Question about Refrigerators
LOWER PART IZ NOT COOLING....UPPER PART IZ WORKING PROPERLY....
  • 51 Answers
Make sure the fan is moving(pushing the cold air down to the fridge from the freezer.
Posted on Oct 03, 2010
My Toyota kzTE is boiling after travelling 15km bt de fan iz ok.iz it the thermostat?
Certainly it might be the thermostat and this should be checked, though it isn't very often the cause or the sole cause of overheating.
A leaky head gasket and/or a blocked degassing system is another possible cause and this could prevent a good thermostat from working properly.
Insufficient coolant circulation is another possible cause and this could be caused by a blocked/partially blocked radiator core, callapsing hose(s), silted water passages in the cylinder block or head...
Insufficient cooling air flow through the radiator core due to a build up of mud, insects, dust, etc.
Or a combination of several...
Aug 09, 2016 | Toyota Cars & Trucks
How do i replace the radiator on a 2003 Buick Lesabre
3.8L Engine
  1. Drain the engine coolant.
  2. Remove the upper radiator seal.
  3. Remove the upper tie bar.
  4. Disconnect the coolant overflow hose from the radiator.
  5. Plug the coolant overflow hose.
  6. Disconnect the upper and lower radiator hoses.
  7. Remove the transaxle oil cooler pipe bracket bolt from the lower tie bar.
  8. Remove the cooling fans.
  9. Slide the plastic cap off the transaxle oil cooler pipe quick connect fittings.
  10. Disconnect the upper and lower transaxle oil cooler pipes from the radiator.
  11. Remove the A/C condenser mounting bolts.
  12. Separate the condenser from the radiator.
  13. Lift the radiator up and out of the vehicle.
To install:
  1. Install the radiator to the vehicle. Place the bottom of the radiator in the lower pads.
  2. Install the condenser to the radiator.
  3. Install the A/C condenser mounting bolts and tighten to 115 inch lbs. (13 Nm).
  4. Push the upper and lower transaxle oil cooler pipes into the radiator quick connect fittings, until a "click" is heard.
  5. Tug gently on the cooler pipes to ensure proper retention.
  6. Slide the plastic caps (1) over the quick connect joints.
  7. Install the cooling fans.
  8. Install the transaxle oil cooler pipe bracket bolt to the lower tie bar and tighten to 89 inch lbs. (10 Nm).
  9. Install the upper and lower radiator hoses.
  10. Connect the coolant recovery hose to the radiator neck.
  11. Install the upper tie bar.
  12. Install the upper radiator seal.
  13. Fill the cooling system.
  14. Inspect the transmission oil level.
Nov 02, 2015 | Buick Cars & Trucks
After a front end collision the lights in my consel as well as my dome light and my floor heat no longer work
Lighting may be as simple as a fuse, or may even have the switch in the off position. As far as floor heat, is heat coming out of the upper ducts? If not, the shop may not have properly filled your cooling system since your heater works by using the heated coolant. Your cooling system requires purging of captured air within the system whenever the system is drained. If you have heat from upper ducts and not the lowers, the doors built into the heating/cooling system are not working properly. A severe collision may have broken some of the plastic casing of the system causing a mechanical interference of moving parts, or knocked a wire connection loose that controls the doors. Those are the items to visually check. Otherwise it's a process of elimination via testing of the electronics.
Jan 11, 2014 | 2003 Chevrolet Cavalier
Upper compartment works but lower compartment ligth on but does not cool
Sounds like a bad fan ,,in lower compartment,,,check manufacturer website,,,,but can be replaced,,good luck,,
Dec 20, 2011 | Refrigerators
How to change a radiator
1988–91 Models
  1. Disconnect the negative battery cable.
  2. Properly drain the cooling system into a suitable container.
  3. Disconnect the fan motor and motor connector.
  4. Disconnect the upper and lower radiator hoses.
  5. Disconnect and plug the automatic transaxle cooling lines at the radiator, if equipped.
  6. Disconnect the coolant reservoir overflow hose.
  7. Remove the radiator attaching bolts and brackets.
  8. Remove the radiator with the cooling fan attached.
  9. Remove the cooling fan and shroud from the radiator. NOTE: Check all cooling system hoses for any signs of damage, leaks or deterioration and replace if necessary. To install:
  10. Attach the cooling fan and shroud to the radiator and install the assembly.
  11. Attach the radiator bolts and brackets. Tighten the radiator bracket bolts to 7 ft. lbs. (10 Nm).
  12. Connect the coolant reservoir overflow hose.
  13. Connect the automatic transaxle cooling lines to the radiator, if equipped.
  14. Connect the upper and lower radiator hoses.
  15. Connect the fan motor and thermo-switch wire connector.
  16. Refill the system with the proper type and quantity of coolant, check for leaks and bleed the cooling system.
  17. Reconnect the negative battery cable. Fig. 7: Cooling system components — 1988–91 engines 86833085.gif
1992–95 Models
  17. Reconnect the negative battery cable. Fig. 8: Cooling system components — 1992–95 engines 86833086.gif
Aug 27, 2010 | 1991 Honda Civic
I am trying to remove my radiator and place it with a new one? I have a 1998 Dodge Grand Caravan.
Chrysler Caravan/Voyager/Town and Country 1996-1999
Radiator - REMOVAL & INSTALLATION
Fig. 1: Before removing the hood latch, mark it's location on the crossmember with a paint marker or other tool
CAUTION Do not remove the radiator cap or drain with the cooling system hot and under pressure or serious personal injury can occur from hot pressurized coolant.
  1. Place a drain pan under the radiator drain. Open the radiator drain plug and allow the coolant to drain.
  2. Remove the air intake resonator from the air cleaner assembly.
  3. Remove the Coolant Recovery System (CRS) overflow tank filler neck hose.
  4. Disconnect the cooling fan electrical connector located on the left side of the cooling fan module.
  5. Remove the CRS overflow tank mounting screw from the upper radiator crossmember.
  6. Remove the upper radiator-to-crossmember mounting screws.
  7. If equipped, disconnect the engine block heater wiring connector.
  8. Remove the upper radiator crossmember.
Fig. 4: ... and the upper radiator-to-crossmember bolts, then ...
Fig. 5: ... unbolt the crossmember ...
Fig. 6: ... and lift it from the front of the vehicle
  1. Remove the entire air cleaner assembly.
  2. Disconnect and plug the automatic transaxle oil cooler lines from the radiator.
  3. Disconnect the upper and lower radiator hoses from the radiator. Remove the lower radiator hose clip from the cooling fan module.
  4. Remove the A/C condenser mounting fasteners and separate the A/C condenser from the radiator. Be sure the condenser is supported in position.
  5. Remove the A/C filter/drier mounting bracket, 2 mounting bolts to the cooling fan module and 2 mounting nuts to the filter/drier. Remove the mounting bracket.
  6. Carefully lift the radiator out of the engine compartment. Be careful not to damage the radiator cooling fins or water tubes during removal.
To install:
  1. Be sure the air seals are properly positioned before installation of the radiator. Lower the radiator into position and seat the radiator with the rubber isolators into the mounting holes provided.
  2. Install the A/C filter/drier and mounting bracket onto the cooling fan module. Install the bracket mounting fasteners.
  1. Install the A/C condenser to the radiator.
  2. Unplug and connect the transaxle oil cooler lines to the radiator.
  3. Connect the upper and lower radiator hoses to the radiator.
  4. Connect the CRS overflow tank filler neck hose to the radiator.
  5. Reconnect the cooling fan motor electrical connector.
  6. Install the entire air cleaner assembly.
  7. Install the upper radiator crossmember.
  8. Install the upper radiator mounting screws and torque to 105 inch lbs. (12 Nm).
  9. Reconnect the engine block heater electrical connector, if equipped.
  10. Install the CRS overflow tank mounting screw to the upper radiator crossmember. Torque the screw to 18 inch lbs. (2 Nm).
Fig. 11: Unbolt the lower radiator mounting brackets
Fig. 12: Once all of the components are removed or set aside, the radiator can be removed from the vehicle
  1. Install the air intake resonator.
  2. Refill the cooling system with a 50 / 50 mixture of clean, fresh ethylene glycol antifreeze and water to the proper level.
  3. Reconnect the negative battery cable.
  4. Start the engine and run until it reaches normal operating temperature, then check the coolant level and the automatic transmission fluid level. Add fluids, if necessary.
Hope help with this, remember comment and rated this.
Jul 22, 2010 | 1998 Dodge Caravan
How do I replace a radiator on a 2002 maxima
Nissan Car 350Z & Maxima 1999-06 Radiator - Removal & Installation
  1. Before servicing the vehicle, refer to the precautions in the beginning of this section.
  2. Drain the cooling system.
  3. Remove or disconnect the following:
    Negative battery cable Coolant reservoir tank and bracket Upper mounting bracket Upper radiator hose Oil cooler lines, if equipped Lower radiator hose Cooling fan and condenser fan Fan motors and shields Radiator
To install:
  1. Install or connect the following:
    Radiator Fan motors and shields Cooling and condenser fans and torque the bolts to 44 inch lbs. (5 Nm) Lower radiator hose Oil cooler lines, if equipped Upper radiator hose Upper mounting bracket Coolant reservoir tank and bracket and torque the bolt to 44 inch lbs. (5 Nm) Negative battery cable
  2. Fill the cooling system to the proper level.
  3. Start the vehicle, check for leaks and repair if necessary.
WARNING Do not remove radiator cap when engine is hot. Serious burns could occur from high-pressure engine coolant escaping from radiator. Wrap a thick cloth around the cap. Slowly turn it a quarter of a turn to release built-up pressure. Carefully remove radiator cap by turning it all the way.
  1. Before servicing the vehicle, refer to the Precautions section.
To install:
Fig. Exploded view of radiator and components
    CAUTION Do not damage or scratch the A/C condenser and radiator core while removing.
    CAUTION Because A/C condenser is onto the front-lower portion of radiator, moving to rear direction should be at minimum.
    Negative battery cable Engine cover Air duct and air cleaner case assembly Bracket mounting bolt for anchoring A/C piping Reservoir tank and bracket Upper and lower radiator hoses Radiator cooling fan assembly On A/T models, A/T fluid cooler hoses. Plug hoses to avoid leakage Cover, then two A/C condensing mounting bolts located in the upper part of the radiator Rotate two radiator upper mount brackets 90 degrees in the direction shown in the illustration and remove fce8147.jpg
    Fig. Removing A/C condensing mounting bolts
    Fig. Rotating radiator upper mount brackets 90 degrees
    Fig. Removing radiator
  4. Remove the radiator by performing the following:
    CAUTION Lifting A/C condenser should be minimum to prevent a load to A/C piping.
    With lifting and pulling radiator in a rear direction, disassemble lower mount from radiator core support center. Lift A/C condenser up and remove radiator after disengaging the fitting as front-bottom surface After removing radiator, put A/C condenser on radiator core support center to prevent a load to A/C piping, and temporarily fix it with rope or similar means
To install:
  1. To install, reverse removal procedure.
  2. Check radiator cap for any leaks.
  3. Start and warm up engine. Check for engine coolant leaks and A/T fluid leaks.
Hope this help (remember comment and rated this).
May 12, 2010 | 2002 Nissan Maxima
Freezer and fridge not cooling (halfway)
SxS Amana upper half of feezer and Refrigerator not working
Jun 22, 2009 | Amana 22.6 cu. ft. Side-By-Side...
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
