Question about Maytag CWE4800A Electric Single Oven
Won't turn off
Last night after cooking a peach pie, then a ham & potatoes I turned off my oven. When I turned it back on to make bisquits it made an electrical zap & the lights in my house flashed. After the biscuits were done I turned off the oven (so I thought) but it stayed on w/ the fan running. We had company over so I really didn't notice it until later. The oven looked like it was off but it was still heating. We got the oven/fan to turn off but it started up again on it's own. I think it probably never shut off but the fan came on again to cool it down. I tried taking out the fuse & left it out all night. Today, I put it back in & the oven started up by itself. I thought I had it turned off again but apparently it was only the fan since the elements were hot. I even tried taking out the breaker that turns the electricity off to the entire house hoping that would reset it...but to no avail.
  • hulaflop May 27, 2008
    I'm thinking you are right. I will call a repairman. Thanks for the help!
  • 525 Answers
Sounds like maybe a wire burned off of an element terminal and shorted to ground. This would bypass the thermostat, so to speak, and continue to heat at 1/4 wattage. The only way to control this failure would be to turn off the power to the oven, but it won't reset until the burned wire is repaired.
Posted on May 27, 2008
Bosch wall oven (electric) heats up but baking 2 pumpkin pies & 1" cubed sweet potatoes took over 2 hours, crust still doughy and not browned, potatoes cooked but did not brown.
Have you checked your elements? They could be going bad otherwise your oven control board is going bad and needs to be repaired. The Repair Shack offers a service which can fix this issue of the problem is in fact the Conteol Board. Check your elements first and then give them a call, they will be able to save you some money on the element(s). Otherwise they can help you get the control boards repaired.
Nov 28, 2015 | Bosch Ovens
My oven won't warm up. I was cooking some oven chips last night when the electrics tripped in my house. I reset the electrics, however my oven lost its heat and started to cool down. I turned it off and...
The problem will be the oven ele3ent has failed, a very common event.
It is located at the rear of the oven behind a removeable cover.
Make sure you have the power off.
Please rate my solution.
Thankyou.
Feb 03, 2010 | Whirlpool Ovens
F-10 code and continuous beeping
Your board is going bad
Aug 25, 2009 | Ovens
Oven not heating
you could have lost one of your 120v leads to the machine. that could cause it to work only half way. go turn the breaker off and then turn it back on and see if that corrects the problem.
Dec 07, 2008 | Hotpoint SY36 Style Line Stainless Steel...
Whirlpool oven accubake system
I have a whirlpool accubake wall oven. Half-way through baking a pie ,unknown to me, the oven went to the self-clean mode , the door locked and the pie started to burn. I tried to turn the oven off but it would not cut off. I immediately ran to the house's main power and turned off the oven breaker. I waited for a short time to let the oven cool enough to open the door and get the burned pie out, then went back to turn my breaker back on and the oven (even though in the off mode) started heating again with the bottom unit turning red again. I had to then go back and pull the power. We tried this several times trying to push the off button but the oven will not go off until we throw the breaker. Help please!
Jul 01, 2008 | Whirlpool RBS245PDS Electric Single Oven
GE Profile JT952 Double Wall Oven doesn't heat up adequately
If your electric2_bing.gif oven is not heating then you probably have a bad heating element in your oven. This is not that hard to fix yourself...
Check out this tip that I wrote about the Oven not heating problem..
Oven Problems Electric2_bing.gif Oven is Heating Slowly or Poorly
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
May 29, 2008 | GE Profile JT952 Electric Double Oven
Dacor single convection oven will not turn on.
Turn your breaker off and back on. If you only have half voltage everything but the elemnets can come on.
Apr 24, 2008 | Ovens
F10 error code
Need model number please. It should be behind drawer on left or right.
Nov 22, 2007 | Kenmore 40494 / 40495 / 40499 Electric...
Maytag CWE4800A Electric Single Oven Logo
263 people viewed this question
Top Maytag Ovens Experts
Dan Webster
Dan Webster
Oloyede Monsuru
Mack Baxter
Are you a Maytag Oven Expert? Answer questions, earn points and help others
