Question about Samsung Dryers
Dryer comes on, gets warm, shuts downafter about 3 minutes
  • 51 Answers
Replace the thermostat.
Posted on Oct 03, 2010
My Maytag Bravos dryer is shutting off after running 10-20 minutes. Will not restart for an hour. Feels very warm
Have you considered calling a repairman .. sounds like you have a thermal overload malfunction .
Mar 16, 2016 | Maytag Dryers
MDG6200 dryer doesn't dry and clothes aren't warm after cycle. I took off front cover and observed that flame comes on, but then cuts out a minute or two after starting. Airflow/venting not problem, since...
The gas valve is shutting off too soon due to a weak solenoid coil that shuts off when it gets hot. Replace the solenoid coils to address the problem. Disconnect power to the dryer prior to servicing to avoid the risk of electric shock.
Unplug the wiring harnesses from the solenoid coils then remove the two screws securing the coils holding bracket. Remove the bracket and lift the solenoid coils off then replace it in reverse of the removal steps.
May 29, 2010 | Dryers
Screen goes blank and projector shuts downafter about 10 minutes (IN24 In Focus projector)
ballast/ power supply issue. you'll need to send it in to an infocus service center for repair. try av solutions in ny. they're really good. www.avsolutionsny.com
Nov 28, 2009 | InFocus IN24 Multimedia Projector
I replaced the coil set, but that was not the problem. The ignitor will light the gas flame and it will blow for about 2 minutes, then the gas shuts off. Since replacing the coils, I have not tried the...
The gas flame will cycle on and off in response to the thermostat. Two minutes sounds about right for the dryer to warm up to temperature. The gas will shut off until the temperature cools down and then should cycle on again. Let the dryer run (either with or without clothes inside) and watch to see if the gas cycles on and off. If the gas does not come back on there may be a problem with the thermostat or auto sensor or the exhaust vent duct may be clogged.
Nov 06, 2009 | Dishwashers
Whirlpool LER4634EQO Runs for about 2 minuts and shuts off.
It is possible your Cycling Themostat is not working properly. It determines at what temperature to turn heat on and off to maintain a consistent dryer temp. The High Limit Thermostat would turn off the heat but your dryer would still run. That leaves the Thermal Cut Off which is turning off your dryer. It might be faulty and turning off at too low a temp, or it might be doing it's job. In that case something else is wrong. If you can check the exhaust air temperature at the dryer, it should be under 175 degrees. If you are absolutely sure the vent is clear, then replace the Dryer Cycling Thermostat.
Aug 25, 2009 | Dryers
Flame shuts down after 5-8 minutes
AFTER THE BURNER SHUTS DOWN THE 1ST TIME IT SHOULD COME BACK ON WITHIN 1 TO 3 MINUTES. WHEN THE BURNER TRIES TO COME BACK ON YOU'LL HEAR A CLICK AND THE GLOW OF THE IGNITOR SHOULD BE VISIBLE. AFTER 30 TO 60 SECONDS IGNITOR SHOULD FADE AND THE BURNER SHOULD FIRE. IF IGNITOR FADES AND BURNER DOES NOT FIRE YOU WILL NEED TO REPLACE BURNER COILS #279834. IF IGNITOR DOES NOT COME ON YOU WILL HAVE A T STAT OR SENSOR ISSUE. SOUNDS LIKE COILS TO ME. HOPE THIS HELPS PLEASE FEEL FREE TO CONTAT ME HUBAPPLIANCE@COMCAST.NET. PLEASE RATE MY RESPONSE.
Jun 23, 2009 | Dryers
2 to 3 cycles to fully dry clothes
if the clothes are warm after the cycle then you need to make sure the vent to the outside of the house is not plugged if they are not warm then it is in the heating circuit of the dryer wether it be the element or a fuse will have to be tested. to dry clothes it takes heat and air flow if you dont have one of the two they will not dry correctly
May 18, 2009 | Kenmore Elite Oasis 6808 Electric Dryer
Heat runs ten minutes than heat shuts off continues to run
I'm thinking the thermostat has failed, it get's too hot and the emergency over temp sensor kills the flame before a fire is started.
Apr 07, 2009 | Kenmore 63942 Dryer
Roper dryer res7745pq is taking 2 cycles to dry and vent is clean?
check if the thermostats in rear part of dryer are covered with lint. take power off to dryer and remove back panel you will see 2 or 3 thermostats if there is a lot of lint around them carefully remove lint. if that doesn't solve problem make sure clothes are coming out of washer spun dry enough .. check lint screen on dryer. is the vent clear all the way outside ?, in winter little critters like to set up housekeeping in vents where the temperature warms them up. you can also check if heat is cycling open door to dryer and press the door button, start dryer and observe heater , it will come on then shut down and it should come back on in a minute or two, if it doesn't come back on the cycling thermostat may be at fault
Jan 26, 2009 | Dryers
Dryers Logo
60 people viewed this question
Top Samsung Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Samsung Dryer Expert? Answer questions, earn points and help others
