Question about LG W2442PA-SF 24" LCD Widescreen 16:9 VGA DVI HDMI Tilt Pivot Swivel Height Adjustable Speakers 3 Ye... Monitor
My Flatron W2442PA monitor has not been able to dislay full screen - the viewable area is smaller than the physical screen, about an inch short on each end of the diagnals - since I switched from DVI to HDMI data cable between the graphics card and the monitor. The display setting is system default (Windows 7 Pro) of 1920x1080 at 60Htz. Even more frustrating is that I cannot go back to DVI cable, because the system no longer recognizes it and the monitor simply does not light up when the computer is switched on!
SOURCE: LG Flatron 775FT monitor distortion
Doesn't look very good :( You can try returning to the "factory settings" in your monitor's menu. Maybe try the monitor in another computer to check whether your graphics card is faulty. But all in all it looks like a fault from the monitor :( Good Luck!
Posted on Jul 27, 2007
tomhar
  • 20 Answers
SOURCE: How can I make fonts look good in an LCD monitor ?
The VGA connection should be fine; I have DVI and when I switched from analog, the difference was pretty minimal, to my eyes.
Is it just the fonts that are blurry, or everything? If fonts only, then this almost certainly suggests that running the ClearType tuner again would solve the problem. But this applies to all displays, so if one is good and the other is not, then this isn't it.
If everything is a little blurry, then this suggests one of two problems -- the first, you report trying, which is that the display adapter is set to a different resolution than the native resolution of the LCD monitor itself. Your display adapter should probably be able to drive 2 monitors (the built-in laptop monitor and the external monitor) at once. You should be able to set their resolutions separately.
Assuming Windows XP: Start > Control Panel > Display > Settings > at which point, you should see two monitors listed in a dropdown. Set them to their native resolutions there (using the slider bar, usually all the way to the right), and save.
If you do have the display resolutions set to their native resolutions for both monitors, then it's possible that your external monitor is messed up. A quick test would be to run the on-screen settings, usually from a button on the monitor itself. If what is displayed there is sharp and what is displayed from Windows is not, then this points to a problem with the display driver. If everything, even the on-screen display is blurry, then perhaps the monitor settings are messed up -- usually there's an option to restore to factory settings -- try that.
If that doesn't work, I'm probably out of ideas, unless you have further information.
Posted on Mar 08, 2009
michael_grey
  • 365 Answers
SOURCE: Nothing on the screen at startup
If you cant get into the setup menu then I would think the monitor is defective,you did not state if you hooked up the monitor to a computer that has a vga port that works.
Posted on Jul 21, 2009
SOURCE: Flatron 22" 16:9 occasionally goes black for 1-2 seconds
RAM if under heavy duress when it gets stuck by Page loads , which means " virtual Memory" just dips in . It's like a person who coughs a bit under some common cold simply because it's resistance has gone low .
Kick up some more RAM or use a RAM Booster , or install a " cache" reguling software .
Posted on Nov 13, 2009
  • 31 Answers
SOURCE: 1920x1080 resolution-entire screen not viewable
This also happens to my vga connection to my TV.
I used my tv remote "auto" button to re-size it to fit correctly.
If your monitor/TV does not have the adjustment, you may need to
supply your vga compatible device with your monitor's driver software.
This tells your computer what monitor specifications you have.
Posted on Mar 16, 2010
Testimonial: "Thanks for the info. I was able to solve my issue by switching from vga to dvi connection"
Desktop only partially viewable on monitor
How to fix it depends on what operating system you use. For Windows right click on the desktop and choose Screen Resolution. Look under "What display should I use" and follow the instructions or simply drop the resolution down one step
Mar 18, 2014 | ASUS Computers & Internet
Lg flatron w2442pa buttons not working
This trouble maybe power supply or inverter boards is defective.
first you can test the voltage of the multr,and then check which part is defective.From Wisiny.com can find those parts
if you have any question,please let us know email:service@wisiny.com.thanks,we sincerely hope we can help you!
you can also check this boards whether suit you:
EAY38422105 AIP 0178A LG EAY38422105 Power Supply Backlight Inverter
Jun 20, 2012 | LG W2442PA-SF 24" LCD Widescreen 16:9 VGA...
Good Day, I have an LG Flatron W2442PA. The screen keeps dimming, re-adjusting the brightness etc. Can you please tell me how to fix this?
Power capacitor problem or failing board in the monitor. Best solution is to get it checked out by a professional. I'm assuming you have already tried this monitor on another computer or laptop? If not, try that first, if it then works ok, check the DVI lead and the graphics card on the computer you are using it on
Jul 05, 2011 | LG W2442PA 24" wide LCD monitor, DVI,...
LG 700B SHAPE SIZE AND POSITION UPSET PLEASE HELP TO RESTORE
Push the button on the Monitor to activate the OSD (On Screen Display). With the OSD, one can "stretch" the picture (horizontally/vertically) and "move" the picture (horizontally/vertically) in order to "fill" the viewable area with your compueter's output.
May 09, 2010 | LG Flatron F700B 17" CRT Monitor
Monitor Display Messages Not Viewable
You may have components (capacitors) failure in the power supply circuits which will cause odd symptom.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://www.badcaps.net
http://en.wikipedia.org/wiki/Capacitor_plague
Apr 13, 2010 | LG 22" FLATRON LCD Monitor
Mar 16, 2010 | ViewSonic X Series VX2260wm 21.5"...
The viewable area is bigger than the screen. I
You probably need to go into the control panel and change the resolution for your display
Mar 12, 2009 | ViewSonic VP920b 19" LCD Monitor
Jul 25, 2007 | LG Flatron 775FT 17" CRT Monitor
LG W2442PA-SF 24" LCD Widescreen 16:9 VGA DVI HDMI Tilt Pivot Swivel Height Adjustable Speakers 3 Ye... Monitor Logo
513 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
