Question about Solis Crema SL-90 Espresso Machine
The machine is still turning on however the light which indicates when it is ready to make the coffee never changes from red to green. I wondered if it might a problem with the control panel. My machine is only two years old. The last cup of coffee I made was fine as far as the pressure mechanism ... it is just the panel now not responding when I touch the button to make the coffee and the light indicating readiness never changes from red to green. The portion button still functions as well as the steam button.
  • 1,089 Answers
HI I would suspect the thermostat on top of the boiler. it is 2 red wires with a little thermal couple on the end. Could be broken or bad. Goes to the board.
Posted on Oct 04, 2010
My saeco vienna plus has a code issue The red light is flashing but the brew green light is not on
1. Make sure the drawer for coffee grounds is securely closed 2. make sure that coffee beans are loaded and are actually down into the machine (and not clogged at the top) 3. Make sure water is in the hopper. If so, "bounce: the hopper a few times to see if bubbles come out indicating air in the water line. 4. Turn on and hope for a green light. If not, re-check 1 through 3
Aug 18, 2016 | Saeco Coffee Makers & Espresso Machines
Red light comes on, instead of turning to green when ready it is turning orange.
RED LIGHT IS ERROR IF YOU HAVE AN ORANGE LIGHT YOU HAVE TO DO DESCALING TO REMOVE ERROR FOLLOW INSTRUCTION ON YOU MANUAL IF NOT SEND US AGAIN
Mar 03, 2016 | Coffee Makers & Espresso Machines
2 red lights on CPU board
I will assume that you have the first on/off switch turned on and the one for the element is not turned on. The machine is saying it is not ready to dispense hot water or steam.
Apr 20, 2014 | Rancilio Classe 10 Espresso Machine
Saeco Eclipse stopped functioning
Have you solve your problem with Odea. Mine is new out of the box and not working at all. Red light blinking, manually prime it and so far only tree cups of coffee. After priming it the green light was solid and could make 3 cups then stopped. Any advise greatly appreciated.
Dec 12, 2011 | Saeco Odea Go
It is a new Saeco Odea Go machine. Every time I turn it on the indicator lights flash up and down successively and a half inch of water comes out of the coffee spout. The light is then in the ready...
What will the machine do when you turn it on? The green light will start flashing for warming up phase. When it reaches the working temperature, all the lights start flashing in anticlockwise direction and the brew group moves up and start pumping water to rinse the system.Of course half an inch of water will come out from the spout. That is normal.
Sep 10, 2010 | Saeco Odea Go
Should the power light be green or red, when I turn camera on it shows a green light then turns red
Red light indicates that the camera is out of charged., Try to charged your battery for 3-4 hrs if you encounter flashing red on a fully charged battery you need to call kodak 1 800 235 6325 ext 12
You can charged you camera using 5V AC Adaptor or a USB cable taht attached into the computer
Nov 16, 2009 | Kodak EASYSHARE M1063 Digital Camera
The start button won't turn green when power turned on.
if the machine needs toner you will be able to change paper size & reduction but the machine will not come to ready[green ready light lit]. so if the machine keeps running after you turn it on it needs toner. if you leave it on for lets say 15 min. does it give you an add toner light or an error code?
Dec 15, 2008 | Sharp AR-160 Copier
Solis Crema SL-90 Espresso Machine Logo
253 people viewed this question
Top Solis Coffee Makers & Espresso Machines Experts
graybeard32301
Colin Stickland
Colin Stickland
AZBen
AZBen
Are you a Solis Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
