Question about Dryers
I think the belt broke - Dryers
  • Dryers Master
  • 7,482 Answers
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
If you have to check/replace/repair your drum motor,drum seals,belt,rollers, etc.
If replacing drum seals be sure to use a good grade of weather proof cement to hold the seal/s in place.
Note: This method works for most front loading machines.
Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer. Be real careful not to knock any of the wires off of the timer switch or other electrical connections.
Remove the lint filter and the screws that hold the filter housing.
Then remove the top of the dryer.
Note: Some of the tops tilt backwards and do not have to be removed completly.
Remove the front of the machine, this will expose the belt and drum, remove the drum and belt and this will expose the drum rollers, idler arm bracket with pulley, and motor with pulley. Pay attention to the route of the belt, this will come in handy when you go to reinstall the belt and drum.
Sometimes the belt will slip off of the idler arm or motor causing the drum not to turn.
While you have the drum out, I would recommend that you lubricate the drum rollers at the shaft of the roller with a good grade of machine oil like 3 in One oil. This will save you a problem later with the rollers getting noisy, also check your drum rollers for flat spots, if they have flat spots on them this will cause a noise like a thumping type noise. You will need to replace the drum rollers if they have flat spots on them.
This is a FREE answer, Please rate me
Posted on Oct 03, 2010
Timeing belt broke have replaced now not fireing
You either have the belt 180 degrees off. So you have to take belt off and turn crank only (slowly) around once to its mark again, but first you need to go to a website that lists motors that are called "interference fit" engines. (Think Gates belt co. has a list) If your motor is an interference fit then when belt broke the motor is trashed. Interference fit means that pistons can hit valves if the belt breaks. That is why they tell you to replace the timing belt before too long. Also if motor is interference fit when you try and turn crank go slow because you may bump into valve.
Apr 04, 2011 | 1993 Geo Storm
My wife has a 1994 chevy suburban,she was driving along and the serpentine belt broke, what do you think caused that to happen?
WELL I WOULD SAY BELT WORN HAD A BAD PLACE BROKE OR FAULTY DRIVE BELT TENSIONER CAUSING LOT OF SLACK IN BELT TO BREAK.
Aug 27, 2010 | Chevrolet Suburban 1500 Cars & Trucks
The serpatine belt on my 96ford taurus broke. I fixed it but it still does not start.I recharged the battery still nothing.It tries to turn over
i think that when the belt broke it has damaged the wires too the crank sensor which could be on the front pulley
Jul 29, 2010 | 1996 Ford Taurus
Timing belt broke is this a low tolorance enging
A 1991 GEO is worth scraping if this is your problem
A water pump is also needed to replace with the belt
It is a rule of thumb for the belt drives the pump as well
Think about selling it to a local kid as his first car that he has to fool with. The monet to fix it is really not worth investing into it
The fuel pump for these cost more than the worth of this car now
Jun 22, 2010 | 1991 Geo Storm
Wont wash dry or spin. Motor runs. I think my son overloaded the machine. Could the belt be broken?
Hi there
i read your report. Yes it dose sound like your belt has broke.If you can spin the dryer with your hand with no Resistance then it's your belt that's broke. hope this info helps. Ty you for writing to fix ya.
Best Regards Richard
Dec 03, 2009 | Bosch Nexxt 500 WFMC3301 Front Load Washer
I think belt broke need to replace
Go to maytag.com then service and parts then use and care manuals then model no. hopefully you can find info. there if not call customer care 800 number. Most times you have to remove the top of dryer then the front to get to the belt. You will have to locate what type fasteners it uses some use a snap lock type fastener others use screws.
Apr 07, 2009 | Maytag Dryers
MDE5500AYW Drum belt
I dont think you broke the belt, I think it may have just come off the belt tensioner. Take the bottom of the back panel off and I think you will see it hanging in there. Just put er back on.
Nov 01, 2008 | Maytag Neptune MDE5500AY Electric Dryer
Dryers Logo
29 people viewed this question
Top Dryers Experts
