I just installed your video card HD 4350.I am adding a second monitor.The computer doesnot see the second monitor.
  • 7,733 Answers
OS?
open the Display Properties window. In the settings screen, you should see something like this:
You'll see that a second display is shown. Click on the grayed out display marked as "2". The window will change slightly to look like this:
You can then change the desktop resolution and color depth. Once you've done that, click your mouse on the "Extend my Windows desktop onto this monitor" to enable it. Remember that the resolution, color depth and refresh rates of each monitor adapter combination don't have to be the same. The window should look something like this now:
Click on OK and your second monitor should activate itself as an extension of the first: i just installed your video - monitor0005.gifbr />
moni just installed your video - monitor0006.giflass=
You'll find that you can change the relative geometries of the two monitors by moving their respective boxes around in the Settings window.
Posted on Oct 03, 2010
Trouble with install second video card HD 5450 to emachines t6532
Unclear of your statement. (More like run-on sentence)
Problem heading statement reads,
"trouble with install second video card HD5450 TO eMachines T6532"
Need clarification
The eMachines T6532 Desktop PC uses an MSI MS-7207 motherboard.
Also known as the MSI K8NGM2-L,
http://www.msi.com/product/mb/K8NGM2-FID--IL--L.html
(Click on photo for a better image)
Has one long white PCI Express x16 slot. (Expansion Slot)
Only uses one graphics card at a time, will Not use two.
[Graphics card / Video card. Same/same]
Therefore I surmise you are not referring to adding a Second graphics card, but are referring to;
A) This is the second time you have added a graphics card.
Or,
B) This is the second ATI Radeon HD5450 graphics card.
Had one before. Removed it, and are using a new one.
Or,
C) This is the second time you have added a graphics card.
It is not an ATI Radeon HD5450 like the old one is.
Know this;
1) You can ONLY use the OnBoard (Integrated) graphics,
OR the graphics card.
You CANNOT use both.
When using a graphics card the monitor is plugged into it.
You cannot plug into the onboard graphics of the motherboard, with it installed in the computer.
Said differently;
With the graphics card physically installed in the computer, you cannot just unplug the monitor from the graphics card; and plug it into the OnBoard graphics of the motherboard.
[Also; Computer on, you CANNOT unplug a monitor, and plug it back in.
This = NO ]
2) Driver: Small piece of software that allows the Operating System to communicate with a device.
The device is the graphics card.
The version of Windows operating system was not stated.
Did you install the software from the Installation Disk? (CD/DVD)
Has the drivers on it, and the user interface software.
User interface software for an ATI graphics card, is Catalyst Control Center.
(Just to note; I'm using a Powercolor Radeon HD5450 graphics card, right now.
I'm using dual monitors.
HP 2009M - 20 inch widescreen LCD monitor, and an RCA L26HD31 HDTV as the main monitor. (26 inch HDTV)
They work GREAT! ]
(It is an ATI Radeon HD5450 graphics card just like yours, IF yours has 1GB of graphics memory.
Doesn't matter what graphics card manufacturer, makes that HD5450, it is still an ATI (AMD) design.
Powercolor, VisionTek, Sapphire, Diamond Multimedia, Mickey Mouse, or Goofy. It is still an ATI graphics card )
The ATI Radeon HD5450 graphics card, has to have a MINIMUM power requirement of 350 Watts.
Does your power supply have 350 Watts or more?
If it is the original power supply, the answer is NO.
Back then power supply manufacturers were 'fudging' the true maximum rated wattage.
Why?
Sold more power supplies.
Power supply rated at 250 Watts?
Nope.
More like 60 to 70 percent of that.
Divide 250 by 10.
= 25.
Take that times 6. = 150 Watts (60 percent)
Times 7 = 175 Watts (70 percent)
Would like your opening statements clarified.
Post back in a Comment.
Regards,
joecoolvette
Mar 15, 2013 | E-Machines eMachines Desktop PC
Tip
USE YOUR LCD TV AS A COMPUTER MONITOR BY WAY OF HDMI.
To use your LCD TV as a monitor. look for a HDMI output on the computer and the TV. If you dont have a HDMI output on the computer, you will need to spend approx. $70 for video card and install it. I found "VisionTek Radeon HD 4350" to work fantastic.. Make sure your LCD TV has a HDMI INPUT. If not, you will need a newer TV. All thats needed now is a HDMI CABLE. The cable can be purchased anywhere computers are sold for between approx. $30 to $40. Depending on length. The cables can be found for much less ON-LINE. firefold.com has the cables for approx. $5. and they are the high quality gold plated cables. Now plug the cable into the computer and the TV and then using your tv remote, switch to HDMI and your tv is now a computer monitor. "Note"you may have to make adjustment on computer for display size and quality. My LCD TV is a 46" and the video card described above supports HD full screen. A wireless mouse and key board are a nice feature to add. If you like movies, you can get netflix and stream movies. there are many other sites for streaming and downloading. after doing this with my computer, i dont have a cable bill any more..I hope this tip helps.
on Dec 02, 2009 | Computers & Internet
How do I replace a video card on a T6412 emachine. Monitor not working
This machine have an IGP video solution, an integrated graphic chip, therefore you can replace it. But you can ad one graphic chard, a very cheap one, if you use this machine only for internet browsing and office activities and light video activities.. You have an PCI Express X 16 slot free on your computers motherboard. But first check the functionality of our computer using some other video card, maybe borrowed from a friend.
I can suggest something like ATI Radeon HD 4350 to HD4650 or ATI Radeon HD 5450 to HD 5570. Those entry level graphic cards have HDMI output also.
You have an old system, maybe is not the IGP the only problem. Don't' get any more powerful card as you have a lesser capable power supplier.
Have a nice day.
Mar 14, 2011 | E-Machines T6412 (RBT6412) PC Desktop
Dell 4600 problem with new video card
if you can still log on to the Windows Advanced option, you need to go to the "enable VGA mode" then re-install your video card drivers.
**you can get it from this website: http://www.amd.com/uk/Pages/AMDHomePage.aspx
To get to the advanced boot up menu's for windows, you need to press on either F8 or F5 button as soon as your computer is turning on. Like you have to tap those buttons.
Apr 03, 2010 | Dell Dimension 3000 PC Desktop
I installed a Radeon HD 4350 video card and the computer stick on the Supermicro logo on bootup
unplug the new card and retry,,
if it works without the card then take the card back to the store
Mar 12, 2010 | SuperMicro X7DAE Motherboard
After installing into my vista machine, computer
maybe the monitor is still connected to your mobo, not on your vidcard.
Dec 30, 2009 | HIS HD 4350 Silence DDR2 PCIe, PCI...
ATI Radeon HD 4350 will not display red.
It could be a problem with the monitor cable.
Try unplugging and re-plugging the PC to monitor cable (VGA cable)
If possible, Use a different monitor to ensure that your video card is working fine.
Sep 05, 2009 | Power Color Powercolor 1A1-G000004879 ATI...
HP D530 Video card upgrade
If the HP D530 has an AGP slot, which I think it does, then yes you can install the Radeon HD 4350 card.
Make sure you have the correct driver for the video card.
Go to this site for more info:
http://bizsupport1.austin.hp.com/bc/docs/support/SupportManual/c00059123/c00059123.pdf
Hope this helps.
Good Luck.
Mar 19, 2009 | HP Compaq d530 SFF PC Desktop
Computers & Internet Logo
54 people viewed this question
David Payne
David Payne
