Question about Dryers
My dryer is making this incredibly loud noise that sound as though there is a shoe being dried inside. It makes this loud thumping noise, and squeaks too. Help!
  • Dryers Master
  • 7,482 Answers
ALWAYS UNPLUG YOUR DRYER BEFORE STARTING ANY REPAIRS
Your problem sounds like drum rollers have flat spots on them or in need of lubrication, or maybe your drum belt has slipped off of the idler arm pulley.
Note: This method works with most front loading machines.
Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer.
Note: Some tops hinge and tilt backwards so they do not have to be removed and the electrical console with stay with the lid.
Also remove the lint filter and the screws holding the lint filter housing in place.
Be REAL CAREFUL not to knock any of the wires off of the timer switch. Then remove the top of the dryer.
Remove the front of the dryer. This will expose the drum and belt. Remove the drum and belt and this will expose the drum rollers, idler arm pulley and motor.
Now is a good time to check the belt to see if it has slipped off of the idler arm pulley and also to check the belt condition for wear.
Be sure to note the route of the belt, this will come in handy when you go to reinstall the belt.
Check your drum rollers for flat spots or wear, if they have flat spots or wear on them replace them.
If the drum rollers don't have flat spots or wear on them then they probably only need lubrication. Lubricate the shaft of the rollers with a good grade of machine oil such as 3 in One oil. Reassemble the dryer, plug back in. This should solve your noise problem.
For this FREE answer, Please rate me
Posted on Oct 03, 2010
What is making mywhirlpool/admiral electric dryer sound loud and thumping noise
You dryer belt may be shot and a piece of rubber is missing making it jump while working. Needs replacing before it completely quits. It will eventually just break apart.
Apr 13, 2015 | Admiral Dryer. 6.5 cu. ft. Electric Dryer...
Kenmore dryer making a thumping noise
Your dryer has rolls on the drum and they are going bad and need to be replaced
Mar 22, 2014 | LG DLG3788W Gas Dryer
Creda simplicity TVU1 tumble dryer is making a thumping noise while drying
Hi dave hemming.
I do not believe it is a bearing that is causing your thumping noise
No...you do not need a new drum...all you need is new drum rollers
You probably have a flat spot on one of the rollers, it will make the thumping sound when the drum rotates.
Go to the following webpage and get your drum rollers and install them and that should take care of the noise you are hearing
Please take time to rate me
Bud
http://www.appliancepartspros.com/index.aspx
Oct 13, 2012 | Dryers
My dryer makes a thump thump sound
  1. Thoroughly check the inside of the dryer for any foreign objects with hard surfaces. Sometimes items that fall out of pockets become stuck inside a dryer and make thumping noises.
  2. Check for level
  3. Make sure the dryer is level. A dryer that is out of level may not rotate properly. Banging or thumping noises from unleveled dryers are common, particularly if the dryer is resting against another metal object such as a washer.
  4. Check rollers
  5. If the thumping noises are present only for the first few minutes of the drying cycle the likely culprit is rollers. If the rollers are warped they will need to be replaced and a professional should be called in to help
Dec 17, 2010 | Frigidaire Electric Dryer
Dryer makes a "thumping" sound even when it is running and clothes are not in it. Sounds like a pair of shoes are in there being dried.
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Oct 18, 2010 | LG DLE3777 Electric Dryer
SOUNDS LIKE YOU ARE DRYING SHOES IN THE DRYER. EVEN WHEN THE DRYER IS EMPTY!
Bad rollers
These rollers get a flat spot on them and make a thump type noise with every revolution. More HERE
Jun 10, 2010 | Kenmore Rear Control 8885 Dryer
Thumping noise (similar to shoes drying) and burnt smell
that one needs a serviceman to look at it too many variables as to cause
Jan 23, 2010 | Maytag Atlantis MDE6400AY Electric Dryer
Dryer is making loud thumping noise.
Take off the back panel of the dryer and look at the motor and belt turning the drum. There may be something caught on the drum and is pinned in place causing the noise. The motor could be loose on the platform and needs to be tightened. It is probably something physical and seen causing the noise.
Jan 04, 2009 | Whirlpool LER4634J Electric Dryer
LG ELECTRIC DRYER
Henry, its going to be 1 of 2 things. Check inside your drum, see if the vent in the rear has burning or discoloration around it. If it does, it sounds as if your vent is restricted causing the unit to overheat, so clean/fix/replace the venting and your support pulleys will need to be repalce ie flat spots from overheat. If there is no scoarching marks and you know its not the vent or heat issue, the drum seam may have parted causing the thump as every revolution is made.
Apr 04, 2008 | LG DLE2514 Electric Dryer
Dryers Logo
151 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
