How to repair internet connection in System Preferences?
  • Doctor PC
    Doctor PC Oct 03, 2010
    Type of Connection is?
  • 7,733 Answers
Type of OS? Type of Conn? Windows?
Go to Network Connection and start the connection wizard.
Post back!
Posted on Oct 03, 2010
A remote user is unable to connect from a internet connection or a cellular connection. They are using apple devices.
You must go to System Preferences and select Sharing. Set Sharing to include remote log on . Also select share files and share printers.
Oct 14, 2017 | Apple Computers & Internet
How do i get out of dns mode on my imac home computer?
Mac OS X v10.5 or later:
  1. From the Apple menu, choose System Preferences.
  2. From the View menu, choose Network.
  3. Click the interface you use to connect to the Internet, such as AirPort or Built-in Ethernet.
  4. If you use Built-in Ethernet: Type your DNS address(es) in the DNS Server field. If you have more than one, separate them with a comma.
    If you use AirPort, click Advanced, then click the DNS tab. For each server, click the "+" button under DNS Servers and enter the address provided by your ISP or network admin. Click OK when done.
  5. Click Apply.
Mac OS X v10.4 or earlier:
  3. From the Show menu, choose the interface you use to connect to the Internet.
  4. Click the TCP/IP tab.
  5. Type your DNS address in the Domain Name Servers field. If you have more than one, press Return at the end of each to put the next address on a new line.
  6. Click Apply Now.
Changing networks
You may experience a delay with the first connection after changing networks on a portable Mac. For example, you might use a MacBook at home with Wi-Fi, then take it to work or school and use an Ethernet connection. By default, Mac OS X uses one set of Internet preferences (known as a "location") named Automatic that will search your computer's modem, Ethernet, and AirPort interfaces until it finds the one that is connected to the Internet. You may experience a delay while your computer determines which network it is on. This can be easily differentiated from a DNS issue by creating a location that only contains one network interface. For more information, see Using network locations in Mac OS X.
If issues continue after trying the above steps, consider removing any manually-entered DNS addresses from the Network preferences pane. Select the address, then click the minus ("-") button. Note that dimmed addresses cannot be removed.
Jan 17, 2014 | Apple 24" iMac Desktop
Itune 306 error
From http://support.apple.com/kb/TS3297
iTunes Store loads partially or returns "Error 306" or "Error 10054"
Proxies, parental control settings and software, security or filtering software, or a bad iTunes Store cache can cause this.
To address proxies, Remove Internet Options proxy settings and connect to the Internet without a proxy.
To reset iTunes Store cache:
  1. In iTunes, choose iTunes > Preferences (Mac) or Edit > Preferences (PC).
  2. Click the Advanced tab.
  3. Click the "Reset cache" button.
  4. Click OK and see if the issue is resolved.
Adjust Parental Controls in iTunes:
  1. Open iTunes.
  2. Access iTunes preferences:
    1. On a Mac: From the iTunes menu, choose Preferences.
    2. On a Windows PC: From the Edit menu, choose Preferences.
  3. Click the Parental Controls tab.
  4. Remove restrictions on Parental Controls.
Oct 22, 2013 | Apple iTunes
I am unable to do a google search?
Internet Explorer comes preinstalled on most Windows-based computer systems.
If you use Internet Explorer, you may run into the issue where the Internet browser does not open for some reason when you attempt to access it.
Usually that's caused by a minor flaw in your computer, one you can correct without too much effort or time.
Run the anti-virus software you have on your computer and perform a full system scan. Sometimes if a virus or malware infects your computer, it blocks Internet Explorer from launching.
Once the scan has finished, remove any bugs or infections your software found on your computer and attempt to relaunch Internet Explorer.
Shut down the computer and restart it.
Sometimes just restarting the computer can correct any error you are having.
Click the "Start" button, followed by "Control Panel."
The Control Panel window will load with a variety of system icons. Select "System."
Select "System Update" and allow your computer to connect to the Internet (no browser is required) and Windows tells you if any updates for your system are available.
Install these updates and your issues with Internet Explorer may disappear.
Launch a different web browser (such as Firefox or Safari). Using one of these browsers, you can usually access the Internet; you could try to download an updated version of Internet Explorer to correct the older version that's not loading.
http://www.enhanceie.com/ie/troubleshoot.asp
Turn Off Google's Safe Search
Google's preference page allows users to customize settings and options that help utilize searches to the viewer's needs.
One of those options is Google's filtering tool.
This tool contains three filtering options that will filter your results completely, with moderate safety, or it will not filter the search results at all.
Google's filtering preferences also filter and determine what kind of keywords and keyword phrases appear in the Google search bar.
Click on "Preferences" on the left side of the search bar of the Google Home Page.
You will be directed to Google's "Preferences" page.
Scroll down until you locate the "Safe Search Filtering" section of the page.
You will see three safe search options: "Use Strict Filtering," "Use Moderate Filtering," and "Do Not Filter My Search Results."
Click the "Do Not Filter My Search Results" option to check the option and click the "Save Preferences" button to save your changes.
Google guide making it easier
http://www.googleguide.com/preferences.html
Editing SafeSearch Filters
http://www.google.com.au/preferences?hl=en
Aug 15, 2013 | Computers & Internet
When I try to connect to a wirless internet connection with my Playstation 3 Obtain IP Address succeeds, Internet connection fails and I get the message "A connection error has occured....
try power cycling your router and modem, and if that doesn't do it somewhere in your system should be a menu to get to either in preferences or settings that "sets new IP address"
Jan 17, 2011 | Video Game Consoles & Games
Connection problem
These Steps will help you out:-
1)Click on the apple icon on the left hand side of the start screen and go to system preferences.
2)Under system preferences a category name internet and network select the title network from there.
3)Under Network you will have an option for airport to turn it ON so do that and then below you will see list of networks available , from that list select the network you created , enter the password if it's secure one and you will be good to go from there on and will have an internet access.
Nov 16, 2009 | Computers & Internet
Can connect a MAC to my home network
Yes you can connect a Mac to your home network either wirelessly or using an Ethernet connection. Click on Apple menu, select System Preferences, in the preferences window, click Network. In the left column, click on Ethernet or Airport (for wireless), then click the 'Assist Me' button. The Internet Assistant will step you through setting up a new network configuration or location.
Oct 17, 2009 | Apple Computers & Internet
EMac computer Internet
With the ethernet connected, try going to system preferences, choose network and select built-in ethernet in the left hand panel and then in the right hand panel at configure use the esing DHCP option then click on Apply in the bottom right of the network panel.
Oct 10, 2009 | Apple Computers & Internet
No internet connection
Internet connection solutions
  1. Restart the computer.
  2. Test the jack.
  3. Test the equipment.
    1. Try a different jack that you know works.
    2. Try a different cable that you know works.
  4. Check your computer settings.
  5. Renew your IP Address
    1. [x] Windows Vista
      1. Look for your Ethernet card:
        1. Right-click on My Computer from the Start Menu or on the desktop.
        2. Left-click on Properties.
        3. Click on Device Manager on the left side under "Tasks".
        4. Expand the Network Adapters and look for any yellow exclamation points. Make sure a card is listed.
        5. If there are exclamation points, or if there is no card listed, you need to reinstall the card.
      2. Set your IP address to configure Automatically (through DHCP):
        1. Go to the Control Panel in your computer (in the Start Menu).
        2. Go to Network & Sharing Center.
        3. Under "Network", go to Local Area Connection and select "View Status". In new window, choose Properties at the bottom.
        4. Scroll down "This connection uses the following items" list to Internet Protocol (TCP/IP).
        5. Select Internet Protocol (TCP/IP) and click Properties.
        6. Change to "Obtain an IP address automatically".
        7. After you have changed this, restart computer.
      3. Check to see if your network connection is on:
        1. Go to the Control Panel in your computer.
        2. Go to Network Connections. If you cannot see Network Connections, go to Network and Internet Connections and then go to Network Connections from there.
        3. If there is a red X through the Local Area Connection, or the Local Area Connection is grayed out, double-click on the X to enable.
    2. [x] Windows XP
        2. Left-click on properties.
        3. Go to the Hardware tab and click on Device Manager
        3. Right-click on Local Area Connection and go to Properties.
        4. Scroll down the "This connection uses the following items" list to Internet Protocol (TCP/IP).
        7. After you have changed this, restart the computer.
        3. If there is a red X through the Local Area Connection, or the Local Area Connection is grayed out, click on Local Area Connection and click "Enable."
    3. [x] Macintosh OS X (10.4 or "Tiger")
      1. Look for Network Cards:
        1. Go to the System Preferences panel from the Dock or Apple Menu.
        2. Open Network icon under Internet and Network.
        3. This shows your current network settings. Green lights for each device means it is connected and red mean there is no connection.
        4. Go to Show and then click on Built-in Ethernet.
        5. Under the TCP/IP tab make sure "Using DHCP" is chosen under the top option.
      2. Renew IP address. Hit "Renew DHCP" or change it to a manual address. Then restart and change it back to DHCP to renew the connection.
      3. Set your IP address to "Configure Automatically using DHCP". Under the Ethernet tab make sure that configure is set to "Automatically". Click OK until you are back to the main System Preferences windows.
      4. Check your privacy setting
        1. Go to Sharing under Internet and Network in System Preferences
        2. Under Services everything should be unchecked.
    4. [x] Macintosh OS X (10.5 or "Leopard")
        3. The left menu shows your current network settings. Green lights for each device means it is connected and red mean there is no connection.
        4. Select Ethernet from the left menu. Go to Advanced.....
        5. Under the TCP/IP tab make sure "Using DHCP" is chosen under the top option, "Configure IPv4".
      2. Renew IP address. Hit "Renew DHCP" or change it to a manual address. Click OK.Then restart and change it back to DHCP to renew the connection.
      3. Click OK until you are back to the main System Preferences window.
    // MAIN FUNCTION: new switchcontent("class name", "[optional_element_type_to_scan_for]") REQUIRED // Call Instance.init() at the very end. REQUIRED var bobexample=new switchcontent("switchgroup1", "div") //Limit scanning of switch contents to just "div" elements bobexample.setStatus('[x] ', ' ') bobexample.setColor('#674a80', '#3b5998') bobexample.setPersist(true) bobexample.collapsePrevious(true) //Only one content open at any given time bobexample.init()
  6. Make sure your computer is clear of all viruses, spyware, and adware.
Oct 03, 2008 | Computers & Internet
Computers & Internet Logo
13 people viewed this question
David Payne
David Payne
