Question about Ovens
Turn on oven cleaning, but clean indicator stops after few seconds
    Genius:
  • 1,416 Answers
Hello
what this need is to set the reprograms
here are solution below
You can set the timer on a Corning ware slow cooker to automatically switch to a warming setting when you estimate Foods will finish Cooking The programmable features allow you to leave food stewing at home while you are out of the house, freeing up your day. Set the timer on a Corningware slow cooker to let the kitchen appliance do all the Work, and come home to a fully cooked meal.
  • Fill the insert of the Corning ware slow cooker with food and cover it with the lid. At least a quarter of the insert should be filled with liquid to keep the environment moist during long cooking times.
  • 2 Press the "On/Off" button on the left side of the electronic control panel in the front of the appliance. This will turn on the slow cooker to the low heat "Warm" setting.
  • 3 Press the "Cook Time" button on the right side of the electronic control panel to add hours to the timer which will show a total time in hours with a red digital display. Continue to press the button until the display indicates the desired cook time in one-hour increments up to 10 hours. The cooker will automatically adjust the temperature setting based on the amount of time you programmed on the timer. Cooking times of six hours or less automatically start on "High" heat and times of seven hours or more will start on "Low" heat. A small indicator light will come on below the word to tell you the cooking temperature.
  • hope this hope ?
    thanks
    Posted on Oct 03, 2010
    2 Suggested Answers
    rylee_smith
    • 8619 Answers
    SOURCE: My GE wall oven model
    Hi
    Thanks for using FixYa. It seems that you interrupted the self clean cycle in between or you ran the self cleaning cycle after a long time, as these kind of issues are usually caused due to these reasons. The issue is with the latch assembly going bad and should be replaced. Please accept the solution if the issue is resolved or post a comment for further assistance.
    Thanks
    Rylee
    Posted on Oct 13, 2010
    My oven fan has recently started to make a very loud rattling noise for around 30 seconds once every few minutes while the oven is turned on in fan mode.
    The fan needs be cleaned and lubricated. To do this: Turn off stove/oven. Remove fan cover plate. Remove fan. Clean and lubricate the shaft bearings with 3 way oil. Install fan and cover plate.
    May 16, 2016 | Smeg Ovens
    How do I turn off?
    Just open the oven door and you'll see a button that the door actually pushes against... with your finger hold the button in and turn the oven on to the self clean cycle... While still holding the button wait a few seconds and then turn the self cleaning cycle off, this should disengage the door latch... Always keep the button engaged until the self clean cycle is off...
    Mar 25, 2013 | Ovens
    F5e1 error code
    The F5 E1 error message indicates the latch motor was unable to lock the door. When the self clean cycle is started, the control board will turn on the latch motor which is mounted on the rear of this range. The motor is connected to a cam that transfers the motors motion to a rod that runs under the cooktop. This rod connects to the actual latch mounted behind the oven door. The control board will then monitor a position switch that is actuated by the latch motor cam. As the motor rotates, the latch will engage the door locking it in place just as the cam contacts the switch button. When the switch contacts close, the control turns the latch motor off and starts the cleaning cycle.
    When diagnosing this failure, the error code gives us a good starting point to begin our trouble shooting. I removed the rear panel and started a clean cycle. Once the start button was pressed, the latch motor began to rotate, but didn't stop at the locked position. It continued to rotate three times and then displayed the error. I unplugged the range from the wall and using my meter, did a continuity check of the latch position switch (the one on the right). The switch was reading as an open circuit in standby and when I actuated the switch which tells me the switch has failed. The second switch on the latch assembly, by the way, is to turn the oven light off during the self cleaning cycle to protect the bulb. That way, if you leave the light switch on the control panel turned to the on position, that second switch will turn it back off. Good to know if you can't figure out why the oven light won't turn on.
    With the failure down to the latch assembly, I checked the range parts to see if the switch came as a separate piece, but it looks like it's an entire assembly, and not individual parts. I removed the old latch after removing the two screws and six wires, then installed the new latchshow?id=y6f3ez5blva&bids=92089.709229668&type=10&subid=. Once all the wires were back connected to the proper terminals, I put the rear panel back on and plugged the range back into the outlet. Started a self clean cycle, but this time I heard the motor make one revolution and stop. The cycle started for the customer and a few hours later, I am sure the oven was nice and clean.
    Aug 14, 2011 | Ovens
    Oven Stuck on Self-Clean/Locked cannot undo
    you can press the clear off button for 3-5 seconds this should turn off the oven. if not turn off the circuit breaker for a few minutes then turn it back on and hit the clear off button again
    Feb 27, 2010 | Ovens
    Double oven, top oven run by keypad turns off
    I have a double oven. The top unit works fine. The bottle unit will turn on to cook or clean. Then after a few seconds it turns itself off.
    Oct 12, 2009 | GE Profile JKP56 Electric Double Oven
    My self cleaning oven door will not open, and keeps beeping and
    The F9 code indicates there is a problem with the door lock.
    Try disconnecting the power to the range for 10 seconds and reconnecting. Open the oven door and hold the door switch plunger in while you try these things. Put the control into clean for 5 minutes then cancel clean. You must hold the door switch plunger in for the 5 minutes.
    Try canceling the clean cycle without putting the control into clean.
    Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question^%$%^@#
    Apr 19, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
    Door lock lites keeps flashing but the door is not locked
    Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question^%$@#$%
    Mar 02, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
    Slef cleaning oven Frigidaire electri clean oven lock will not un
    set both start & stop timers to the same time.Turn on the selector and the temperature knobs to clean. Hold in the light button, on the right top side of oven, and hold for 15 seconds.
    then turn off the selector knob. hold button again for 15 seconds and the lock should unlock,
    then turn off the temperature knob.
    Jan 22, 2009 | Frigidaire FEB27S5A Electric Single Oven
    Frigidare Self Clean Oven
    I JUST CALLED FRIGIDAIRE AND GOT INSTRUCTIONS FOR SELF CLEANING:
    1. TAKE OUT THE RACKS UNLESS YOU DON'T MIND THEM TARNISHING
    2. TURN THE "SELECTOR" AND/OR "OVEN" DIALS TO THE LOCK (OR CLEAN) POSITION
    3. PRESS THE "COOK TIME" BUTTON
    4. SET THE CLOCK TO 2 OR 3 HOURS (I.E., "2:00" OR "3:00"), DEPENDING ON HOW DIRTY THE OVEN IS
    5. PRESS "START" BUTTON
    6. YOU WILL HEAR THE MOTORIZED LOCK MOVE INTO PLACE; WAIT ABOUT 30 SECONDS, THE DOOR SHOULD BE LOCKED AND CLEANING WILL BEGIN.
    7. CLEANING WILL STOP AFTER THE TIME SELECTED (I.E., 2 / 3 HRS) AND THE DOOR SHOULD AUTOMATICALLY UNLOCK
    Sep 30, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
    Ovens Logo
    Top Ovens Experts
    Dan Webster
    Dan Webster
    ashburton
    Are you an Oven Expert? Answer questions, earn points and help others
