Question about Samsung Digimax S730 Digital Camera
My camera will not turn on even with new batteries. the lens is stuck out.
    Brigadier General:
  • 11,967 Answers
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include "E18 lens error", or "lens error, restart camera". Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in "no heat" setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Oct 04, 2010
My olympus tg 310 is stuck with the lens open and won't come on at all even when a fresh battery is installed
If the camera is within warranty, return it to where you bought it. Common fault with a few different brands, to do with a lens open sensor within the lens assembly itself. Maybe allow the camera to dischage without the battery for a few hours and see does it power on with a new battery. Also chack the battery, if it has bubbled it a dud, and check the battery contacts within the battery compartment.
Jun 05, 2012 | Olympus TOUGH TG-310 Digital Camera
Kodak Easy Share Z1275 stuck lens
**** a very common problem with most cameras. There hasn't been much of a solution for this problem except to try to wiggle the lens zoom while pushing and holding the power button.
Also make sure you have brand new batteries installed. Even the slightest dead battery will cause a problem.
Jun 02, 2009 | Kodak EasyShare Z1275 Digital Camera
Can't take pictures
If the lens is buzzing and followed by an "E18" or "lens error" message then the lens will need to be replaced. If no message appears you may just have flat batteries or even a single bad battery can cause this. Try getting some good quality disposable batteries specifically for digital cameras. If all is well with the new ones, invest in a new set of rechargeables.
Mar 24, 2009 | Canon PowerShot A95 Digital Camera
S1050 Samsung crashed?
ok, i had a similar problem I had normal batteries in there... cheap ones... and accidentally set the battery type to NiMh in the camera settings... it wouldnt turn on after that. Make sure you try NiMh batteries in case that might be your problem. Another thing i have noticed (may be just my camera) is that it doesnt want to work if its cold....
Aug 22, 2008 | Samsung S1050 Digital Camera
My camera will not come on. and also the lens is opened out and will not go back in, i have put several new batteries in it, and if i put batteries in it and close the battery door, and push on, the light...
my camera will not turn on or off lense stuck open put new batteries still nothing my daughter took picture with it everything went blank its the samsung s630 worked fine till today!!
Jun 08, 2008 | Samsung Digimax S630 Digital Camera
Lens stuck open
i have just had the same problem. mine was stuck open, i gave the lens a slight twist and heard a bit of a crack. i switched it on again, now it is ok.
Apr 09, 2008 | Samsung Digimax S600 Digital Camera
Lens cover only partially opens
This blog post outlines repair procedures for stuck lens covers. An A400 is used as an example. But it should be similar for the A430:
http://camerarepair.blogspot.com/2007/11/repair-of-stuck-lens-covers.html
Mar 31, 2008 | Canon PowerShot A540 Digital Camera
Digimax samsung s500 beeps 3 times lens stuck wont stay on
Mine got stuck with lens out. The batteries were new so I never imagined it could be the batteries, but they were cheap ones so I recharged a pair of good ones and once I put tried them on it worked just fine again. Conclusion, the "new" cheap batteries had only enough energy to turn it on and then they couldn't give it enough energy to make it work anymore and that's why I couldn't retract the lens or even turn it off properly. So in your case, try using a couple of good and new batteries.
Dec 14, 2007 | Samsung Digimax S500 Digital Camera
Samsung Digimax S730 Digital Camera Logo
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Computer Links
Are you a Samsung Camera Expert? Answer questions, earn points and help others
