I have a kenmnore 80 series electric washing machine. It does not seem to spin properly. sometimes it will not spin, other times it spins weak. I set it on spin cycle last weekend and had to manually spin the tub to get it started.
    Genius:
  • 1,417 Answers
There are several reasons that a washing machine won't drain or spin. The cause could be something as easy as a clog or something difficult that will need a licensed repairman. Start with the simplest possible cause and work down to the more difficult causes.
INSTRUCTION BELOW
  • A washing machine won't spin if the water can't drain. Check hoses for any kinks or clogs that may prevent the water from draining. If a hose has kinks, try to straighten out the kinked hose. If it can't be straighten sufficiently, replace the hose. If hoses are not kinked, check for clogged hoses. This can be done by using the screwdrivers to remove the hoses and looking for clogs or running a water hose through the clogged hose to remove the clog. Use the rags and bucket to clean up the water that comes out of the hoses when they are disconnected. Once the clog is cleared, put the drain hose back into place. The washer should drain and spin now if a clogged or kinked hose was the problem.
  • 2 If the washer still won't drain or spin, check to see if the lid is not closing all the way or if the lid switch is not clicking into place. Close the lid and make sure that it closes all the way down. When the lid closes, the lid switch should click. If there is no clicking sound, then the switch may need to be replaced. Follow manufacturer's directions for replacing the switch. If the lid does not close all the way, visually check for signs that the lid is bent. If bent, try to bend it back into place.
  • 3 Loose or broken belts could also prevent a washing machine from draining or spinning. Pull the washer away from the wall and, using the screwdrivers and wrenches, remove the back panel. Using the flashlight, visually check for any broken or loose belts. Replace any broken or loose belts. Although replacing washing machine belts is difficult, anyone who has replaced belts on a car, lawn mower or even a bicycle chain should be able to accomplish the task.
  • 4 Another possibility for a washing machine to not spin or drain is the pump. With the back panel still off the washer, check the pump with the voltmeter to ensure that the pump is getting power. If the washer is getting power, turn on the washer and listen to find out if the pump is running but the water is still not draining. It may be necessary to remove the pump and clean it or to replace the pump with a new one. Once the pump is replaced, turn on the washer to determine if it will now drain and spin.
  • 5 If all of the above steps fail to produce a washing machine that drains or spins, then it is time to call a professional repairman. Use the screwdrivers and wrenches to replace the panel on the washer and push it back against the wall
  • rate this.
    thank you and thanks for using fixya.
    Posted on Oct 03, 2010
    My kenmore 80 series washing machine will not always drain out on the spin cycle and sometimes when it does there is dirt in the tub under the clothes. why?
    Problems with a washing machine not spinning or not draining are often interrelated..
    If you are having a problem with your top load washer then check out thistip...
    Washing Machine does not Pump or Spin
    If you are having problems with your front load washing machine then checkoutthis tip...
    Front Load Washing machine not draining and or not spinning
    heatman101
    Apr 02, 2011 | Washing Machines
    Kenmore 80 series washing machine model stopped spinning
    Check this out acc8ce4.jpgmight be a partially defective coupling or lid switch. More HERE
    Mar 21, 2010 | Kenmore Washing Machines
    Kenmore 80 series not agitating or spinning,making racheting soun
    You have a broken coupling that links the motor and transmission. Call around your area for estimates. It is a pretty straight forward job so most technicians should be able to give you an estimate over the phone. Most likely between $150.00 and $200.00.
    Aug 01, 2009 | Washing Machines
    Kenmore 80 series makes noise in sping cycle
    Its the transmission. Try to find a used appliance store in your town. Most save used parts and you should be able to pick up a used tranny for around 100 bucks.
    Nov 14, 2008 | Kenmore 24032\24036 Top Load Washer
    Kenmore washer 80 series 4 years old
    my washing machine is not rinsing and spinning
    Jan 20, 2008 | Kenmore 24032\24036 Top Load Washer
    Kenmore washer 80 series 4 years old has prob
    You may not have the coupling seated properly. However, if the unit is agitating and spinning at the same time, you may have a more serious transmission problem.
    Washing Machines Logo
    23 people viewed this question
    Top Washing Machines Experts
