Question about Mitsubishi WS-55859 55" Rear Projection Television
The front timer light is blinking and the TV wont power up.
  • 666 Answers
The blinking light signifies to a repair technician with capacitors or circuits are having an issue they can diagnose the problem via the amount of blinks in between pauses however it will require a technician and some specific tools and schematics to fix and it may be cheaper if its no longer under warranty to purchase a new one
Hope this helped
Robb
Posted on Oct 03, 2010
Toshiba 50HP95 timer/Rex light blinking green. Tv wont turn back on.
place to begin if you are able is examine the power board for puffed up caps and or voltages coming into the board and out of it.
Aug 27, 2012 | Toshiba 50HP95 50 in. Plasma Television
T.v wont turn on
The light means nothing---if TV will not turn on or comes on briefly and shuts down--could be a jammed or not working mechanism in the VCR or the TV may have a power supply problem.
Apr 29, 2012 | Panasonic PV-C2061 20 in. TV/VCR Combo
Sony HD Projection TV KDP-57WS550, timer light blinks 5 times and repeats sequence. When power button is pushed sound comes on briefly, no picture, then TV goes off. Please advise.
Mine did this after a power flash. Lights blinking 5 or 6. They blink fast lol. I have sound till tv powers back down. Front yard bond fire? Or any ideas? Thx.
Dec 25, 2010 | Sony Grand WEGA KDP-57WS550 57" Rear...
Timer light blinks constantly
Is it Mitsubishi WD-52628 TV? please confirm model number.
Unplug TV from AC outlet for couple of minutes, replug back in, turn power ON and check, still same problem?
Lets read error code in TV, press Device and Menu buttons on front of TV at same time for 6 seconds that will activate error code read process. Led will flash in 2 sequence with half second pause. count it and let me know the error code to proceed.
Thanks.
Jun 29, 2009 | Mitsubishi WD-52628 52" Projection HDTV
Tv wont turn on get audio then tv shuts off timer lite blinking
If TV stays in stand by with audio but no video, then common faults are the ballast board, or a fault on digital board.
If the led stays blinking , and tv turns off then the TV is on protect mode.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
Also ensure that the fault is not coming from a faulty receiver box sending bad signal, check if you get same problem with no receiver box or dvd connected.
If that does not work, and you keep having a flashing led on front of the TV, and tv turning off by itself after a while, that indicates a fault condition.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible reasons.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or abroken contact, identified an internal fault and kicked in , startingthe flashing light.
If you are in situation one, then theTV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
Common faults that can occur are a blown capacitor on power board, a convergence IC has blown, or a fault on Digital board.
Check also the video cable or any external connection cable, if the cable is shorting, or the connector is bad, you can get same flashing state because of the video cable.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
Dec 21, 2008 | Mitsubishi WD-62531 Projection Television
Tv wont turn
The blinking red light at the the front of the television is the "Diagnostic STANDBY/TIMER LED".
This little red light will blink 2, 4, or 5 times and then stay off for three-seconds. And blink again for 2, 4, or 5 times. This cycle repeats. The most common diagnostic code is the 4-blink code.
When the red LED blinks 4-times, it means one of two possible causes:
1) +13V is not supplied on the A-board. Or, 2) IC502 is faulty.
It is best to take this television set to a repair facility and ask that the +13V power supply be repaired.
The copper tracks and integrated circuit pads are very thin and delicate on the KV-24FV12 circuit board, and will easily lift off of the circuit board, if the incorrect desoldering tool is used. Unless one has a good quality PACE vacuum desoldering unit, one should not attempt to repair the television.
Aug 17, 2008 | Sony KV-24FV12 24" TV
Tv wont turn on only clicks and then flashes red timer light
tv wont turn on when i hit power it makes the clicking noise like it is going to turn on, but never does and the red timer light next to the power button just flashes.
help!
trinitron kv29f1u
only clicks and blinks
Jul 26, 2008 | Sony KV-35S42 35" TV
Power serge
ok First question does the led continue to blink after 70 seconds after u plug it in. it is common for a cuircit board called the dm(digital module) to go bad in these units. this set has a keyboard lockout feature. Press menu for 10 seconds on front panel. if that does not release control then u more than likely have a problem with dm module. there are several bullitens about this and several things a tech can do to repair this set
Jan 16, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Well, I have found out that the number of red light blinks is a "blink code" that indicates the nature of the fault with the TV. Usually these are various failures of internal fuses or circuit boards. There's a fair amount of information on threads at techlore.com on this, so try searching there. Teh specific codes and manuals are usually it seems under license from Sony and not available for free to the public. Sorry!
Oct 17, 2007 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Tv wont turn on
Had the same problem. turned out to be the power supply to the DM assembly. Had to put a power supply, board and a new lamp in. Tech said the lamp blew out the power supply and board. I think it's just a lemon.
Oct 08, 2007 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WS-55859 55" Rear Projection Television Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
