Hi, How can I test the performance of an Apple G5 Tower computer? Thanks Avinash
    Master:
  • 515 Answers
There are bench marks criteria for hardware performance under all sort of operations on those hardware review site such as Tomshardware. So you will know which application is most resource consuming LOL. If you don't want to get those application, you can run all the program you will ever want to run at the same time.
Posted on Oct 03, 2010
Testimonial: "Quick answer and very helpful. Thank you."
G5 revs but won't turn on
possible bad cpu fan or system fan..................meder's tv service
Feb 21, 2013 | Apple iMac G5 Desktop
My Hp proliant Ml110 g5 server powers on, but shuts itself down while the OS is booting - win 2003 server
Perform a RAM test to check every section of the memory. It might be hitting a bad sector when it loads the OS.
Oct 18, 2011 | HP ProLiant ML110 G5 (444809-001) Server
My G5 tower is no longer recognising my external iSight camera. The only thing that happened was that I switched the G5 off and on again, it was working fine previously. Can you help? Many thanks
Best thing you can do is to determine whether its the port or the camera.
If you go to the Apple in the upper-left corner, and go to "About this Mac", then click "More information", it will start System Profiler. On the left side, under "Hardware", click on "Firewire" and see if your iSight shows up. If you have another FireWire device, plug it in, and see if it shows up there as well. The solution could just be a dead iSight (hopefully!). The worst case scenario is a dead FireWire bus...
If you have a dead iSight, I'd guess that ebay would be your best resource at this point. If its a dead bus, I'm afraid it won't be terribly cost effective to fix it :-/
Jan 06, 2011 | Apple iMac G5 Desktop
17" iMac quit working
Your Imac may be one of those affected by Apples purchase of inferior capacitators from Taiwan. If you are less than 3 years from the purchase date, apple will repair the problem for you for free. Just take the unit to your nearest local Apple Genius or tech. If you are outside of the repair extension guidelines, I have provided a link here which can show you or someone more skilled how to repair the problem. Ordering a new motherboard and power supply will set you back a lot of money, however the following guide and pdf give you step by step instructions on how to ressurrect your dead imac without speding more than $100.00. I was able to repair my imac using this guide and it was worth it to save a $2k computer that was only 3 1/2 years old. Check it out:
the following information (in italics and bold)  is taken directly from: http://www.jimwarholic.com/2008/07/how-to-repair-apple-imac-g5.php.  (this site is complete with instructions, manual and the full compliment of materials available at an extremely affordable and fair price. I took a chance and repaired my own, it is not as hard as it sounds1)
The iMac G5 Repair Extension Program for Video and Power Issues applies to first generation iMac G5 computers that have video or power-related issues as a result of a specific component failure. If your iMac G5 is exhibiting any of the symptoms listed below and your computer's serial number is within the noted ranges, your computer may be eligible for repair, free of charge. If Apple or an Apple Authorized Service Provider (AASP) determines that your iMac G5 computer is eligible as part of the program, the repair will be covered by Apple for up to three years from the original date of purchase even if your iMac G5 is out of warranty.
This is a worldwide Apple program.
Affected systems will exhibit one of the following video- or power-related symptoms:
Scrambled or distorted video
No video
No power
Note: If your iMac G5 is not experiencing any of these symptoms, you do not have to contact Apple or any Apple Authorized Service Provider.
Which iMac G5 computers are affected by the iMac G5 Repair Extension Program for Video and Power Issues?
The program is available for certain first generation iMac G5 models that were sold between approximately September 2004 and June 2005 featuring 17- and 20-inch displays with 1.6GHz and 1.8GHz G5 processors.
The affected iMac G5 computers have serial numbers where the first 5 digits fall into the ranges noted below.
Serial Number ranges:
W8435xxxxxx - W8522xxxxxx
QP435xxxxxx - QP522xxxxxx
CK435xxxxxx - CK522xxxxxx
YD435xxxxxx - YD522xxxxxx
Some second generation iMac G5 computers have serial numbers that fall within the upper band of the ranges listed below. Only first generation iMac G5 computers are affected by this program.
Where do I find the serial number of my iMac G5?
The 11-digit serial number is located on a label under the foot of the iMac G5. There is a bar code underneath the serial number.
To view the label, hold the sides of the iMac and gently lay the computer face down on a soft, clean towel or cloth.
Is the iMac G5 Repair Extension program available for other Apple computers?
This program applies only to the systems noted in this FAQ. Other versions of the iMac G5 line are not part of this program. Click here for more information on how to identify iMac G5 models
Free guide for how to repair the motherboard capacitors, rescue the hard drive and more.
http://www.jimwarholic.com/docs/Repairing-Apple-iMac-G5-Motherboard.pdf
Feb 22, 2009 | Apple (661-2795) for iMac Motherboard
The USB/ Fire wire connections do not work with my Apple display
try updating the drivers sounds like a software issue conflicting when putting other connections in
actionman
Feb 22, 2009 | Apple Cinema HD Display30" Flat Panel...
G5 Desktop icons, cursor: horizontal lines
Hey Kim,
You most definitely have a video card problem, I have seen it many times. The AHT is different for each Macintosh, which version are you using? let me know the serial number of your computer and the version and I will tell you the correct AHT to use.
Feb 18, 2009 | Apple Power Mac G5 Desktop
Imac g5
HI, read through this Apple artice, I hope it helps. Please rate if useful, thanks!
http://docs.info.apple.com/article.html?artnum=106156
Dec 02, 2007 | Apple iMac G5 Desktop
Computers & Internet Logo
77 people viewed this question
David Payne
David Payne
