Question about Sylvania SMPK4077 Digital Media Player
When I connect the MP3 Player to the computer using the ISB cable, I get the message from Windows that the device has malfunctioned and it is not recognized. I appear to have the correct drivers. The music player does function ok but I am unable to load more music to the player
  • 10,421 Answers
When i plug in my Transonic MP4 player a pop up box comes up which says that "USB device not recognised". It then tells me that one of the USB devices has malfunctioned and windows does not...
MP3 players use the popular USB connection which sometimes produces errors while connecting. These messages are similar to the "Device Not Recognized" error received with various USB devices. Fixing an MP3 player is sometimes specific to the brand, but they are so similar that most can be fixed the same troubleshooting steps.
Instructions
Device Manager
Click "Start" and go to "Control Panel." Double-click "System" and locate the Hardware tab to find the Device Manager. Vista and Windows 7 users can just type "Device Manager' from the start menu.
Locate "Disk Drives" from the list and double-click "Portable Device." If there is an exclamation mark or other error on the device, go to the "Drivers" tab.
Click "Uninstall" and remove the player. Restart the computer and attach the player reinstall the drivers.
Anti-virus conflicts
Plug the player into a different computer to see if it gets recognized. If it does not, contact the manufacturer to find out if it is broken.
Turn off your anti-virus program on your PC if the device works on other computers. Reinstall the drivers using the device manager as described in section 1.
Plug in the player to confirm the connection.
Other solutions
Check the battery level and make sure the batter is not low or depleted. A low battery will sometimes prevent the player from connecting. Let it charge from the power cord, if necessary.
Verify that you have at least Service Pack 1 installed. Go to the Start menu and type "Run." Press Enter.
Type "Winver" in the box and press "Enter." The Windows version will be displayed along with any installed service packs. Download a service pack from Microsoft, if applicable.
Remove the player from the USB port and push a pin into the reset hole located on the bottom. Reconnect to see if the problem is resolved.
Check the connection to make sure it's secure. The cable should fit firmly into both the player and the computer. Connect to a different USB port if you have one available.
Download updated firmware or use the MP3 Recovery Tool provided under Resources (for Zen players).
Tips & Warnings
A bad cable will sometimes prevent a good connection. Use a different one to isolate the cause.
May 22, 2011 | Audio Players & Recorders
I have go gogear 4gb have a long charging cable and i put it in the computer wont regonize\no pop up windows?
Instructions
Device Manager
Other solutions
Download updated firmware or use the MP3 Recovery Tool provided under Resources (for mp3 players).
Tips & Warnings
May 13, 2011 | Philips GoGear SA5285/37 Digital Media...
USB Port Not Recognized
Here Two Reason for USB Port Not Recognized:
1. Check you USB cable properly connected to the you computer, If cable break or not connected properly, It will show your cable not recognized.
2. If again these problem shows. go to,
My Computer - right click - Properties - Hardware - Device Manager - and Unistall you USB drivers - then again scan new hardware.
Jan 29, 2010 | Emerson BAR900 MP3 Player
My GPX player, model number MW259BU, will not work. When I plug it into the USB port, Windows gives me a message that it is not recognized and the device is malfunctioned. I updated Windows Media Player...
try
these steps:
1.plug your pen drive in your computer.
2.then open Control panel.
3. open administrative tools.
4.open Computer Management
5. a window label computer management will appear.
6. click disk management
7.locate you pendrive and select delete partition or format it fat 32 or other format convenient for your usage.
ok
hope this will help
cheers
uttam
Jan 21, 2010 | GPX MW3837 MP3 Player
Computer does not recognize Coby MP822 4G MP3 player
The actual MP3 player should display a USB connection on the screen, if not, I would say its a connection issue (bad USB cable), my guess is your using a laptop, a lot of laptops disable their USB power options, you probably need to re-enable your USB ports, if desktop, it should show a USB connection on MP3, if not, battery or cable issue.
Sep 13, 2009 | Audio Players & Recorders
Mp3 player malfunction
1. Connect the player to the PC using the USB cable.
2. Open Windows Media Player.
3. Go to the Sync or Devices tab and delete all content from the player.
4. Go to the Tools menu and select Options.
5. Select the Devices tab, highlight the ILO or Siren player and click on Properties.
6. Uncheck the box "Create Folder Hierarchy on Device"
Sep 11, 2008 | iLO (2 GB) MP3 Player
When i plug in my external hard drive to my computer a message comes up saying the device has malfunctioned and windows does not recognize it. reconnecting the device and changing the port is not changing...
I had the same problem with an MP3 player once. What causes it is the connection between the Pc and The ext Hdd. What you need to do is either find another plug for the hdd, dont replace the hardrive just the USb cable, or muck about with the cord untill your computer notices it
Sep 07, 2008 | Computers & Internet
Windows not recognised
Press and hold the lower volume button and plug it in to the computer simultaneously and keep holding the minus button until a box appears where the message of usb device malfunctioned and click on it. Then follow the instructions and it should be recognized.
Jul 11, 2008 | SanDisk Sansa MP3 Player
USB Malfunction
oh God. I have the same problem. but my grandparents got it for me, so i can't find the courage to throw it away. too much sentimental value. see, i put Rockbox on it. it was working fine for a while. this sucks. the good thing - you can copy/cut/paste/delete/move....etc. with Rockbox. so i just put the music on the microSD through the computer, then put it into the player and cut/paste.
Mar 03, 2008 | SanDisk Sansa e250 MP3 Player
Sylvania SMPK4077 Digital Media Player Logo
94 people viewed this question
Top Sylvania Audio Players & Recorders Experts
David Payne
David Payne
Tre Elkins
Are you a Sylvania Audio Player and Recorder Expert? Answer questions, earn points and help others
