Question about Ovens
Oven displays FE error and shuts itself off, impossible to get anything to cook!!
    Genius:
  • 1,416 Answers
This error code on a Kitchen Aid range indicates a keypad short on the Electronic Range Control (ERC) board. This is the clock/timer on the operator console. The recommended fix is to replace the ERC. You can generally find replacement parts at these websites:
pcappliancerepair.com appliancepartspros.com
All these sites offer great service with competitive pricing, so shop and compare.
Replacing an ERC is not a difficult repair and can be accomplished by the average do-it-your self offer. If you decide to order the part and wish to repair this on your own, follow these steps:
1. UNPLUG the range. Dangerous voltage is still present inside even with the range turned off.
2. Pull the range away from the wall and turn the unit around so you can access the rear panel.
3. Remove the screws on the back of the operator console.
4. Carefully disconnect the connector plugs to the ERC. Take note of how they are connected, so that you can reinstall them correctly.
NOTE: The connectors are usually color coded with the colors printed on the circuit board. However, if the colors are not printed on the board, write them down. (A digital camera also comes in real handy for this).
5. With the connectors removed, remove the mounting screws to the ERC and the assembly will come out.
NOTE: Most replacement ERC boards do not come with the overlay. This is the plastic pre-printed number display. The overlay can easily be peeled off and re-used. Just make sure you properly orient the overlay so that you don't inadvertently place it on the new board upside down. If your existing overlay is damaged, you will need to order separately.
6. Install new ERC using the steps provided in reverse order. Minimize handling the new circuit board with your bare hands to avoid damaging the board.
thanks
Posted on Oct 03, 2010
I have a GE 24 inch wall oven model number JRS04B0W5BB that when bake is selected the broiler element comes on and then after awhile it looses temp and does not cook anything.
Ovens often use broiler element to preheat, then shut off when set temp is reached. Check fuses for and bake element itself.
Dec 01, 2014 | Ovens
My G.E. oven shuts off by itself
Sounds like an issue with the thermostat . If stove has electronics perform a reset to factory defaults. If that does not resolve the issue look at the thermostat being defective.
Sep 20, 2017 | Ovens
Oven is flashing f10 and burning the top of food being cooked and then shuts itself off
Hello - Typically error code F10 indicates a variety of issues. The range could possibly have a runaway temp (higher than normal temps), shorted keypad, faulty EOC (Electronic Oven Control) or, display wire harness missing/not connected. Usually, this code means to replace the EOC. You may be able to reset the range by disconnecting the power to the unit for up ten minutes. Usually this will clear most false error codes. You can disconnect power by either unplugging the unit or flipping the circuit breaker off and back on. If resetting the unit proves to be ineffective, I would recommend contacting a professional to move forward accurately.
Oct 13, 2012 | Frigidaire 30" Self-Cleaning Freestanding...
I want to use top and bottom ovens but at different temps - how do I do this
To Set a Cook T ime:
1. On double oven models only, press UPPER OVEN or LOWER
OVEN for the one you want to set.
2. Press BAKE or CONVECT UPPER (on some models).
Press the number pads to enter a temperature other than the
one displayed.
3. Press COOK TIME.
4. Press the HR and MIN "up" or "down" arrow pads to enter
the length of time to cook.
5. Press START/ENTER.
The start time and stop time countdown will appear on the
oven display.
On double oven models only, when both upper and lower
ovens are being used at the same time, touch UPPER OVEN
or LOWER OVEN to display the respective cook time.
When the stop time is reached, the oven will shut off
automatically and "End" will appear on the oven display.
If enabled, end-of-cycle tones will sound, then reminder
tones will sound every minute.
Repeat the process by choosing the other option of UPPER or LOWER OVEN
Sep 04, 2011 | Whirlpool RBD305PD Electric Double Oven
Zanussi double oven switches off during cooking. It can be restarted without a problem so fault can not be detected. It displayed error 3 message once.
The shutting down of the oven is due to a defective thermal switch or thermistor. Replacing the thermistor could fix the problem. It is usually located in the inside compartment of the oven and connected to the control panel board.
Dec 02, 2010 | Zanussi Ovens
Where can i get a manual for a built in teba fan oven. It has reset itself and the timer switches off after 2 minutes and I cannot reset to not use the timer so cannot cook anything in the oven.
Try pressing the stop/cancel button, this should clear the error, if this does not work unplug for 5 minutes and then plug back up , this should clear the display and the oven should work.
Nov 14, 2009 | Ovens
Kenmore gas oven
after the gas stove have been on a while a loud whoosh that is a constant thing comes on. I thought it was getting ready to explode. I took seconds after we turned the gas off for the noise to stop. Any ideas what this coud be
Jan 09, 2009 | Kenmore 30464 / 30465 / 30469 Gas Single...
Broiling
it really doesnt matter because the heat transfers directly onto the food therefore you can leave the door open or shut.
Jan 05, 2008 | Equipex PZ-330 Electric Single Oven
F2 error, both ovens stopped working
F2 is a Oven temperature exceeded the clean runaway temperature (self clean only) or the cooking runaway temperature (cooking modes only)
Nov 23, 2006 | Dacor ECD230 Epicure Electric Double Oven
Ovens Logo
51 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
