Question about AEG 24 in. Favorit 40260i Built-in Dishwasher
AEG OKO FAVORIT 6040 / 6150
Rotary timer switch was removed by techi and never re-installed due to cost. Now need to put timer switch back in machine but have no idea which colour wires go to which pin point on back of rotary switch/timer. Switch was never faulty, but element was the cause of tripping the earth leakage.
I have looked at the UK models and it is identical to 6040 model. Mine has Bio buttons, so could be the BIO model, but not too sure.
Please can someone supply the wiring diagrams or tech manuals.
2 Suggested Answers
joe_lishman
  • 192 Answers
SOURCE: AEG OKO FAVORIT 6050 trips earth leakge
This is typical of a water leak onto electrical connection OR the electrical element has shorted internaly . Check this with a Ohm meter and itshould show the problem
Posted on Jan 19, 2010
Aeg oko favorit 40300 service manual
AEG OKO FAVORIT 40300 When switching dishwasher on no water is flowing into the the dishwasher
Please help
Jan 11, 2012 | AEG Dishwashers
On off switch won't stay depressed on AEG dishwasher
Took unit apart and when I put it back it worked again. For how long who knows.
Access to the switch is difficult but by removing the printed circuit board, it seemed to allow the switch to work.
Dec 27, 2009 | AEG 24 in. Favorit 40850 Free-standing...
Dec 20, 2009 | AEG 24 in. Favorit 60830 Free-standing...
The drain pump on the AEG oko favorit 6050 keeps running even when the on/off switch is off or the door is open.
Empty all the water from the salt resevoir, (I used a turkey baster), then rock the machine backwards and forwards a few times and empty the last few drops from the resevoir again.
Oct 17, 2009 | AEG Favorit 50500 Built-in Dishwasher
AEG OKO LAVAMAT - BROKEN BOLT - WHAT DOES IT DO?
The bolt you described is indeed a transit bolt and should be removed. I believe that the current UK agents for aeg are service force. Check their website for your nearest branch.
Hope this helps & thanks for using Fixya
Dec 23, 2008 | Washing Machines
Aeg dischwaher model oko favorite
This seems like the anti flood system (polystireen float / micro switch) at the base of the washer is triggered,\. This puts the washer in pump out mode and stops inlet of water via the inlet solinoid. Dry the water on the base and then check for any water leaks. (pipe leak
Nov 15, 2008 | AEG 18 in. Favorit 64800 Free-standing...
Drain pump keeps running AEG oko favorit
Aug 29, 2008 | AEG Favorit 50500 Built-in Dishwasher
Aeg oko_lavamat 508- not enough water
Have law level water problem in my clothes washing AEG Lavamant OKO 508.
Jun 01, 2008 | Kenmore Elite 45986 Front Load Washer
AEG OKO-FAVORIT 50800
C3 error means that there is water at the bottom of the dishwasher. Unplug the dishwasher, slide it forwards and push it back. So it stands on the 2 back knobs. Do this atleast at a anle of 45 degrees. You will see water flowing at the floor.
If this happens often you have a leak somewhere. Time to cal the technician then.
Mar 03, 2008 | AEG Dishwashers
AEG 24 in. Favorit 40260i Built-in Dishwasher Logo
555 people viewed this question
Top AEG Dishwashers Experts
Oloyede Monsuru
Mike
Are you an AEG Dishwasher Expert? Answer questions, earn points and help others
