Question about Microsoft Windows Server Standard 2003 for PC
RPC Service not running
I have a terminal server & the other client connect throw Remote Desktop,last one days I have a problem, when they r try to connect the error "RPC Server not avalable" comming, i serach on services and i see the RPc not running and unable to restart it, also the remote desktop sesson manager also stopped. Help me out..
  • saikatsen432 May 27, 2008
    Help me
  • crnokosa_89 Feb 11, 2009
    I tried to install my printer but it was impossible mission for my PC and me because my RPC server was not running... i can't fix that problem and I need help. i tried to restart service trough control panel/services but there is everything OK. i really need a help. tnx
Please restart the service of RPC.
Write the script for RPC services by the help of google ur problem will be shortout .
Posted on May 28, 2008
  • 20 Answers
Log on to Server as administrator, got to start menu and select server management, select internet & e-mail, and re-run configure remote access. this should reconfigure/repair RPC
Posted on Feb 15, 2009
I have installed hp laserjet 1000 on server 2003.I have shared this printer to my network.I am even able to print from client machines remotely.But one of my client machine shows 'The RPC server is...
RPC service may not be available or started on the client machine.
To start/ enable it go to 'Run Command' and type 'services.msc' , locate REMOTE PROCEDURE CALL (RPC) and start the service.
Dont forget to appreciate the solution if I could have been of any help!
Dec 07, 2010 | HP LaserJet 1020 Printer
Port Forwarding On Linksys RV016
it's a rather lenghty explanation so please go to this site and follow the instructions...
Please rate this solution ... thanks
Sep 08, 2008 | Linksys RV016 Router
Hi. I want to set up a server and run dumb terminals (thin clients) off of it. Can anyone give me a basic run-down about how I do that?
You would setup Windows Server. Windows Server 2003 and 2008 Small Business Server comes with a license of Terminal Services Server.
You would first need to setup your Windows Server. Install it according to at least minimum requirements.
Make sure you assign this server the correct role. If this is the primary server and if you intend on hosting dns and dhcp on this machine, then please make sure you are assigning this server these roles.
You will need to create user accounts so that you can log into from your thin clients.
Next you need to run the install for Terminal Server.
Next you need to configure each thin client.
Next try to access each thin client via Remote Desktop as well as the server.
This is the basic run down of the process. If you do not know how to setup a server then you will need to ask that question as this is very detailed. Also you will need to be more detailed in your question as to whether this is a linux based network or a windows based network.
Hope this helps. Please don't forget to give me a good rating as well as your vote.
Apr 02, 2010 | Network Computing Devices (NSH800S/A)...
Cant install driver with "rpc server is unavailable" and also shows both the se and se sec family in device manager.
Have you gotten an RPC error lately? They look a little like this:
- "RPC Server is Unavailable"
- OR "The RPC Server is too busy to complete the task"
- Here's the best one, "Access denied"
This is fun stuff. Unfortunately, an RPC error is one of the most common errors out there, and most of us don't even know what RPC is.
What is RPC?
RPC stands for "Remote Procedure Call." This probably still doesn't tell you much. Let's see if we can put this in non-technical language. RPC is the go between of your computer and server. This is what allows your computer to access a network.
RPC has two main parts to it: the client and the server. When the client (the program requesting something) sends a message to the server (the process that takes the order or performs the task), it is being asked to execute a certain procedure. The client waits for the server to process the call before resuming the execution.
Why Won't the RPC Server Work?
Usually, the RPC error pops up because there is some sort of miscommunication between the computer and the server. Most of the time, the wires get crossed somewhere due to Internet components that are not configured or activated. Sometimes it is just a matter of adjusting the Internet Firewalls or Proxy Server.
Quick RPC Error Fix
One way to investigate an RPC server error is to verify that you have enabled the DCOM Tunneling is enabled and not being blocked by any third party Internet Security programs such as AVG, Norton, McAfee, etc.
To do this:
1. Go to Start and Run
2. Type in DCOMCNFG
3. Click on Component Services
4. Click on Computers
5. In Computers, right click My Computer
6. Choose Properties
7. Go the Default Properties tab
8. Check the "Enable DCOM" tab
9. Go to the Default Protocols tab
10. Click Add
11. By the Protocol Sequence move the down arrow to Tunneling TCP/IP
12. Click OK
13. Click MoveUp button until Tunneling is at the top of the list
14. Now you may select SPX and Remove
15. Click OK or close the program out
16. Restart the computer
When You Need Help with the RPC Error
The RPC Error is such a common error, it seems like it should be easy to fix. However, the DCOM Tunneling fix is only the beginning of troubleshooting an RPC server error. The good news is that you really don't have to do anything when it comes to an RPC error if you maintain your computer with registry maintenance tools. Try researching the benefits of a registry cleaner to fix RPC errors.
Optimize-Your-PC, with its Advanced Registry Cleaning Technology, will repair an RPC error, and Speed Up Your PC, all in under 2 Minutes.
Jan 21, 2010 | ATI RADEON 9200 Graphic Card
Remote Procedure Call (RPC) service terminated
do one thing ...
start the system and make sure you are fast
when the system starts up click on the start > run > type > services.msc
in the list find the remote procedure call ( RPC ) and double click on it > click on the tab that says recovery > and than make sure the failures say take no action and than apply and click ok
Dec 23, 2008 | Toshiba Satellite A75-S231 Notebook
Getting connected
Build a Windows server with DHCP and DNS and install Terminal Services. Open config on the winterms and setup the RDP client. Follow the prompts, it's pretty straight forward.
Term Service requires license after 90 days AFAIK, so you better have a plan by then.
Thats the easiest way to setup and connect, it is a far from complete solution, though.
I would suggest you google upgrading the winterm firmware using FTP, the older firmware is poor and slow.
Otherwise, these are great little termianls that will last forever and work well.
Mar 17, 2008 | WYSE Winterm 3350SE Network Terminal
Printing throw terminal server
Are you remoting into your server from a differnet location than where the server is? I need to know th physical location of the printer to the server. If the printer is connected to the server there is a problem with the driver. if the printer is connected to your local PC you will need to click on the options button in remote access and tell it you want to use local resorceses. If the server / Printer / PC are in the same location do not access the server thru terminal services, set it up as a client server.
Dec 25, 2007 | D-Link Express EtherNetwork DP-301P+ Print...
"The RPC server is unavailable"
I?m assuming this is happening on a Windows machine. This is one of the really vague error messages that Microsoft give for an incredibly large number of problems. I typically see this on servers but have seen it occur on workstations. If you?re running XP, 2000 (server or Pro), or 2003: - Check and make sure your Remote Procedure Call Service is running. - There is an older vulnerability that tries to use a flaw in the RPC services. It is fixed if you copy of Windows is up to date so make sure it is. - Review your application log for any clues. If you need more assistance let us know your operating system, if it is fully patched and what is showing in your log file around the time you receive the error message.
Jul 07, 2007 | ASUS P5S800-VM Motherboard
Microsoft Windows Server Standard 2003 for PC Logo
1,486 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
