Question about Insignia IS-LCDTV32 32 in. Television
TV is not locating antannae channels - Insignia IS-LCDTV32 32 in. Television
  • 321 Answers
Tv set as to be programm in set up menu by
using the channel scan option....
hope that will help you
regards allan
Posted on Oct 03, 2010
Does the tv ghetto channels if I don't get cable and what kind of antanna do I need
The tv should get what are called free view channels with a built in decoder, almost any new antenna will work , just make sure you choose one that is suitable for hdtv.
Hope this helps
Oct 11, 2015 | Televison & Video
My Alba TV , when scanning for channels ,says no signal, check antannae, which i have by connecting a different tv, its working good , but my tv not showing any channels when even using first time ins
Check and replace the tuner inside the TV. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Dec 01, 2014 | Alba LDVD1538WDCH LCD TV
How do i set the 2632 from cable to uhf/vhf antanna
Have a good antana like a roof or a HD antana plug into the ANT tv hole.Tv remote push the tv menu.Goto SETUP go down to CH.push and pick AIR not cable.Push for scan for free DTV tv channels.When finish scan u will have all the free DTV channels,depend how good is ur tv antana receptions is.
Nov 26, 2010 | Polaroid FLM-2632 Television
The program light blinks all the time. I do not have a remote. I have a convertor box on the tv and an antanna but I keep getting a message saying to check antanna and connections, no sinal. I get a few...
I'm assuming you are getting more than two digital channels into the converter so the problem lies in how the converter is connected to the TV, which I presume is via a coaxial cable, right and you have the TV tuned to analog channel 3 or 4, right?
If that is all true, the RF coax cable solution is not going to work. The few channels you were getting, either side of 3 or 4 is just RF bleed.
Try this, acquire somehow a A/V hookup cable that has 3 RCA male jacks on each end. One cable will have YELLOW ends, This is composite VIDEO. There will be two others colored RED and WHITE (or perhaps black). This is for the AUDIO. The outputs on the converter and the inputs should be colored the same way. Hook the two up, noting which INPUT (1, 2 or 3) on the TV you have plugged into. Not sure of the exact number your TV has. Make sure you change the TV to INPUT whatever. You may also have to re-scan your converter. As long as your antenna is connected correctly gto the converter you should gain a lot more channels. Let me know how you make out.
Nov 24, 2010 | Panasonic PV-DF2735 27 in. TV/VCR/DVD...
After a power failure all our televisions dont have any signal
if your using an off-air antanna the or digital reciever box you may have to replace it. If you are using a powered antanae try plugging it in somewhere else if that doesn't work, you might have to buy a new powered antanna.
Feb 15, 2010 | LG 47LG60 LCD TV
I have a vcr/dvd hooked up to my present tv with a antanna. How do i hook up the digital converter. so thatI still could use vcr. Thank You
It depends on brand of converter. In Radioshack they have one with AV-in ports (for $56 (-$40 coupon = $16). So TV signal going trough antenna and DVD/VCR going trough AV-in of converter to the same antenna of TV. Or you will have to hook up the CONVERTER - ANTENNA IN VCR/DVD - Antenna OUT VCR/DVD - ANTENNA IN TV. And you will use the remote of converter to switch the channels.
Good Luck
Jan 10, 2009 | Philips Magnavox DVD/VCR Dual Player
No uhf with antannae
UHF channels are basically "line of sight" type signals. You need to be pretty near those UHF stations.
You need a Uhf or combination Uhf/ Vhf antenna to receive them - - Usually an out-door type.
Your TV needs to be set in the "antenna" mode to tune beyond channel 13 "air type" channels. Channel 14 is the first UHF channel if you're in the antenna mode. If you're in the "Cable" mode then channel 14 is a cable channel which is operating at a different frequency from UHF.
I hope this will help you!
Stargazer
Mar 21, 2008 | Orion STV2763 27" TV
"No Signal" Keeps Flashing on the Screen
I would suspect you have a weak or intermittent source. If it is cable, you may want to have them check it for you. If you are using an antenna, you will want to get a better one or at least try a different position.
Dec 20, 2007 | RCA 14F512T 14" TV
Black menu screen pops and hides half the tv.
that is close caption, get your remote control and press the close caption button.that's it
Oct 31, 2007 | JVC AV-27020 TV
Insignia IS-LCDTV32 32 in. Television Logo
85 people viewed this question
Top Insignia Televison & Video Experts
Jaime Hernandez
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
