blocking your drain plug. take the bottom panel off your machine by removing the 3 (1/4") screws at the very bottom of your washer. once the panel is removed you'll see a 1 1/2" PVC white valve plug. open that by turning it to the left untill open (WARNING ALL THE WATER WILL DRAIN OUT THOUGH THIS PLUG) remove debris and you all set.
    Jan 19, 2010 | Kenmore HE2 Plus Front Load Washer
    Water will not drain, drumb won't spin
    check water pump for faults and or blockage it will not spin as there is to much water inside once it has drained it should spin this is a safety feature
    Jan 15, 2010 | Kenmore HE2 Plus Front Load Washer
    Kenmore HE2 won't finish spin cycle
    you have blockage in you drain plug. to solve this problem you'll have to remove the lower front panel of your machine by removing the 3 (1/4") screws on the vary bottom of the machine. once the panel is removed you'll see a 1 1/2" white PVC drainage plug. turn the inner plug to the left in till open. (WARNING ALL THE WATER IN THE DRUM WILL DRAIN THOUGH THIS PLUG) remove debris likes socks or everything that's there replace the panel and your all set.
    May 28, 2009 | Kenmore HE2 Plus Front Load Washer
    Will not spin or drain
    take front panel off in the water pump rubber hose feel to see u can feelsomething in side the pump .this will cause the pump to stop/and not spin
    May 12, 2009 | Kenmore HE2 Plus Front Load Washer
    Kenmore HE2 Plus Front Load Washer Logo
    758 people viewed this question
    Sal DeAngelo
    fordexpert
     Brian Main
    Brian Main
