Question about Roper RAX4233PQ Top Load Washer
The washer won't spin and drain??? - Roper RAX4233PQ Top Load Washer
    Genius:
  • 1,417 Answers
There are several reasons that a washing machine won't drain or spin. The cause could be something as easy as a clog or something difficult that will need a licensed repairman. Start with the simplest possible cause and work down to the more difficult causes.
INSTRUCTION BELOW
  • A washing machine won't spin if the water can't drain. Check hoses for any kinks or clogs that may prevent the water from draining. If a hose has kinks, try to straighten out the kinked hose. If it can't be straighten sufficiently, replace the hose. If hoses are not kinked, check for clogged hoses. This can be done by using the screwdrivers to remove the hoses and looking for clogs or running a water hose through the clogged hose to remove the clog. Use the rags and bucket to clean up the water that comes out of the hoses when they are disconnected. Once the clog is cleared, put the drain hose back into place. The washer should drain and spin now if a clogged or kinked hose was the problem.
  • 2 If the washer still won't drain or spin, check to see if the lid is not closing all the way or if the lid switch is not clicking into place. Close the lid and make sure that it closes all the way down. When the lid closes, the lid switch should click. If there is no clicking sound, then the switch may need to be replaced. Follow manufacturer's directions for replacing the switch. If the lid does not close all the way, visually check for signs that the lid is bent. If bent, try to bend it back into place.
  • 3 Loose or broken belts could also prevent a washing machine from draining or spinning. Pull the washer away from the wall and, using the screwdrivers and wrenches, remove the back panel. Using the flashlight, visually check for any broken or loose belts. Replace any broken or loose belts. Although replacing washing machine belts is difficult, anyone who has replaced belts on a car, lawn mower or even a bicycle chain should be able to accomplish the task.
  • 4 Another possibility for a washing machine to not spin or drain is the pump. With the back panel still off the washer, check the pump with the voltmeter to ensure that the pump is getting power. If the washer is getting power, turn on the washer and listen to find out if the pump is running but the water is still not draining. It may be necessary to remove the pump and clean it or to replace the pump with a new one. Once the pump is replaced, turn on the washer to determine if it will now drain and spin.
  • 5 If all of the above steps fail to produce a washing machine that drains or spins, then it is time to call a professional repairman. Use the screwdrivers and wrenches to replace the panel on the washer and push it back against the wall
  • help in rating
    thanks and good luck.
    Posted on Oct 03, 2010
    Testimonial: "Thanks, ery helpful."
    • aschweierf Oct 18, 2010
      Unfortunately, I'm using a public computer and I'm not at home where I can troubleshoot step by step. I was able to print this and try each step logically and methodically. Thanks for making your answer so simple. I just hope my problem is as simple.
    Tip
    Washing Machines will not rinse or spin
    If the water won't drain out of your washing machine, either something is stuck in the drain hose or pump, or the pump is broken. Both fixes are simple if you're even just a little bit handy with tools. We're showing the repair on a Maytag washing machine.
    What is wrong with a washer that does not spin?
    If your washer fills with water but doesn't agitate, the problem is likely to be a faulty lid switch, a broken belt, or a problem with the motor. (Note: Direct-drivewashing machines do not have belts.) To diagnose the problem, do the following: 1Check the washing machine's spin cycle.
    How to Drain Washing Machine That Won Drain Family Handyman
    Washer Doesnt Agitate or Spin
    Error codes in front load washers
    Washing Machine Not Rinsing How To Fix
    My washing machine stops at Rinse Does not DRAIN or SPIN
    What causes a washing machine not to drain and spin?
    If the washer won't drain there might be a clogged pump or hose. It's common for small socks or other small clothing items to get into the water drain system and clog the hose leading to the pump or the pump itself. Remove the hoses from the pump in order to remove the article of clothing.
    SOLVED Why won my washer spin or drain Kenmore 110 Series Washing Machine
    Maytag Washing Machines will not rinse or spin Google Search
    on Dec 12, 2017 | Washing Machines
    Washer doesn't spin out sometimes
    you say it drain, but sometimes it won't spin,this could be your filter if it is blocked these new machines can sence it and won't let the machine spin easyest thing check your filter,you never know might be that simple
    May 07, 2012 | Washing Machines
    What should i look for on my whirlpool washer if it hums but won't spin, agitate, or drain?
    The motor may be shot if it is getting current and won't operate the washer.
    Nov 04, 2011 | Washing Machines
    Washer won't spin
    Hi hometownrock,
    The washing machine may have a problem draining the water, if it cannot drain the water, then the cycle will not progress to Spin. You may have a foreign object in the Drain Pump Filter, this must be checked.
    Please follow my below Tip on how to do this:
    ACCESSING, DRAINING & CLEANING THE DRAIN PUMP FILTER...
    Kind Regards
    JEDEMEYER1
    * If this solution helped you, please rate it
    Aug 15, 2011 | Bosch Nexxt 100 Series WFMC1001UC Front...
    Washer will wash but won't spin or drain
    Problems with a washing machine not spinning or not draining are often interrelated..
    If you are having a problem with your top load washer then check out thistip...
    Washing Machine does not Pump or Spin
    If you are having problems with your front load washing machine then checkoutthis tip...
    Front Load Washing machine not draining and or not spinning
    heatman101
    Aug 11, 2011 | Kenmore 22422 Top Load Washer
    My washer did fill, but won't spin or drain now and the door won't open
    Hi tragz,
    If it can't drain, it won't spin. There may be something preventing the pump from draining in the Pump filter. You will need to clean it.
    Please follow my below Tip on how to do it:
    ACCESS, DRAIN & CLEAN THE DRAIN PUMP FILTER
    Kind Regards d")
    Aug 05, 2011 | Kenmore HE2 Plus Front Load Washer
    GE Washer will wash but won't drain?
    heatman101
    Jul 24, 2011 | GE Washing Machines
    WASHER FILLS WITH WATER, THEN WON'T AGITATE. TURN KNOB TO SPIN AND IT DRAINS THEN SPINS. STILL WON'T AGITATE
    WASHER FILLS WITH WATER, THEN WON'T AGITATE. TURN KNOB TO SPIN AND IT DRAINS THEN SPINS. STILL WON'T AGITATE please show me a diagram
    Jun 14, 2011 | Whirlpool LSR7333 Top Load Washer
    Front loader won't spin and is filled up with water. Won't drain.
    Problems with a washing machine not spinning or not draining are often inter related..
    If you are having a problem with your top load washer then check out this tip...
    If you are having problems with your front load washing machine then checkout this tip...
    heatman101
    May 15, 2011 | Kenmore Energy Star 44092 Front Load...
    Roper RAX4233PQ Top Load Washer Logo
    545 people viewed this question
    Top Roper Washing Machines Experts
    Dan Webster
    Dan Webster
    Mike
    Are you a Roper Washing Machine Expert? Answer questions, earn points and help others
