Question about Fujitsu Electronics - Others
I have a new home with a Fujitsu Inverter unit in one room. It has been working OK on A/C, but now I need to change to Heating mode. No operating manual or instruction were left with the unit -- only a handheld control that doesn't seem to do anything but control A/C temperature. Is there an operating manual available for download. John Field
  • 905 Answers
Hello John,
You didn't specify which model you have, as some models (all retired, I believe) don't offer heating functionality.
Find the model # of your system, it may be located on a nameplate on the indoor unit, or you may have to search for it on the outdoor unit. Once you have the model #, go here to get the manual for your unit.
For what it is worth, the remotes typically are the same across the line of Fujitsu's split systems. If you are not able to find the exact model #, find the manual that is closest description and try using it. Of course, you won't know if your system actually has heating ability or not though.
Have a great day, and thanks for using Fixya. Please accept and rate my solution if I have been able to help.
Posted on Oct 03, 2010
Problem with Fujitsu minisplit heating
did you try to set to maximum heat? (suspect the thermostat is defective)
Oct 03, 2015 | Fujitsu AOU24RLXFZ Dual, Tri and Quad Zone...
Fujitsu heatpump 13 years old is not heating room as it used to.filters are clean.i have gauges and would like to know what pressures are good and what pressures indicate low refrigerant or worn...
The refrigerant and compressor are related in cooling the room.As for heating problem the thermostat needs to be checked.
if you're used to a certain temperature of air and your heat pump is producing much cooler air, take the following steps. (Note that a heat pump may go into a defrost mode to prevent icing. When this happens, it can temporarily output cold air. Also be aware that the heat pump will have to work harder to produce heat.)
1) First be sure the thermostat is set properly. Try raising the set temperature 5 degrees F. and waiting a few minutes.
2) Be sure the room-heating registers are open.
3) Check the heat pump filter. If it's dirty, change it.
4) Be sure the auxiliary heating elements are working .
5) Clean the coils of the outdoor condensing unit.
If still the same problem then thermostat needs to be checked and replaced.
Thanks.
Jun 15, 2010 | Heating & Cooling
Fujitsu inverter; opens vents but no red light, no cold air
check that it is set to cooling sounds like it may be set to heat in cooling mode the indoor fan should at least run
Mar 10, 2010 | Heating & Cooling
Aou18c1 not shutting off
Fujitsu, Mitsubishi, Sanyo mini-split indoor fan motors operate continuoulsy. The room-temperature sensor is inside the unit, so the fan motor needs to circulate air continuouly to sense room-air temperature. This is normal operation.
Sep 12, 2008 | Fujitsu 18C1 Air Conditioner
We have a fujitsu air con model ast9lsbcw which blows cold air from the outside unit and the inside unit is not cooling the room.
Sounds like you have it in heating mode or it is low on charge. In cooling mode, the outside fan should blow hot air not cold.
Jul 30, 2008 | Heating & Cooling
Fujitsu Heat Pump - problems with timer? When starting the heat pump - the operation light, together with the timer light blinks twice, then the operation light blinks another five times. Then the...
I had the same problem. The heater did not work in heating mode. However it was OK in air-conditioning mode. The operation light and the timer light blink twice and then the operation light blinks for 5 times followed by few seconds non blinking, then the cycle repeats again. I have read on the internet that you better unplug the power cord and then plug it again so that the heater re-sets itself. My only problem was that my heater is directly plugged to the power with no visible plug. So I went to the main distribution board and put off the power for about 20 seconds for the whole home. HOORAY!! The heater worked after that.
Jun 24, 2008 | Fujitsu Heating & Cooling
Fujitsu Inverter ASTA09LCC - heating not working
Use a pen to hit the reset button on the remote.
Feb 09, 2008 | Fujitsu 18C1 Air Conditioner
Electronics - Others Logo
132 people viewed this question
Top Fujitsu Electronics - Others Experts
Are you a Fujitsu Electronics - Other Expert? Answer questions, earn points and help others
