Question about Dishwashers
I have a foul odour in my dishwasher and a few hours of dishes sitting. I don't want to run the dishwasher every day. My dishwasher is a Bosch. I haven't even had it a year yet. What can i do
  • 51 Answers
If you have a garbage disposal make sure your drain line is higher than where it comes out of disposal, also make sure all water is being drained out. Befor next time add some vinager and or lemmom juice run with out any dishes, also put cut lemmons into your disposal over night then in the AM top off with ice cubes and run for 30 seconds, the citirus will kill the oder and the ice will sharpen the blades.
Posted on Oct 03, 2010
Our Bosch dishwasher always has condensation after completing the cycle. Is there a reason for this?
I have noticed the same with our bosch dishwasher. Once the unit finishes washing, it sits there silently for about 1/2 hour and then exhausts the hot/moist air through the drain pump and illuminates the "clean" light. With the tub still hot, I open the door and prop it open a few inches with the top rack for a few hours. Since the tub is still very hot but open to the much cooler air, a lot of that condensation will leave the clean dishes. A few hours or even overnight should do the trick! It isn't a perfect system but beats having that coil heater in the bottom to warp all of your plasticware.
Aug 13, 2017 | Bosch Dishwashers
Bosch SHX33A05UC/36 dishwasher seems to run for hours to do a load of dishes. Checked water temperature, drain and hose and all is clean. The rinse and hold cycle times out correctly. Is it a timer or...
No, the problem in not the unit, it is programed to run up to 3-3 1/2 hours for a single cycle. You can select quick wash to shorten this time down, but this is not a problem with the unit. It wants to assure you have clean dishes and hot enough water to complete the program.
In testing one a few days ago, I ran into this same problem, I reread the time charts and cycles and found this to be normal for this manufacture.
I hope this answered your question.
Aug 13, 2011 | Dishwashers
There is always condensation on the inside of the door and some water on the floor of the machine after washing. The main thing is the foul odor that is inside the machine after a day of sitting with...
Check your heating element..
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
Asker's Testimonial " explanation very clear. will give it a go and seehow simple it was. thanks Ronnie " - ronnieshomes
Sep 20, 2010 | Bosch Dishwashers
Foul odor coming from Miele dishwasher
hi,
if you put the unit on the hottest wash this will kill off the odour. after each wash leave the door open for about half an hour so it dries out and doesn't smell. Also make sure the filter is clean and the door seal is clean. this should all help with the odour
Aug 22, 2010 | Miele Incognito G818SCVi Built-in...
I do not leave dirty dishes in my Bosch dishwasher more than a few hours and do a load every other day. However there is always a 'rotten' odor in it. I've tried washing it with baking soda but that...
Clean out the pump filter (located above the pump) then run the machine with a large measuring cup full of vinegar first then, dishwashing soap nothing else no other dishes for the two loads.
Jun 22, 2010 | Dishwashers
Mold grows on dishes in bosch dishwasher
Put a bowl filled with 2 cups of clorox on the lower rack and run a wash cycle (nothing else in the machine) this will kill the mold spores in the machine, and clear the smell.
Jul 29, 2009 | Bosch 24 in. SGS45E02 / SGS45E08 Exxcel...
Bosch dishwasher will not drain - causing moldy odor
Hello Mimhoff it depends on how much water is down there. The sump area always has a little water in it to prevent the circulation pump seals from sticking. Usually around 1 to 2 inches. If there is more than that, check the slots at the bottom of the sump on the left side for being clogged and check the end of the drain hose to make sure it is clear. If you are getting a moldy/odor from the dishwasher, try running Dishwasher Magic or Tang thru the dishwasher. This will remove any build up of food or detergent from the dishwasher. If you are running the dishwasher every few days and just scraping your dishes, then either leave the door ajar or run the rinse & hold cycle to help keep the odor down. Bosch doesn't reccommend running bleach thru the dishwasher as this can cause damage to the rubber seals. However 2 tablespoons of bleach once a year won't hurt.
Feb 01, 2008 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
Dishwashers Logo
76 people viewed this question
Top Dishwashers Experts
