Question about Hampton Bay Heating & Cooling
Unit is getting electricity but will not turn on
  • 382 Answers
Dear sir
if you know how to use a electrical tester then open control box and check electric supply is coming till the selector switch of your air-conditioner unit if it,s coming on selector switch then check indoor unit and pre fuse for control panel and see all cable is ok.and if all is ok then there is more possibilities selector switch is not working and it,s need to replace its up to you change by yourself or take help from a technician.
hope answer the question
thank you
please vote!
Posted on Oct 03, 2010
The flame effect quit working in my Brittany Electric Stove Heater, Model #BESBY-1500. How can I get a replacement flame effect?
Typically the flame effect is accomplished when a motor turns a rod with polished metal strips on it. The strips then reflect the light onto the back of the glass. The the rod rotates, the reflection moves giving the effect of the flames moving. If the lights work on your unit then the motor has most likely stopped. It would need to be replaced. A quick internet search turned up nothing for that company so you may need to go back to the store where you purchased the unit to get the part. Once you have the part, you will need to disassemble the unit. Some units are simple (like removing the fake logs) and some units are more involved (like removing access panels from the back or bottom).
Mar 10, 2014 | Vendor Development Group Inc Borgen...
Hows the best way to clean the back part of the AC when its still in the window
the best way to clean your air-conditioning by using pressure washing
step 1: Turn off your power supply or remove plug.
step 2: Pullout unit
step 3: Remove electrical box or insulate the electrical box to prevent water enter the electrical box and fan motor.
step 4: Clean the evap. and condenser by use pressure washer.
step 5: Wait unit dry the unit
Step 6: Remove insulate electrical box and fan motor
step 7: Install the unit
step 8: Plug and turn on the power supply.
step 9: Turn the unit
Aug 08, 2012 | Haier HWR06XC6 Wall/Window Air Conditioner
I have a goodman gsc13 ac unit about 4 year old. When the temp gets around 90 or above outside the fan on the unit starts but the compressor does not. I had service check it out but that day they were...
It sounds like the unit may be over charged. Make sure the outside coils are clean and you have plenty of airflow coming out of the top of the outside unit. What could be happening is, when the temps get higher outside, so do the pressures in the system. The compressor has a thermal overload protection that will kick the compressor off if it gets to hot, which if the compressor is over charged, it will work twice as hard, over heat and shut off. You would need a technician to come out and get the refrigerant charge back to normal. Another thing that could be happening is a weak or faulty capacitor, which is a small round or oval metal object, found in the electrical compartment on the unit. This are fairly simple to change out if your comfortable with electric. I've also had to put what's called a hard start kit on compressors with the same problem, new and old. The hard start basically gives it that extra boost of power to get it up and going. I would start with the refrigerant charge and go from there. The electrical "humming" sound that you hear unless you turn the breaker to the furnace off, is the contactor on the outside unit having a call for cooling. The 24 volts come from the furnace, to the outside unit, and pulls the contactor in to power the unit with the 220 volts supplied. It is normal and you don't have to worry about that at all. I hope some of this helps and good luck!
Jul 05, 2011 | Heating & Cooling
Condeser unit fan not turning.
Hello, most likely youmhave a bad capaitor or bad fan motor. If you push the fan and it gets going than the capacitor is bad,if not bad fan motor.
Jun 08, 2011 | Goodman CKL36AR36 Air Conditioner
The central air turns on, but does not cool. The fan outside of the house is not moving. Is there a switch I need to use to turn the outside fan on?
There should be an electrical box next to your exterior unit. Open it up and there should be a pull handle on an electrical bridge. Usually when it is turned one way it will make an electrical connection and if it is rotated 180 degrees and plugged in it won't make an electrical connection.
Jun 04, 2011 | Heating & Cooling
I am getting a EEAF fault code and the smoker will not heat. What is wrong?
To RESET control panel:
If control panel shows an error message, turn electric smoker off, unplug unit from outlet, wait
ten seconds, plug unit back into outlet, then turn electric smoker on. This will reset control panel.
ASSEMBLY, CARE & USE MANUAL
WARNING & SAFETY INFORMATION
MODELS 20070106, 20070206
Nov 25, 2010 | Masterbuilt 20070106 Electric Smoker
The unit working, but the problem is thermostat control, already get the said temperature, but could not auto off the unit.. i cannot check the unit without electrical diagram. i request to have an...
Its sounds like you need to adjust the cool anticipator in the T-Stat!It controls the reaction time by anticipating the temp and when to shut off or turn on! Very tricky on some T-Stat's!
Aug 22, 2010 | Heating & Cooling
My home's Air Conditioner shuts off and on until reach temperatur
You have some issues that probably need to be addressed by a Certified Tech asap. There's an off chance that it could be just thermostat related. If you feel confident on doing what I'm about to instruct go ahead and try it.If you turn off electricity to your unit(should be marked as A|C or furnace or the like if you have the unit on and turn off at the panel it's easier to locate) you can take the cover off your thermostat and you will find various wires. Unscrew the R, Y, and G wires(if they;re not colored red yellow green make a diagram as to which goes where) and twist them together, Then turn electric back onto unit. If the unit runs normally as it should, then you have a thermostat problem and need to get a new one right away. Remember you unit is worth $2,000 to $6000 don't let and electrical malfunction compromise the value, if it.s not the thermostat get someone qualified to look at it. Leave it off til they get there. Good Luck
Jul 16, 2009 | Heating & Cooling
Air conditioning unit leaks
It sounds as if the unit overflow tube has disconnected. You may need to turn the electric off to unit, take the plastic housing off and see if the tube is still connected.
Jul 05, 2009 | Heating & Cooling
When we turn on the central air there is a strong burning smell...like burnt toast but way stronger. IS it safe to remian in the house?
Is your central air furnace or electric heat. Electric furnace sometimes have electric strip sequencer stick in the closed positions leaving on one strip of the electric heat. Get a service tech as soon as possible to check this out. Any smells from a central unit need to be teken care of promptly. TURN OFF unit you have it checked for your safety. Rus
Jun 28, 2009 | Coleman Heating & Cooling
Heating & Cooling Logo
Top Hampton Bay Heating & Cooling Experts
Tim Whalen
Pete Norton
Are you a Hampton Bay Heating and Cooling Expert? Answer questions, earn points and help others
