Question about GE (PSS26MSRSS) Side by Side Refrigerator
I hear a whirring noise when the refrigerator is running
  • 593 Answers
Try to find out if the noise is inside or outside (under the bottom). If the noise is Inside, that will be the main cooling fan. Could be from hitting ice or a wire, or age meaning it needs replacing. If hitting ice or a wire will need to be cleared by accessing the evaporator section in the freezer. If under the fridge. pull it away from the wall and remove the back cover (screws) use a vacuum if needed an clean the fan blades, (unplug it first). It may still be due to the age, in which case will need to be replaced.
Posted on Oct 03, 2010
How do I fix ice maker? Reset did not work. Can hear whirring noise but no ice is dropping.
And could you tell me a little bit about your refrigerator like a model number that's found inside? Can you feel down in the ice maker slots and see if there's ice still in there? Are you sure that whirring noise is coming from the ice maker is it trying to move in and vibrating? Be glad to help you if you answer my questions
Nov 12, 2015 | Refrigerators
Whirring noise when engine is running
Power steering pump. low on fluid.
Aug 08, 2015 | 2010 Ford Escape
Dryer makes loud whirring noise when try turn on, won't start
I am guessing that it does not do anything after it makes the noise?. If you hear something running after the whirring noise, but the drum is not turning it is possible the belt has broken or slipped off the motor pully. If you hear no noise after the first startup and it completely stops making any sounds then it may be a motor problem. I am no pro, just a do it yourselfer. www.repairclinic.com can help ya more than me. Just have the model number ready when you go there and look at the symptoms. Hope this helps.
Oct 11, 2014 | Dryers
Not cooling the fan is working. there is whirring noise as if the compressor wants to start but it does not. this noise keeps on repeating
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Sep 08, 2011 | Frigidaire Side by Side 26.0 Cubic Foot...
High pitched whirring noise in motor/fan?
the bearings in the motor are going bad. you probably need a new fan motor.
Nov 06, 2009 | Hotpoint HSM25GFRSA
Ice behind panel in refrigerator and loud whirring noise from refrigerator. also periodically leaks water onto the floor
IF STILL RUNNING OK, MAKING ICE ? ETC ITS PROBABLY THE CONDENSATE DRAIN OUTLET EITHER FROZEN OR PLUGGED ALLOWING CONDENSATE TO FREEZE THUS PLUG
Aug 23, 2009 | Samsung Refrigerators
Louder whirring noise when turning on computer
trumpjd,
Usually on startup the fans work a little harder then slow down. On newer computers they still have noticable fan noise. Most of what ou hear while the machine is running after start up is the power supply fan. When it starts to go bad you'll hear it all the time.
randy320sgi
Jan 09, 2009 | E-Machines eMachines Desktop PC
GE SidexSide PSS26SGPASS Makes Humming Noise
GE refrigs have a variable speed evaporator fan motor that is controlled by a computer board on the back of the refrig. now the noise you are hearing is most likely the fan motor ramping up and down in speed (some of my customers say it sounds like a ghost). if its a continuous ramping up and down then the speed cotroller on the board is bad and must be replaced. if its just an occasional sound then thats normal and nothing to worry over.
Btw the reason the noise stops when the door opens is because the fan shuts off when you open the door.
Dec 19, 2007 | GE (PSS26MSRSS) Side by Side Refrigerator
Intermittent Loud Whirring Noise
sounds like the evaputaor fan motor.. may need to replace.. check to see if anything maybe hitting fan blades
Sep 30, 2007 | Frigidaire FRS23R4A Side by Side...
GE (PSS26MSRSS) Side by Side Refrigerator Logo
326 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
