Question about JVC AV-27020 TV
My JVC AV-27020 TV that I bought used on craigslist needs videa adjustment. The video needs to be reduced so that the entire pictures fits on the monitor. For example, if I'm watching a baseball game I can not see the entire score in the upper left corner. I downloaded the manual but I can't seem to figure out how to adjust the video.
  • 321 Answers
The problem is the vertical height adjustement but usely you dont need to adjust this setting its inside
the set , thats is probably a capacitor in the vertical deflection circuit chips but you can disconnect the set and open it and look for a mini control wheres its write v height because the guy sale you the tv should have a problem with this;i highly recommend that you dont do wath i say but call a tech at home and make it fix its an hour jobs about
its not verry expensive...
hope that will help you ps if you decide to open it and fix that by your self watch you have very high voltage inside it can arm you seriously
regards allan ,pro tech..
Posted on Oct 03, 2010
I have jvc av-27020 volume and channels display appears normal on the screen but the picture is dark, help to solve it
Volunteers and Chan display ate digital inputs. On a CRT TV the picture is an analog input. A dark picture generally means that the EHT supply is low or the picture tube is getting old ending it's useful life, solution is not easy
Jun 03, 2014 | Televison & Video
JVC PROJECTOR TV 61INCH
try to checked the memory program I.C. located near the controler I.C. or it maybe put you on timer mode, try to go menu and checked the settings
Jul 30, 2009 | JVC AV-27020 TV
Blinking Timer Button
The tv must of turned on the timer by itself. They do do that sometimes. I suggest leaving it unplugged for 24 hours to reset itself.
If problem persists, you may be able to go to your menu and access the sleep mode timer and set it to 0:00 or OFF
Jul 10, 2009 | JVC AV-27020 TV
Jvc tv av-32d502 timer light is flashing will not turn on
Hello, I am a tv tech. I worked on a JVC AV-32D502 today. Problem: led flashes / no power or picture at all. Same as trobertson52's set. The microprocessor is bad in my machine. trobertson52, if your sets' relay does not click when the power button is depressed you most likely have the same problem or the standby power circuit is at fault. That circuit supplies +5 volts to the micro.
Edtal you have a different problem with your machine. Your machine is going into shutdown. A number of circuits could cause this and would need to be looked at by a technician to determine exactly which circuit is at fault. High voltage transformer (HOT) \ Vertical Circuit \ Power supply are the most likely causes.
barneyinNC
Sep 25, 2008 | JVC AV-27020 TV
Digital Tuner or Analog
I have the JVC AV-27020 and had to download the manual just today. I checked where I got my manual and they did not have anything for an ACV-27020. The link for the TV manual I downloaded is below. Maybe it will help.
http://www.retrevo.com/s/JVC-AV-27020-TVs-review-manual/id/279ag501/t/1-2/
Aug 10, 2008 | JVC AV-27020 TV
Black menu screen pops and hides half the tv.
that is close caption, get your remote control and press the close caption button.that's it
Oct 31, 2007 | JVC AV-27020 TV
Picture not fitting on screen
if your tv has a warranty take it back to where you you bought it.or check if your remote has the zoom feature,if it does zoom it back.or else you will have to call the repair man to program it for you.
Mar 23, 2007 | JVC AV-29LX 29" TV
JVC AV-27020 TV Blinking LED, Static Electricity on tube but no sound and image
Sounds like a bad main regulator IC.. Try putting a 100 watt light bulb across the main AC fuse, turn on the set and see if it will stay on longer. If it does, replace the main regulator iC. If it does not, then it could be almost anything in the sweep section of the set, and or in the regulation circuit of the power supply. Look for slightly swollen capacitors in the set. good Luck please do not forget to rate this thread.
Dec 10, 2006 | JVC AV-27020 TV
JVC AV-27020 TV Logo
99 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
