Question about Amana Dishwashers
Our dishwasher was cleaning just great...then the next washing...no clean dishes. We thought we forgot to run it, so reran, and the same thing...dirty dishes. Any ideas?
  • 4,323 Answers
Hi
If you are noticing that the dishes are not clean, then there are a few things to check for. Check the soap powder if it's kept in a dry environment. Also try replacing the powder with something like a gel or liquid. Next thing to check for is the water pressure and fill valve. Check if the water is filling in and the spray arms are throwing the water with enough pressure. Try and listen to the sound if you hear a proper spraying action sound.
If it seems as a low water pressure then check the fill valve. Now, check if dishwasher is draining the water or not. While the dishwasher is working check whether the dishwasher is draining and there is not much left out water after the cycle is complete. Try cleaning the spray arm with a soft brush. The water temperature plays a major role in cleaning of dishes. The temp should be between 125 and 150 F for dishwasher to clean the dishes. Hope this helps...
Daniel
Posted on Oct 26, 2010
Dishes not coming out clean
Hello
There are some things you can try, however, if your Maytag dishwasher is not getting your dishes as clean as you would like. Maytag recommends several processes for fixing this issue with your dishwasher.
Do not run your Maytag dishwasher while hot water is being used in other parts of your home, such as washing clothes or showering. Hot water is needed for your Maytag dishwasher to properly clean dishes.
Run water in the sink in your kitchen until it gets very hot. Then, turn on your Maytag dishwasher. This will ensure that the water cleaning your dishes is the hottest possible temperature.
Clean your Maytag dishwasher to improve the cleaning results for dishes. Run your dishwasher on a short wash cycle and wait for it to fill up with water. Stop the cycle and add about 1/3 of a cup of rust remover to the dishwasher and finish the cycle. Run your Maytag dishwasher through one normal cycle with regular detergent to finish the cleaning process.
Check your detergent. Old detergent or those that have been exposed to moisture can be clumpy. This detergent will not clean your dishes as well when loaded into your Maytag dishwasher. Purchase fresh detergent.
Use extra detergent when washing dishes that have a lot of built-up grease or food particles. The extra amount of detergent is needed to get your dishes clean. Choose a long cleaning cycle to clean these dishes.
Fill your Maytag dishwasher properly. Dishes should not be stacked on top of each other or excessively crammed into your dishwasher. This will keep the dishwasher from adequately cleaning all areas of your dishes and from rinsing them thoroughly.
Sep 13, 2011 | Maytag Dishwashers
The water does not get hot enough. I think it's the reason why dishes are not coming out clean. In normal conditions do I need to wash the dishes (like the manager of this apt. complex suggests) before I...
No you need not wash the dishes but just cleaning of the debris and then putting it in the dishwasher for proper cleaning will help you to prevent the drain from getting blocked.
First perform a vinegar cycle wash in the dishwasher. Pour a cup of vinegar into the bottom of the dishwasher. Keep the temperature at the highest setting possible and perform a wash cycle.Then start using a dishwasher most probably that would solve the problem. If this does not solve the problem then there must be some parts worn out or faulty creating the problem.
There are many probable causes of failure .
To clean the dishes the water temperature is essential.It the water is not hot then the dishes will not be cleaned properly.So check the water temperature.
Also check the filter in your dishwasher.Clean the filter if there is accumulation of debris in the filter.
Feb 22, 2011 | Whirlpool Dishwashers
Our dishwasher has started leaving cloudy film on silverwar, glassware etc. Used Finish in washer per instructiuons. Have cleaned with white vingar per owners manual. Spray arms, filters all clean. ...
Run 2x bottles of Dishwasher Magic 1x per each wash. You can pick this up at your supermarket. Run on normal cycle without any dishes. Kills 99.9 bacteria and cleans out dishwasher.
Also make sure your not using rise aid and detergent with rise aid in it. To much rise aid will cloud the dishes as well.
Have a great day!
Dec 08, 2010 | KitchenAid Dishwashers
When we open dishwasher theres standing water in the drain area and it smells bad this is after washing aload dishs look clean but inside stinks
After you run a load of dishes put 1cup of CLR or vinegar (white) and run a quick wash.no dishes,after running dishes clean out spray arm and clean strainer,use a rinse agent like finish, and spray off dishes before loading.About 35yrs. ago I use to be a dishwasher as one of my first job's and if you did'nt spray the dishes and scrap them off before loading,the dishes would not come out clean,And after each shift the dish washer would be cleaned out.
Aug 04, 2010 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
Dishes not clean
Run a hot wash without the dishes and a quart of white vinegar plus detergent which should wash out any oily film left by the water folks when they were 'fixing' whatever. You may have to do this several times until the water runs clean as before. Hope this helps!
Jun 27, 2010 | Dishwashers
White residue on dishes after wash
check if the residue are soap or not. residue could be from water tank or water itself.
Nov 01, 2008 | Kenmore 24 in. 15173 Stainless Steel...
My 3 year old
Try a different detergent such as the electrosol tablets. Also might add vinegar to an empty cycle to clean dishwasher, or with dishes.
Oct 15, 2008 | Kenmore 16602 / 16604 / 16609 Built-in...
Dishes are not clean; lots of soap residue
Try the combo liguidgel powder packets and wash on the potscrubber plus setting. We saw a drastic improvement with this setting. I have just about gotten out of the habit of thorough pre-washing, but I do rinse heavily soiled items.
Aug 20, 2008 | Siemens 24 in. SL84A305UC Built-in...
Dishwasher leaving dirty dishes
Buy a couple of bottles of dishwasher majic, run those through and make sure you are not using too much soap.
Dec 28, 2007 | Maytag MDB7100AWB Dishwasher
HElp Dishes not coming clean
Run the unit with no soap, after about 5 min. of run time open door and check to see if water is clear or soapy,If soapy then you are having an oversudsng issue.When your washer gets to rinse cycle, your unit (if oversuding),will be rinsing with soapy water and the the drying cycle bakes the soap on dishes.You might be having a white film on your clear glasses.Cut down on soap especially if you have soft water.powder soap is best.Your dishwasher will fill , wash , the drain.Its what you put into it that will cause dishes not become clean.
Dec 01, 2007 | KitchenAid 24 in. KUDI02IRBS Stainless...
Dishwashers Logo
265 people viewed this question
Top Amana Dishwashers Experts
Oloyede Monsuru
Kolbrun...
Mike
Are you an Amana Dishwasher Expert? Answer questions, earn points and help others
