Question about LG Dryers
My condensing dryer trips my house circuit breaker,iread the manual,it says there are 2 fuses.is that the problem?how do i get acess to these fuses
  • 489 Answers
There are no fuses inside the dryer that you can service. It does sound like the problem may be in the circuit breaker. Try doing a load and running the plug to a different outlet. You may have to use a heavy duty extension cord.
Good luck
Posted on Oct 04, 2010
What does the Code C3 mean on my Asko Dryer
Here is the list for the DRYER not sure what model... guys please post MODELS!!!!!!!!!!!!!!!!!!!!!
Asko
Dryer
Failure Code Condition Check/Repair
F1 Condensate drain overfilling.
1. Check condensate reservoir pump and drain tube.
F2 Maximum drying time exceeded (3hrs) 1. Check for tripped circuit breaker or blown fuse
2. Check ductwork for lint build-up
3. Check hi-limit and cycling thermostat
4. Check heating element
F3 Thermistor fault 1. Open thermistor, replace
2. Bad wiring to thermistor
F4 Too much lint in the lint filter, front housing, or in the condenser.1. Clean lint from lint filter and/or condenser
F5 Fault in the moisture sensor · Lint covering sensor in front of housing1. Bad sensor
2. Bad wiring to sensor
Sep 26, 2014 | Asko Dryers
When drying the laundry,(Miele T7744C) water does not get into the properly closed condenser unit at the top anymore but is accumulating on bottom of the dryer, I hear it sloshing under the drum. Also some...
test this steps and fix it. God bless you
Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected.
Heating Element
Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it. The proper ohm reading can be found in the service manual or sometimes on the tech sheet located somewhere on your dryer (9- 13 ohms is a common reading). Electric heating elements aren't repairable.
Thermal fuse / Thermal Cut Out / Thermistor
On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel or behind the front cover. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing They are also round and made of metal and plastic. The thermistor is located on the blower housing usually. If any of the fuses do not have continuity replace it. Check for continuity if none replace, But before replacing check for obstructions. The fuses are very inexpensive
Wiring
A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. Check all connections, make sure they are tight. Loose connections can lead to a fire. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
Jul 31, 2013 | Miele T7744C Dryer
WHERE IS THE HOUSE FUSES LOCATED?
If you're reading your manual and it refers to "house fuses" they are the fuses or most likely now circuit breaker in your "house" that supplys the voltage to the dryer. In other words, check your main electric panel for a tripped breaker or blown fuse.
Jul 17, 2010 | Frigidaire FGQB4000F Dryer
Dryer runs but does not get hot to dry clothes
Hello there:
There are a couple of things to check if the dryer does not heat properly
There's no heat If your dryer doesn't heat, check these: Power from the house Heating element Thermal fuse Wiring Power from the house Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected. Heating element Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable. Thermal fuse On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.)
Feb 27, 2010 | Dryers
Dryer will not heat up
Hi fairiesinfli,
Check the below:
Heating element
Thermal fuse
Regards
R.K.
Oct 22, 2009 | Whirlpool Dryers
Heating element
Thermal fuse
Wiring
Wiring A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
Aug 05, 2009 | Dryers
Not heating
Heating element
Thermal fuse
Wiring
May 20, 2009 | Dryers
No heat
No heath can be caused by a faulty element, a faulty thermistor, thermal fuse/ circuit breaker, or a problem with control switch.
See here There's no heat:
Heating element
Thermal fuse
Wiring
Wiring A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.From Repairclinic
You can also find diagrams and spares here.
If you need to call a repairman use the phone number listed on the owner manual.
Sep 27, 2008 | GE DCSR483EA Electric Dryer
Gas dryer is not heating
Heating element
Thermal fuse
Wiring
Thanks Repairclinic
Aug 25, 2008 | Dryers
My Roper Electric Dryer will not heat
i am sending you all the possibilities for your problem, check either of these causes ----and than let me know if it is solved----
Heating element
Thermal fuse
Wiring
Mar 07, 2008 | Roper REX3614KW Electric Dryer
Dryers Logo
70 people viewed this question
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a LG Dryer Expert? Answer questions, earn points and help others
