Question about Cerwin Vega E-712 Main / Stereo Speaker
Dont know what type/# fuse to get to replace fuses in my E-712 cerwin vega speakers
  • brian schunck Oct 26, 2011
    Hi I am having the same problem as my E712's did not have the fuses in the speakers when i bought them. Also where the fuse goes in on the back of the speaker it seems to be missing the fuse holder and I was wondering if you knew what kind of fuse and fuse holder that it requires? Thanks
7.5 amps/ Ineed to know where to get fuse holders.
Posted on Mar 28, 2012
JULIANFIX
  • 975 Answers
SOURCE: Cerwin Vega V-35 Horns Drivers Model TMH-1
first you need a multimeter set to OHM , check on the back of the horn , remove the leads and do some reading , it should read 4 , 8 , 16 ohms depending of the brand , if you get no reading its means that need to be replaced , some horns you can detach the back (magnet w/the coil ) so you can replace it without buying the whole unit . good luck
Posted on Apr 19, 2008
Monster80
  • 463 Answers
SOURCE: I recently purchased a denon av surround re-
Depending on the wattage of the amp to the wattage off the speakers depends on what to use and how to control them..If your speakers are rated for more power than the amp can produce it will blow the fuses just as if the amp is rated for more than the speakers it will blow the fuse..Those type of speakers do need a good supply of power to run and speaker wire size could play an important part of that.If wire supply is to small it will over heat the coil in speakers and also blow the fuse...Look in side of the boxes to see what kind of capacitors they have on the speakers or there size to insure correct for speakers them selves..Also look at all of the wire routling in the amp to insure proper installation..Hope this helps you..Have a great day
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_a3369546f8067589
Posted on Apr 03, 2009
  • 29 Answers
SOURCE: I have a blown LW12 Cerwin Vega Speaker. Can
You have several ranges of options.
1) Contact Cerwin-Vega customer service: http://www.cerwin-vega.com/
2) Do a google search on "cerwin vega speaker replacement". You will find companies both that offer repair or repair kits (e.g., www.simplyspeakers.com) or sell replacements. Contact them - they have the expertise to tell you which of their products are most suitable for your model.
Posted on Nov 01, 2009
jhinsincity
  • 616 Answers
SOURCE: someone gave me a cerwin vega speaker, supwoofer,
Pay really close attention to how the speaker is wired and make a written note, maybe a polaroid, even video, since it is a single speaker you hopefully will not have problems with the mess of wires.
Posted on May 01, 2010
technical114
  • 1851 Answers
SOURCE: I have a cerwin vega subwoofer that keeps blowing the fuse
Take a look at the Voltage selector switch (if one is existing). It may be switched at the wrong position. In that case, I hope that the power supply is not burned out (if it is set at the wrong position).
In case of a problem or clarification, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "thumbs" or add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
Posted on Jun 13, 2010
What is the voltage and wattage of the Cerwin Vega E-715 speaker fuse?
Speaker fuses are rated in Amps. If you cant find the specs on your speaker via google, (I couldn't find anything on the fuse.) start with a 2 Amp 'slow-blow' fuse. That should work at low to medium volumes. If you find it blows at low volumes, move up to a 4 or 5 Amp fuse. E-715 is a big speaker, (handles 400W!) so starting at 2 amps should be pretty safe.
Feb 11, 2016 | Cerwin Vega Audio Players & Recorders
Can i use another 4a 250v fuse for my cerwin vega LS12 if its not a (slow blow) ,and what would be the outcome
Fuses have different blow characteristics. Such to protect components differently. An extremely fast fuse would protect sensitive components like tweeters and slower fuse will allow transcients to pass and blow on long time fault. If you put a slow blow in place of fast blow, it won't blow as quickly, but it could allow the protected device to be damaged. In reverse, you put a fast blow in place of slow blow, it will blow at normal transcients and be a nuscience to always replace.
You can cross to a fuse of different manufacturer. The reliable manufacturers will have detailed datasheet and subsitute or similar fuse to the fuse you are looking for.
Oct 23, 2013 | Cerwin Vega LS-12 Speaker
Where can I source a replacement tweeter for cerwin vega e-712
the exact replacement tweeter can be purchased from midwest speaker company
google it
Sep 27, 2012 | Cerwin Vega E-712 Main / Stereo Speaker
Is the cerwin vega 3200 MPLIFIER SUPOSE TO BE CONNECTED TO ELECTRICITY?
your amp requires a 12volt power wire from the battery, a negative wire grounded to the car body, a remote wire that connects to the radio or fuse box, rca jacks from the radio, and speaker wires from amp to speakers. hope this helps. please rate 4 thumbs up.
Jan 21, 2011 | Cerwin Vega Vega 3200 Car Audio Amplifier
My husband seems to have blown a fuse in our cerwin vega E712 speaker. please advise the model fuse we will need to replace it and were we can purchase the fuse.
Hey
it's a 2.5Amp Slow Blow 2AG fuse..
Most electronics stores stock fuses..also to being a 2AG fuse they are exactly the same as the old auto fuses and thus most auto stores carry them in stock aswell..
but remember.....Fuses blow for a reason
and NEVER put a bigger fuse in!!!. try and find the fault....unless he has just cranked it too much :-)
hope this helps!,ben
Jan 13, 2011 | Cerwin Vega Audio Players & Recorders
Someone gave me a cerwin vega speaker, supwoofer, found fuse blown,this is a single speaker, lw-10, has electical cord, how do you hook up wiring on speakers?thank you
May 01, 2010 | Cerwin Vega LW10 Subwoofer
Nov 01, 2009 | Cerwin Vega LW12 Subwoofer
I recently purchased a denon av surround re- ceiver avr-2805,and a set of cerwin-vega LS-15, (separetly). When playing a cd though my dvd player, at around 0.0dB and up the fuses will blow in both speakers...
Apr 03, 2009 | Cerwin Vega LS-15 Speaker
How many ohms? 6 ? 8 ?
David,
The AT line were all rated at 3.2 ohms. Any amp or receiver rated to handle 4 ohms loads will work. The fuses and tweeter breakers are sensitive to clipping so most low cost amp's and just about every receiver will cause undue clipping. CV stated that increasing the fuse a half amp would increase the time before blowing the fuse or breaker but that will only cause additional harm to the voice coil.
Chris-
Mar 17, 2009 | Cerwin Vega LS-15 Speaker
Cerwin Vega E-712 Main / Stereo Speaker Logo
324 people viewed this question
Top Cerwin Vega Audio Players & Recorders Experts
 Grubhead
Grubhead
Steve
Joe Lamb
Joe Lamb
Are you a Cerwin Vega Audio Player and Recorder Expert? Answer questions, earn points and help others
