Question about Kenmore Washing Machines
My Kenmore 70 series model 110 will not agitate
    Genius:
  • 1,416 Answers
There are several reasons that a washing machine won't drain or spin. The cause could be something as easy as a clog or something difficult that will need a licensed repairman. Start with the simplest possible cause and work down to the more difficult causes.
INSTRUCTION BELOW
  • A washing machine won't spin if the water can't drain. Check hoses for any kinks or clogs that may prevent the water from draining. If a hose has kinks, try to straighten out the kinked hose. If it can't be straighten sufficiently, replace the hose. If hoses are not kinked, check for clogged hoses. This can be done by using the screwdrivers to remove the hoses and looking for clogs or running a water hose through the clogged hose to remove the clog. Use the rags and bucket to clean up the water that comes out of the hoses when they are disconnected. Once the clog is cleared, put the drain hose back into place. The washer should drain and spin now if a clogged or kinked hose was the problem.
  • 2 If the washer still won't drain or spin, check to see if the lid is not closing all the way or if the lid switch is not clicking into place. Close the lid and make sure that it closes all the way down. When the lid closes, the lid switch should click. If there is no clicking sound, then the switch may need to be replaced. Follow manufacturer's directions for replacing the switch. If the lid does not close all the way, visually check for signs that the lid is bent. If bent, try to bend it back into place.
  • 3 Loose or broken belts could also prevent a washing machine from draining or spinning. Pull the washer away from the wall and, using the screwdrivers and wrenches, remove the back panel. Using the flashlight, visually check for any broken or loose belts. Replace any broken or loose belts. Although replacing washing machine belts is difficult, anyone who has replaced belts on a car, lawn mower or even a bicycle chain should be able to accomplish the task.
  • 4 Another possibility for a washing machine to not spin or drain is the pump. With the back panel still off the washer, check the pump with the voltmeter to ensure that the pump is getting power. If the washer is getting power, turn on the washer and listen to find out if the pump is running but the water is still not draining. It may be necessary to remove the pump and clean it or to replace the pump with a new one. Once the pump is replaced, turn on the washer to determine if it will now drain and spin.
  • 5 If all of the above steps fail to produce a washing machine that drains or spins, then it is time to call a professional repairman. Use the screwdrivers and wrenches to replace the panel on the washer and push it back against the wall
  • please rate this after use.
    thanks and good luck.
    Posted on Oct 03, 2010
    My Kenmore 70 series washer sounds like it has something stuck in it and makes a grinding and buzzing noise the agitator will barely move but the washer will drain but not spin
    That could be the motor coupler. It could also be the transmission. It is pretty easy to fix. I recently worked on my brother's washer:
    Aug 04, 2012 | Kenmore 20722
    Kenmore heavy duty 70 series model 110-8237012
    probably your drain pump leaking it has a seal right where it attaches to motor,,,,mine is leaking there but haven't replaced it yet! lol
    Feb 27, 2010 | Kenmore Washing Machines
    My Kenmore 70 series is 18 years old. It will not
    Hello. Since your machine is 18 years old and the agitation/spin is costly to repair I would definitely recommend a replacement washer.
    Jul 06, 2009 | Washing Machines
    Kenmore series 70 washer will only fill with water.
    I recently had this problem. It was found that the main drive belt broke and the washer would fill but not spin, agitate or drain. I replaced the belt and everything worked again. A defective or disconnected cover switch would also cause the same problem.
    Jun 30, 2009 | Kenmore Washing Machines
    Finding Lint Filter on Kenmore 70 Series Model 110
    I've got a Kenmore 70 Series, Model # 82370120 washer and the lint filter in under the machine. I had to tip the thing over to get at it.
    Apr 19, 2009 | Kenmore 22422 Top Load Washer
    70 series kenmore washer won't agitate help model #82873120
    No wash, no spin read THIS
    Spins, pumps, won't agitate right: check THIS out
    Mar 27, 2009 | Kenmore 22422 Top Load Washer
    Washing Machines Logo
    134 people viewed this question
    Sal DeAngelo
    fordexpert
    Mike Squire
