Question about ASUS M2N-MX Motherboard
I need to know that what's the connection point for audio and mic out for front pannel connction.
  • ASUS Master
  • 7,733 Answers
Go here and get Support.
Post back!
Posted on Oct 03, 2010
Hi! i am using Intel DG33FB motherboard, i need the information about the connectivity of front pannel audio. for this it is Realtek HD audio port. i am having 5 cables set for the front pannel...
The L&R-Ret2&3 are common so only one needs fitting so for the speakers you only need to connect 3 cables. R-Out, L-Out and one return (either L of R). I'll comment back shortly on the mic pins for you.
Dec 23, 2010 | Computers & Internet
I want to know where the connection points are on the motherboard for the front mic and audio jacks. I have a epox ep-5pdaj motherboard. Will you send me a diagram please.
close to the back panel of the mainboard, below the back i/o connectors and 3.5mm audio jacks.
You need to remove the two jumpers from the pins, this is where you connect the front panel audio connector, if your case has each wire separate. then please look at this webpage http://www.intel.com/support/motherboards/desktop/sb/cs-015851.htm look at the part "For AC97 Front Panel Audio" PIN 1 should read MIC. If not, then scroll down, you are reading the wrong part of the page.
Aug 07, 2010 | EPoX EP-5PDAJ Motherboard
Front panel Mic not working when connected to Mother Board
Yeah,sounds like the case wasn't designed for that board. Just carefully double check the pins in the manual for the board. If you don't have the manual,check the asus site.
Jul 10, 2009 | ASUS Computers & Internet
I can't connect my Front audio?
connect ur front audio panel to *********** Board...May b u need ur mother Board Mannual for this
Mar 22, 2009 | Abit GD8 Motherboard
Mic dont work
luis_antonio, did you try to set your mic up from within windows?
Do this, open control panel, than open sound and audio devices. Click on the voice tab, click on the test hardware button.
Follow the on-screen instructions. Do you have mic?
There is no direct connection to the board. There is a connection for a front mounted case sound & mic connector if your case has this feature but chances are if your mic does not work connected to the rear of the board it will also not work with the front connector/jack.
Let’s check two other places first. While having opened the sound and audio devices window, click once again on the Voice tab if not already opened. Notice the Default device, (the name of the device). Click the Audio tab listed there is a Default device, (name of device). They should be named the same. Click cancel to close that window. Than open the system icon. System Properties will open. Click the hardware tab, than click the device manager button. Scroll down the list to Sound, video and game controller. Click the + sign & all the audio devices will open for you to see. Do you see a yellow ! point? If yes your sound device software needs to be re-installed. If no & you see a device named ADI AD1986A SoundMAX or AC97, than your current sound device is setup correctly. This device name above should match what you saw while in control panel's sound and audio devices. If after doing another reinstall & running the setup for mic through windows control panel still fails than the integrated sound chip on the motherboard is defective. If your board is under Asus three year warranty, return for a replacement board. If your warranty has timed out, than buy a PCI sound card & install onto a opened PCI slot.
Good Luck!
Have more questions? Feel free to ask.
Mike
Mar 17, 2008 | Intel Motherboard
Hi i have a problem connecting the front pannel mic and standard audio connections to my winfast k8m890m2ma motherboard the manual shows where the 8 pin "front audio connector" is like this...
It is a bit of a problem when you have single connectors but here goes. You use the Front Audio connectors. The manual says you have :::.:
If you turn the board round until the dots are the same way round as above. Working from left to right.
Bottom row. MicIn, MicBios, SpkoutR, empty,SpkoutL
Top row GND, empty, returnR, blank space, returnL. Now this is the tricky bit. Try the power if it works OK. Because the board and the case manufacturer work to different descriptions, try this as an alternative. You may have to swap over the two connectors for GND and Mic Bios.
Mar 10, 2008 | Computers & Internet
Plug mic and earphone to the front panel
hi!gud am...hope this will help...
have you check if your audio controller is working?have you installed the driver?if not check this out...start>control panel>system>hardware>device manager>sound,video and audio controllers...
is your mic and earphone new?if not try to replace it with a new one maybe its broken that's why its not working...
check if the front panel audio is connected on your mobo...some casing with front panel audio has no connection...let me know what you see and tried ok?
goodluck...
Feb 28, 2008 | EPoX EP-4PLAI Motherboard
Mic port not working
1. Check the Audio I/O settings in Realtek Audio Manager in system Tray Icon on Taskbar,
2. Try to connect your Mic to Front pannel of system Unit.
or Reinstall audio Drivers.
Feb 22, 2008 | Intel D101GGC Motherboard
Mic
If your headphones have a single plug you cannot plug these into a regular speaker connection or headphone connction and get mic and sound, you will need a headset that has 2 separate plugs (one for Mic and one for headphone) or a splitter you can get a radio shack. Most headsets have only one plug and there are connections for both the mic and the headphones on this plug, but the headphone connection on the computer has only connections for the headphone and therefore cannot detect the microphone.
Feb 20, 2008 | E-Machines eMachines Refurbished EMA...
Front sound and mic pins
Hi, The motherboard connection points to the front panel audio jacks are shown in the diagram below. It was cropped from a page of the user's manual. A downloadable version of the English version of the User's manual is at http://dlsvr01.asus.com/pub/ASUS/mb/socket775/P5RD1-VM/e2440_p5rd1-vm.pdf Hope this be of help to you. Post back how things turned up or should you need additional information. Good luck and kind regards.
Oct 05, 2007 | ASUS P5RD1-VM Motherboard
ASUS M2N-MX Motherboard Logo
22 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
