Question about Panasonic MC-V5710 Vacuum
Panasonic Vacuum mc-v5710. Was working fine and motor just quit. Sat overnight. Came back on for a few minutes and now quit again.
  • 3 more comments
  • jfkeenan1 Oct 03, 2010
    Does this mean the motor is going out? Would you suggest just looking for a new vacuum? Sending in for service sounds expensive as well. I do love this vacuum however.
    Just checking if anyone has additional advice? Should I consider just purchasing a new vacuum rather than sending this one in for service? Panasonic MC-V5710
    Thanks for your help. It just came on again but sounded strange, like it was laboring. Now it won't come on again. Sounds like the motor is not moving freely when it comes on. Is there a way to grease the motor, or is it just shot? Your info has been very helpful.
    The brushes are in good shape so don't think that is it. The last time I turned it on and the motor came on, I only ran it about 5 seconds and then I turned it off. I then turned it back on immediately and wouldn't come on.
    If the motor is going out, would it make a straining sound when it does come on? The hose is not clogged and the agitator is turning too.
    Thanks again for your help.
    You helped quite a bit. I didn't know the motor would come back on if it was burned out. I kinda thought if it was the motor, it just died and that was it. Thanks again!
  • 10,515 Answers
In Panasonic vacuums, there is a thermostat protection on the motor. It will automatically shut off the motor if there is no airflow through the motor. This is typically caused by a clogged hose. Typically, if your dust container is that full, there could be backup in the hose. Or the dust container being too full could also or otherwise be the problem. Check your hose for blockage, let the machine cool off, it should start up again.
If problem persists, you could check the thermal cut off but from your description, it seems unlikely this has tripped out. It is common for the cord to fail and I would suggest that this is the first thing you need to check. You will need a multimeter to start checking the items, such as the on off switch etc .It could be a faulty motor, but as i mentioned the above causes could be a problem.
However, the repair is never worth on most of these models.If you could follow DIY ( do it yourself ) , then it would be the best.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Oct 03, 2010
  • 1 more comment
  • taran_2005
    taran_2005 Oct 03, 2010
    Thanks for your response!!
    To start with, grease would not help at all.
    This sounds like the motor is overheating. The motor is protected by a thermal fuse which cuts the power until the motor cools and then restarts when cooler.The thermal fuse is embedded in the motor windings or very close to in a small holding carriage. The possible causes of this are the motor is burning out which would mean a new motor needs fitting or maybe the brushes are almost worn out and need changing. When brushes wear right down they start arcing inside the motor causing the added heat and thus then cutting out. This fault is usually distinguishable by a burn smell and a scratching,sparking noise as you use the cleaner.
    All that aside, the cutting out is often a break in the power cable to the vacuum. Try wiggling the lead to see if this is the problem. If this is the problem the break in the cable is most often at the plug end or where it enters the vacuum cleaner rather than the middle. It is often hard to detect exactly where the break is. A multimeter comes in very handy to test the cable, available in all good DIY stores for around £5.
    Hope i helped you.
  • taran_2005
    More likely it seems like a motor, if you have already rules out brush / bearing / thermostat protection.
    Hope i helped you.
  • taran_2005
    You are welcome.
    Hope i helped you.
    PS - Do accept my solution,if you are 100% satisfied from my response and close the thread.
    President:
  • 2,047 Answers
This is an indicator that the unit is due for servicing if it has been working for more than 3 months. Usually the insides of vacuums are such that they have various components which due to the job they perform require to be cleaned at regular intervals. The motor also after intervals needs to be greased. When the unit runs for a while the motor needs some greasing because when the oil in the system is short the motor find it difficult to work properly therefore the unit overheats and automatically starts shutting itself down.
Hope this solution has been helpful?
  • Rockme
    Rockme Oct 04, 2010
    Just send it in for service you dont need to buy a new one. If the unit is still covered by warranty then servicing should be free other wise it shouldnt cost upto quarter the price of a new vacuum.
    Please endeavour to rate the response.
Why does my Vacuum shut off!
Has this happened numerous times? If so, and the filters (all filters) are thoroughly cleaned then its possible the thermal protection circuit could be worn out in the motor. If not, it could be an assortment of other issues. Could you please provide more info?
Jun 17, 2014 | Panasonic MC-V7312 Bagged Upright Vacuum
Hi, I have Pnasonic Vacuum cleaner MC-7650 -2000W,while working machine stops its own.I tried all the way ,all in vain
If it operates less than 15 minutes suspect the filter is blocked and that will cause the motor to heat triggering shut off.
l have seen this and the filter may be washable or not.
Dec 04, 2012 | Panasonic Vacuums
I have a panasonic mc-ul975 vacuum that works great when working properly. the airflow through the canister seems to stops once the aero blast technology is done running which causes the vacuum to not...
Hi there. In Panasonic vacuums2.gif, there is a thermostat protection on the motor. It will automatically shut off the motor if there is no airflow through the motor. This is typically caused by a clogged hose. Typically, if your dust container is that full, there could be backup in the hose. Or the dust container being too full could also or otherwise be the problem. Check your hose for blockage, let the machine cool off, it should start up again
Aug 30, 2009 | Panasonic MC-UL975 Upright Vacuum
Vacum overheats and starts smoking after 4 minutes of vacuming
Clean vacuum internally, if the problem persists replace the motor.
Jul 19, 2009 | Panasonic MC-V7395 Vacuum
Dyson Quits
cut out switch on the motor needs replacing this overheats and cuts of the motor when the motor cools down it will start again you have to keep both filters and cyclone clean and free of dust or after replacement the same will happen again
Sep 04, 2008 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Dyson
the automatic cut out switch on the motor needs replacing when the motor gets hot this switch comes in and stops the motor from overheating when the motor cools down the cleaner will work again and cut out again when the motor gets hot if it is not replaced it will eventually burn the motor out after the switch has been replaced both the filter and cyclone need to be cleaned on a regular basis or the same will happen again
Panasonic upright vacuum MC-E458
Sounds like a problem with the impeller. It is loose or broken. It is attached to the motor shaft.
Mar 10, 2008 | Vacuums
Not enough suction for Panasonic MC-V5716 upright
Probably not the motor protector, its function is shut off the motor if it overheats. Most likely you have a clog or partial clog in the inlet down by the brush roll, or it is in the hose. But if the motor is running, and suction is low, with no clogs, then maybe the motor is running at a slower speed and will have to be replaced.
Nov 04, 2007 | Panasonic MC-V5716 Upright Vacuum
Panasonic Stow'n'Go, model MC-V5481
If you turn the vacuum over, you will see a hose by the brushroll. I think your problem is that it's stopped up right there. Take off the brushroll and make sure that the hose isn't stopped up. The port at the back that makes a hissing sound is to indicate that it's stopped up somewhere. Also, when you replace your attachment hose back onto the machine, does the motor change sound?? That's also another indication that your machine is stopped up. Don't lose hope for the Panasonic, they're great machines. If you still need help, you may call us at 1-866-509-1952. Thanks.
Jul 10, 2007 | Panasonic MC-V7600 Bagless Upright...
Panasonic MC-V5710 Vacuum Logo
181 people viewed this question
Top Panasonic Vacuums Experts
Joseph Hoffmann
Kevin Getz
Kevin Getz
Are you a Panasonic Vacuum Expert? Answer questions, earn points and help others
