Question about Toshiba Televison & Video
Toshiba 50H71 Projection TV
TV is blurry but gets better when it has been on for awhile. Picture is still shaky with audio going off and on while the picture shakes.
    Genius:
  • 1,139 Answers
I would check the power supply and the tuner section. This sounds like the low voltage powers supply is going bad or that the tuner section might be going bad. Does the picture fade to snow? Also I would suggest that you let a TV Technician take a look at the TV to determine what is happening. Most likely it is the power supply.
Thank you,
I hope this helps,
Shuttle83
Posted on May 27, 2008
Why are my photos blurry?
There are only three reasons photos look blurry: poor focus, shaking the cameral during the shot, or trying to take a photo of a fast-moving subject with a slow-speed camera.
You can usually see focus problems on the display before you take the picture, so that doesn't appear to be your issue. On the other hand, movement of camera or subject happens during the shot, so you'll only see that in the completed photo.
Camera movement first. Many cameras today have built-in "anti-shake" circuits that sense when you're the problem -- you're moving the camera during the shot. The best ones are very good at eliminating shakiness, but even they can't overcome large movement, as when you mash down the button to take the picture. If yours doesn't have anti-shake, or it isn't very well implemented, you'll just have to practice pushing gently on the button and holding the camera very still until it finishes the shot.
As for subject movement -- well, more sophisticated cameras offer ways to capture kids bouncing on a trampoline with a minimum of blurriness, but it's always going to be a problem.
If you don't want to switch to one of the more sophisticated cameras from a major brand, practice holding the camera steady during every shot and avoid shooting fast-moving subjects.
Jun 19, 2014 | Polaroid m737t Digital Camera
Picture is shaking during live events
If its just live events, I'm going to assume its your cable/satellite provider. If you watch blu-ray, DVDs and it doesn't shake your TV is fine.
The first step is to determine whether it's the LCD display, the image or the video feed from your cable or satellite provider. Make sure all your connections are secure and not
To test the LCD display, open your menu options to see if that shakes. If it doesn't then it's not a hardware problem and your TV is fine.
If your menu does shake, unplug everything from the TV. You will need to test if you have possible inference from other devices. One by one plug your devices in and view the menu for it to start shaking. This is one possible solution to the shaky image.
Again, other possible solution is your cable or satellite providers feed is shaky. You need to call them and inform them of the issue. A replacement receiver could solve the issue.
Jan 07, 2011 | Televison & Video
Lines and blurry screen
hi, sounds like u need some solder joints re-worked (probably quite a few for a set that old, but your right it`s a great set), price varies by region greatly, I`m in central florida we would charge 75 for service call & 95-125.00 for labor depending on how long it takes to do the solder rework, hope this answers your question, get it fixed it`s waaay better than the new hd (ha ha ha) sets, video-tek
Jun 02, 2009 | Hitachi Televison & Video
My toshiba big screen tv is shaky and blurry
most likley your problems are on the hyper board in the set
it will sorta dance at the top and be shaking back and forth at a fast rate
it would require the hyper board being repaired or exchanged
you would most likley wont to locate a professional in your area to assist with this repair
average repair is 280 to 320 in my area
Jan 20, 2009 | Toshiba 57H81 57" Rear Projection...
Picture very blurry with lines going accross screen
hi gud day! your problem has a solution. Just try to fix your tv from blurry picture. Pull the socket at hte back of the picture tube. remove the socket from pcb(printed circuit board) de solder the pins. then after that, if you see a 2 metal formed like a small mountain facing each other, try to clean those remove the rust (green color) using sander or any material you can use, just avoid using oil on that bcause it is sparking. then try to install it again and try to turn on your tv. if still not working replace that socket with a new one. you can buy it at any electronic supply store. and re install then on it again.. surely it will fix your tv without expensive components.
be sure unplugging the tv from ac souce before disassimbling...
thanks,
janex
Mar 31, 2008 | Sony KP-61HS10 61" Rear Projection...
Blurry pictures
try having other people take a picture with your phone, if they can take a more clear picture, it is likely that you are just a little shaky when taking pictures (i have the same problem)
Jan 31, 2008 | Motorola Mobility L6 Cellular Phone
TV picture shaking!!!
It sounds like the Hyper board is begining to fail....Does the menu shake too?
May 16, 2007 | Toshiba 50HX70 50" Rear Projection...
65 Inch Samsung Projection TV- Shaky Picture
have a tech look at your tv it needs to be repair checks can be made in the power supply.video circuit,or the IF CIRCUIT.good luck.
Apr 01, 2007 | Samsung HCN653W 65" Rear Projection...
Televison & Video Logo
138 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
