Question about Hotpoint GE VWSR4150DWW WASHER
Water is leaking from the under side of my washing machine what could be the problem?
  • 593 Answers
You may have just a loose clamp, You will have to access the underside to check. Get help and tilt the mach. forward, look under in the location of the leak for a loose clamp or cracked hose. Thats about all it can be.
Posted on Oct 03, 2010
  • 51 Answers
Check all hose connections, fill tub check for leak while full, then drain and check pump while draining. Also while tub is full use a flashlight and look where trans goes into tub if you see a leak in the center then it is your center seal.
Leak around Duet wash machine
Leakage from under a top loader often indicates either that the pump is leaking or there is a leak in one of the hoses
Apr 24, 2013 | Washing Machines
My washing machine is a Roper top load washer. The problem I am having is that the pump from the cold water drain from under the washing machine. Do I need another pump? The hot water will work. I use the...
This model is a direct drive with only one pump, the drain pump. If the drain pump leaks, which is a common problem on these models, it will leak no matter what temperature wash is selected! If you a have a leak on cold, it will probably also leak on warm wash. Your problem is your solenoid operated fill valve on the cold side. Only one fill hose comes off of this combination fill valve to your fill plenum at the top back of your tub. So if it leaks on the cold, but not hot, check for a crack in the plastic housing of the valve on the cold half. The valve is located on the inside back of the machine on top right when looking at the front of the machine. They are fairly inexpensive and easy to replace.
Hope this helps
kcomp1863
Jan 18, 2011 | Roper RAS6233KQ Top Load Washer
My Kenmore 700 series washer has been leaking water. When the tub is filling with water, water seems to leak along the front bottom edge of the machine in several areas. I'm left with a huge puddle of...
First ck to see if your water pump is leaking. It normally leaks when the machine is running not just filling. Also look at all the attaching rubber hoses under the machine and see if water is leaking down the back right side of the machine and then running around the frame to the front long shot but possible.
Aug 11, 2010 | Kenmore 15864/15862 Top Load Washer
Water leaking when machine is off
you need a new water valve. it is located at the back left hand side under the main top(the piece the hot and cold water hoses hook on to)
Feb 08, 2010 | Whirlpool GHW9300 Duet Washer
Washer is leaking. If facing washer, water is on
probablly water pump or hose tilt machine to view where water is coming from
Jan 17, 2010 | Kenmore HE2 Plus Front Load Washer
Washing machine leaking water while filling
You will need to check the hose between the water valve and the diffuser where the water gose into the tub. Also check the water valve where the water hooks up to the back. It's plastic and will crack so that it will leak inside the back of the washer. Also if you have a dispencer on the side under the lid it also has hoses that can leak. It shouldnt be a big problem that you will need a repairman. Good luck
Dec 19, 2009 | Maytag Washing Machines
Washing machine pouring water out on final spin
The rubber pipe under the machine is usually parished......
Feb 28, 2009 | Maytag Neptune MAH5500B Front Load Washer
Lg washing machine 1289 fhd
The operating pressure is 4.5 - 116 psi.
Where is the leak?
Feb 08, 2008 | LG WD-1280FHD Front Load Washer
Washing Machines Logo
91 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
