Question about Hotpoint Refrigerators
I have a HTS 18 GBMCRCC ,the freezer constantly freezes up no matter what setting its on the fridge then gets warm and we have to take the freezer panels off and defrost its supposed to be frost free? we had a repair man out and he told up not to put very much stuff in freeze.We have 2 ice cube trays and a few other things.We defost it every 2-3 wks
  • 51 Answers
Could be one of three things going on, first the defrost heater is burned out, it can be checked by ohm meter, the thermostat needs replaced check with ohm meter while still cold(open),or the defrost advance needs replaced.
Posted on Oct 03, 2010
Fridge is too cold
It needs a new thermostat
Jul 27, 2013 | Refrigerators
My beko fridge freezers fridge keeps freezing
Your t'stat is probably bad. Should be easy to fix. At least it is freezing and not ruining your food from being too warm.
Feb 03, 2013 | Refrigerators
Fridge of my Hotpoint FFA90 fridge-freezer freezes
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
Mar 11, 2010 | Hotpoint FFA90 Bottom Freezer Refrigerator
My Jenn-Air JCD2389DE* constantly freezes produce
Hi; Need more info. Does the refridg. cycle on and off during the day. When You say no matter where You set the tstat concerns Me to think that the unit might be
runing all the time. Remember the coldest place in the refridgerator is the bottom. Excluding the freezer compartment. Also are the door gaskets in good condition this will also cause the unit to run more
...alpharome416
Feb 23, 2010 | Refrigerators
Samsung RB215BSSB refrigerator freezes up
I had a similar problem where my evaporator coil was freezing into a block of ice, which caused my fridge to warm up due to a lack of air flow. I fixed this by doing a few things. I replaced the circuit board ($100) which was easy to do. Unfortunately, this didn't fix my problem so I took the inner fridge cover off to view the evaporator/heater coil assembly. I checked my thermo fuse and found it to be open (failed). I ordered the thermo fuse and the thermistor and replaced them both. I then plugged the fridge back up and put a regular thermometer inside the fridge to get an accurate reading of inside temp. A few days now and everything looks good. The board, fuse, and thermistor were all pretty easy to replace.
Apr 09, 2009 | Samsung RB2155 Bottom Freezer Refrigerator
Candy CPCA250 GB Freezer feezing but fridge not cold
Hello jonnyclewlow
Welcome,
You said, you recently had a problem with my Candy fridge freezer (it defrosted overnight and wasnt cooling at all) and a repair shop diagnosed a thermostat problem. I have replaced the thermostat, Now the freezer freezes without any problems but the fridge does not go cold at all.
Also the compressor is running constantly
This is my first thought
Fresh Food temperature is
too warm. Freezer
temperature is satisfactory.
1. Fresh Food control is set too
warm.
2. Set fresh food control to a colder setting. Allow 24
hours for temperature to stabilize.
3.Then see if you do not have your freezer articles packed full up to the top, or covering the cold air vents usually found in the rear of the freezer compartment.
The fridge and the freezer share the cold air so the air must not be restricted from travel form the freezer to the fridge and back!
This would also cause the compressor to run none stop trying to cool the fridge!
So check your air vents in the freezer.
I'll bet you did not know they were there !
Most of us never notice!
Hope this works for you.
Please let me know that one of these solutions worked for you!
or if you have any questions.
Thank You, huuum
Please remember to leave a rating!
Oct 14, 2008 | Candy CPCA270FFK Bottom Freezer...
Gorenje KE267MLA Fridge too warm
higher the number, colder the fridge ie 7 is the coldest setting
switch with red dot is for summer/winter operation. only necessary to switch it on if the appliance is in a cold location
Sep 30, 2008 | Gorenje Refrigerators
Open Questions:
Refrigerators Logo
46 people viewed this question
Top Hotpoint Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
