Question about Maytag MFI2568AES Stainless Steel Bottom Freezer French Door Refrigerator
I have the maytag bottom door refrigerator how do you tighten the handle on the door of the bottom door. model mff2557heb s/n 12681886je
  • 833 Answers
SOURCE: Loose refrigerator door handle
weavie, this is one of those ugly little problems. Get hold of a small screwdriver, a pointy knife blade or similar and stick it into the gap, however small, between the cap and the handle. You may be able to find a small indent or similar near the bottom side of the cap. Gently pry up. It will yield. Be patient.
Posted on Dec 21, 2007
  • 9 Answers
SOURCE: maytag fridge model # MFF2557HEB
This has to be the evap. fan motor. I have ran into this alot. If you take the vent off the topcenter of the freezer back panel useing a simple flat head unlock the clips. Once you see the fan blades push it with your finger carefully if it spins slow and little wobblely the motor has failed. If it turns not at all then check for 120V. going into the motor by unhooking it if you get 120V motor bad if you get nothing then the Jazzboard or Highvoltage control board has failed. To install a new fanmotor is easy take your time most parts come out with a flathead screw driver and 1/4inchnutdriver. Evap. fan motor is just clipped in.
Posted on Jan 20, 2008
SOURCE: Ge profile refrigerator door handle is loose
On the GE Profile, the handle is mounted to two small screws. To detach the plastic housing, you must press on the two connection points (the base and top of the handles) and slide the handle up or down (takes some effort). The handle will come off and you will have very easy access to these 10mm screws.
Posted on Apr 09, 2008
SOURCE: Loose door handle GE two door freezer/frig model TFG 22JADAWW
Called and watched mechanic who clipped of top and bottom covers with a screw driver then tightened both screws and replaced covers. Cost was $100 but I could have wrecked the door. Needs a special little star shaped screw driver head with ratchet fitting. Now equipped for next time.
Posted on Jun 24, 2008
SOURCE: what is wrong with my Maytag refrigerator
You have a bad high voltage board call the manufacturer, if the unit is under 2 yrs old they may help cover the repair with the problem your having.
Posted on Jul 30, 2008
One side of Magtag refrigerate/bottom freezer door handle came off
Can you see a spot on the handle where an Allen wrench can fit into it? it either has an Allen wrench screw to tighten it or it has to be slid into the spot that holds it into place.
Aug 14, 2013 | Maytag MBF2556HEW / MBF2556HEB /...
Maytag refrigerator Model mff2557heb wont cool
The compressor in your refig is bad. whats happening is when you let the compressor cool down it will run for a while then it starts binding internally until it gets to the point of humming and clicking. only repair is replacing the compressor. sorry for the bad news...
Sep 30, 2012 | Maytag MFF2557HE Bottom Freezer French...
Handle on maytag refrigerator coming unscrewed
The handle may have an insert you can prise out to access the screw to tighten. If not it is tightened from inside the door
May 01, 2012 | Maytag MFF2557HE Bottom Freezer French...
How do I tighten up a loose handle on the bottom freezer door.
It took me a while but I finally figured it out. You need a special screw driver bit. The bit is a T10 -- it's star shaped but that is the size you need. There is a place to access this under the handles -- works great!
Dec 18, 2010 | Maytag MFD2560HES Bottom Freezer French...
Freezer located on bottom of Frig. Handle is loose. How to I tighten it?
the handle is install and removed with a plastic like credit card . slide it in the edge to release and when removed you can see the screw to tighten . . mm
Sep 01, 2010 | Maytag MFD2560HES Bottom Freezer French...
The door handle on the freezer of my GE Profile Bottom Freezer Refrigerator came off.
Hi, Please get me the model # from the label inside the refrigerator and I will look this up for you. Most handles have a set screw that tightens down.
Vic
Jul 11, 2009 | General Electric Profile PFSS2MIXSS...
Handle on bottom freezer drawer is loose.
Take the handle and slide to the left as far as it could go to tighten handle. This worked for me.
Jun 26, 2009 | Maytag MFI2568AE Side by Side French Door...
OUR MAYTAG REFRIGERATOR MODEL MFF2557HEB MAKES A CRACKING NOISE
Not sure this is your answer.. but we had a similar issue... it turned out to be the built in Ice maker... even though it was not hooked up it was running... and with no water it would pop and strain.. (like a small motor running).. we were able to stop it by making sure that the Ice Maker was shut off.. it took weeks to figure out.
Not sure its the same issue.. but maybe.
Jun 07, 2009 | Refrigerators
Our maytag model mff2557heb has a cracking and poping noise every few minutes and lasts for 15 to 30 seconds. it has done this since it was new 2 yrs ago. It is bothersom. What is the fix?
these sounds are normal for most new fridges. on some models you are able to get noise reduction kits that can be a pain to install. the sounds you are hearing is the gas turing from liquid to gas state.
Jun 07, 2009 | Maytag MFD2560HES Bottom Freezer French...
LOOSE DOOR HANDLE ON GE PROFILE ARCTICA STAINLESS STEEL REFRIDGERATOR
I may need to know your model # from the sticker inside the fridge to view a diagram but usually there is are small set screws (usually 2) on the handle which are allen head that can be tightened.  Look for this first and let me know if there are no set screws.  If this is your setup then I would appreciate a solved rating.
Oct 18, 2007 | Maytag MBF2556HEW / MBF2556HEB /...
Maytag MFI2568AES Stainless Steel Bottom Freezer French Door Refrigerator Logo
50 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
isaac johny
isaac johny
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
