Question about Honeywell Programmable Thermostat Heater
I just installed an rlv430 and it works fine, but the backscreen light does not come on. The manual says that it should turn on for 12 seconds when any button is depressed. What could be the problem???. I cannot see the displays at night, since there is not backscreen light.
    President:
  • 1,515 Answers
Hi, the only problem that it could be if the display and system is working good, is a faulty back light from the factory. All you can do is take your receipt and the stat back, and exchange it. It has nothing to do with the way it was wired, its just one of those things that happen from time to time. Even though its new doesn't mean it will work right. I know its a pain, but that is the problem as you have 24 volts there or the unit wouldn't run, and that voltage lights the back light, so its not right.
Sincerely,
Shastalaker7
A/C, & Heating Contractor
PS, please rate me on this post! Thank you!! :)
Posted on Oct 03, 2010
  • luismadril Oct 05, 2010
    I called the company and it turns out that there are 3 models of this thermostat which all use the same guide manual, but my model does not have a backlight for the screen.
Dash lights arent working on a 99 explorer, fuses are fine and all the other lights work. quit working after installation of aftermarket stereo
OK, that radio use a straight or constant 12 volts a ignition 12 volts and grounds. now your radio ground might be connected to the park light wires of the car. that wire will should grounds ( - ) but when you turn on the park light it turns to 12 volts to illuminate the dashboard gear shift etc. if that is the case you're wondering where you will get grounds to collect the radio, well the antenna wire has ground, so plug and play, and the frame where the radio goes has metal, which is also grounds. disconnect the black wire from the radio and that wire you can test by turning the park lights on and you will get 12 volts
Feb 16, 2014 | 1999 Ford Explorer
I have a lg S530-K laptop after update bios it isn't work. laptop is backscreen .please give me answer how to solve tish problem.
What is this obsession with the BIOS? The BIOS and system registry is like taking a stroll in a minefield, one wrong step and............ If your computer is working properly leave it alone. But hey, that's just me.
Nov 18, 2012 | LG Computers & Internet
I've installed a 60-minute Woods timer 12842 (digital) in my garage but it switches itself off prematurely over and over. I notice when it is on the little green 10min timer light clicks & dims ever so...
Open following link to identify timer for sure, download on-line manual, and read wiring instructions.
ttp://waterheatertimer.org/Woods-timers-and-manuals.html#59000
1) Manual says 1000Watt Tungsten (incandescent) and 1000Watt Ballast (fluorescent)
2) Timer is powered by electric circuit and not internal battery, so cold garage temps will not affect operation
3) Check wiring against instructions shown on link above, except your other timers work fine, which indicates correct wiring.
4) Buy cheap circuit analyzer at home center, and test receptacle on same garage circuit
5) Try moving known-good timer to same location and see if problem persists.
6) I test timers, and some in-wall and plug-in timers arrive defective, and some go bad quickly, most have 1 year limited warranty, some last 5-7 years.
Add a comment for more free help.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Mar 06, 2011 | Woods 59014 Decora Style 12842 Hour Preset...
Installing a cadet softheat hydrondic baseboard heater on 12-2 wire on 20 double switched breaker. Is this possible? I was told I could change the white wire to black giving me one black to each prong of...
Yes it is acceptable and common practice. You do not need a neutral on a 220 Volt circuit. Just wrap it with black electrical tape so anyone who gets into the wiring later will know that both are hot. This is accepted by the National Electrical Code.
Feb 13, 2011 | Cadet Manufacturing EBHA1000W The EBHA...
Honeywell t stat rlv430 need to program to turn off every day at 700 am lower temp to 62 and on at 730pm raise to 70. need instructions on how to reset
WARNING: When the thermostat is reset, all parameters (clock, configuration
and schedules) return to their default settings.
?? Open the thermostat's door.
?? Press and hold the Pgm button.
?? Insert a pointed object (e.g., paperclip) in the reset opening.
Remove it when the thermostat's screen becomes blank.
?? Wait one second and release the Pgm button.
http://customer.honeywell.com/techlit/pdf/69-0000s/69-1855.pdf for complet instructions
Jan 21, 2011 | Honeywell Heating & Cooling
Can not turn off my ipod nano
i have also faced this problem, simply hold the play button for a while unitl the backscreen turns off, then let go and press it again till it turns off.
Nov 12, 2009 | Apple iPod nano
Blue amp light lights for 2sec
bad head unit or look at your ground wire good luck
May 24, 2008 | Car Audio & Video
Pilot goes out!!
My manual shows three possibilities:  1) Insufficient fresh air available for combustion, so ODS kicks off gas flow 2) Low gas line pressure (should be between 11 and 14") or 3) ODS/Pilot is partially clogged.  Toll free number for ProCom is 877-886-5989.
Mar 09, 2008 | Procom ML300TBA Heater
Manual
get in front of one of the thermostats and call Honeywell at 800-341-0110. If you are prompted, tell them you are an installer and seting up the thermostat for the homeowner.
Good Luck.
Oct 23, 2007 | Honeywell Programmable Thermostat Heater
Heating & Cooling Logo
274 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
