The washer will not start as the start button flashes and says that the washer is paused. No cycle has been started. It does not matter what type of cycle is selected, the start button has Pause for all of them.
  • 1 more comment
  • roma_richard Oct 03, 2010
    No. I checked around the site on how to get the Error Code and I got E41. I don't think I saw any specifics for E41 though.
    The wash is a Frigidaire GLTF2940FS1
    Is there a place on the website that I could find how to take the lock assembly apart?
    Maybe more importantly what a PTC is, how to measure the resistance and what OHMS are.
    Thanks.
    No to both. It sounds like we'll have to call someone out.
  • 5,081 Answers
Is there any light named CONTROL LOCK light up on the control board?
Posted on Oct 03, 2010
  • 3 more comments
  • INDIRA KUMAR
    INDIRA KUMAR Oct 03, 2010
    E41 = Control board thinks the door switch is open. This points towards a faulty door switch on the machine.
    Remove the door lock assembly and measure the resistance of the PTC. It should be around 1500 ohms
  • INDIRA KUMAR
    Ohms are the unit to measure resistance...Do you have experience in working over the electrical components and do you have an ohm meter at home o measure the resistance?
  • INDIRA KUMAR
    PTC thermistor is one whose zero-power resistance increases with an increase in temperature.
  • INDIRA KUMAR
    If you do not have prior experience in involving with such electrical works i would prefer to call some...
  • INDIRA KUMAR
    Please rate and accept my solution if you are satisfied..A testimonial would be greatly appreciated too..
Unlocking your washer so it actually works.
If the green cycle light is flashing on then off, this usually means the cycle is paused. The lid lock should unlock when in pause mode, if not you will need to press and hold the "Pause/Play" button to clear the cycle completely, if there is water in the unit, it will drain first, then unlock the lid and be on standby to start a new cycle. Pleazer Appliance...
Apr 13, 2014 | Amana NTW4700YQ Top Load Washer NTW4700YQ
Electrolux front loader washer ewd1477 flashing start/pause button. interrupted during wash cycle by power outage. start/pause button now flashes and won't start any cycle.
Try to turn circuit breaker off, or unplug unit, for about 5-6 minutes. This is a hard reset and should reset the internal controls to restart the unit properly.
Dec 29, 2012 | Electrolux Washing Machines
Whirlpool Duet washer - paused cycle to add a garment now can't get it to resume cycle or clear the cycle.
I did as Drunan did and unplug for 10 and plugged it back in and it started like a champ! Thanks!!!!!! ;)
Jan 16, 2012 | Whirlpool GHW9300 Duet Washer
My washer won't start, it keeps flashing ERR and then the wash-time, and then LOC. My roommate says to fix it before, he held down three buttons, but can't remember which ones. Any idea?
Try the following two buttons: press Options and Select together for 10 seconds (or until the LOC disappears). The pair of buttons held for 10 seconds also sets this control lock.
To find out the error code, turn the Program knob to the start position, Spin Only. Press Start/Pause to start the cycle. Press Cancel to stop the cycle and turn off the LEDs. Press Cancel again and within 5 seconds press and hold the Options and Start/Pause buttons until the LEDs start chasing. Then release the buttons. Turn the Program knob seven clicks clockwise from the Start position. The control will signal the last error code. To clear the error, press and hold Options and Start/Pause for 3 seconds. Then either unplug the washer for 5-8 seconds before plugging it back in. Alternatively, press and hold Options and Start/Pause together for a few seconds until the Wash LEDs appear.
http://www.applianceblog.com/mainforums/frigidaire-electrolux/12950-frigidaire-atf6000es1-wont-drain.html has a link to the service manual for the listed washer (the link is half-way down the page).
I hope this helps.
Oct 12, 2010 | Frigidaire ATF6000ES Front Load Washer
How do you get the wash cycle off of ''pause''? I put it on pause to add more clothes, and don't know how to get it started washing again.
Hello and welcome to Fixya.
Starting it again from a "paused" status should just be a matter of pushing and holding for a couple of seconds the start button, provided the door is closed properly.
Hope that answer`s your question. Good luck.
macmarkus :)
May 19, 2010 | Kenmore HE3T Washer
Can't get washer to start again after pushing pause/cancel button
sounds like central control unit problem, you can check for diagnostic mode operation by setting (door closed) drain/spin, no spin, pressing prewash 4 times in 5 secs pressing prewash again will advance through diagnostic cycle. replacing user interface may also be necessary
Apr 25, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Reset wash cycle
Changing Cycles, Options and Modifiers
Not all Options and Modifiers are available with all cycles. Cycles,
Options and Modifiers can be changed anytime before HOLD TO
START is selected.
Options and Modifiers can be changed anytime after HOLD TO
START is selected and before the start of the selected Option or
Modifier.
To cancel a cycle and select a new cycle
1.
Select PAUSE/CANCEL twice.
2. Select desired cycle.
3. Select the desired OPTIONS.
4. Select HOLD TO START (for approximately 1 second) to
restart the washer at the beginning of the new cycle.
To cancel a cycle
1.
2. The washer powers down, the door unlocks, and clothes can
be removed.
NOTE: If the water level or the temperature is too high, the
washer will drain automatically before the door unlocks.
To change Options or Modifiers after the cycle has started
1.
Select PAUSE/CANCEL.
2. Select the desired OPTIONS or MODIFIERS.
3. Select HOLD TO START (for approximately 1 second) to
continue the cycle.
To drain the washer manually
1.
2. Select DRAIN/SPIN.
begin the drain.
4. When the spin is complete, the door unlocks. Items can be
removed from the washer.
Nov 23, 2008 | Whirlpool Duet GHW9150P Front Load Washer
ATF6700FS - Affinity? 3.5 Cu. Ft. I.E.C. Capacity Washer Won't Start
ERR=An error has been detected
PAU=Cycle has been intrupted
58=High current on motor phase
To clear latest stored error code:
• Turn the Program Knob to the start position, Spin Only.
• Press Start/Pause to start the cycle and save it.
• Press Cancel to stop the cycle and turn off the LEDs.
• Press Cancel again to turn on the LEDs.
• Within 5 seconds, press and hold the Option and Start/Pause buttons until LEDs start sequentially chasing, then release buttons.
• Turn the program knob clockwise 7 clicks from the Start Position. The control will signal the last error code.
• Press and hold the Options and Start/Pause buttons for 3 seconds. The code will be cleared.
• Exit Diagnostic Mode to return the washer to normal operation.
a) Unplug the power cord, wait 5-8 seconds, then reconnect the power cord OR
b) Turn the program knob clockwise 2 or 3 clicks after the Start Position. Press Options and Start/Pause buttons
together for a few seconds until wash cycle LEDs appear.
Feb 25, 2008 | Washing Machines
Washing Machines Logo
35 people viewed this question
Top Washing Machines Experts
