Question about Maytag LAT2301AAE
The conditioner doesn't come out of the center bowl. It is streaking the clothes and the residual is like a past in the conditioner bow.
  • 905 Answers
The conditioner / softener typically is expelled during the spin cycle. Over time, the holes where the softener exits through can become plugged. Try removing the assembly, normally they just lift right off, and turn it over. You should then be able to see the holes and blockages.
Another symptom is if the spin cycle is not going as fast as it should, possibly due to overloading, damaged motor, or transmission issues.
Posted on Oct 03, 2010
My simpson eziset 750 is leaving grease marks on clothes after wash. Whats wrong?
Do you use fabric softener? Too much softener & too many cold water washes results in a build up of black soap residue on the outside of the inner bowl. You could try a hot wash with some white vinegar in the water (No clothes just the water) If that doesn;t work then you will need a service person to come & take the bowl out for cleaning.
Jan 02, 2016 | Simpson Washing Machines
Eziset 750. Why is it leaving grease marks on clothes after wash?
I am getting black streaks on clothes after washing.
Make sure the washer is level, especially front to back. Do not overload washer. Check to see if marks are coming from build up of gunk in the outer bowl.
Apr 09, 2015 | LG WM2301H Washer
How to clean
empty the bowls, fill with cool water and flush. remove the top and the bowls. wash any residue on the bows with mild soapy water and a soft sponge. do not use a scotchbrite pad. same with the augers and the evaporator barrel. put food safe lubricant (i.e. superlube) on the shaft, the auger nose, and the spigot rings and reassemble.
Nov 10, 2013 | Kitchen Appliances - Others
GE Top Load Washer WLSR2000G3WW~leaves oil residue on clothes and bowl
If it is grease that is in the tub then the trans is shot. Thats the only part that would result in this. Very pricy part but if you want to order it go to marcone.com with your model number and you can get the parts. I would not recommend fixing this, costs almost as much as new unit.
May 22, 2012 | GE WBSR3140DW Top Load Washer
Brother 7220 black streaks
Clean the roller and the inside of the machine, asny residue on the roller will cause these black streaks. If cleaning doesn't cure the problem you will need to replace it.
Jan 18, 2012 | Brother MFC-7220 All-In-One Laser Printer
White streak vertical down center of printed page
I tried all of the above but nothing worked. Brother's support didn't help either. I changed drums and toner cartridges to no avail. My copier is a MFC 8640D, but this should work on most laser printers.
I fixed my problem with a very simple solution, that I didn't find posted anywhere else. I removed the toner/drum unit (easy to do) and looked at the top of the bay where it was located. There is a recessed glass strip running the width of the opening that the laser uses to copy the image to the drum. I wiped it with a soft cloth and removed some toner residue, and then used a q-tip to further clean the entire length of the glass strip (it's called the laser prism). This removed the residue and my copies were crisper and the white streaks were gone. Hope this helps someone and saves you some time.
Jun 11, 2011 | Brother MFC 8500 All-In-One Laser Printer
Pitney bowe 9920, incoming faxes have black vertical columns on each side, with white or normal print in center.
Have you changed the toner cartridge? Often the disposal part of the image unit gets full and leaks out when the cartridge is reaching the end of its toner supply. This will leave black messy streaks on paper, and also make a mess inside the machine. Look inside the machine, if there is a mess, it is the cartridge.
Jan 13, 2010 | Pitney Bowes Office Equipment & Supplies
Washing machine
What actually will happen over time is the stainless steel retianing hub and nut diseningrate and the tub becomes loose. Then the spin cycle will destroy the top balancing ring. When this happens - the washer is junk - not worth repairing.
Before that thou - other mechanical problems can happen, like u-joint breakage. These washers are absolute junk.
Nov 27, 2007 | Whirlpool Calypso GVW9959K Top Load Washer
Maytag LAT2301AAE Logo
24 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
